TA的每日心情 | 开心 2017-2-26 11:53 |
签到天数: 7 天 连续签到: 1 天 [LV.3]偶尔看看II 累计签到:7 天 连续签到:1 天
发表于 2011-12-6 14:53:57
95页,Islanding 这一章就有讲到。
# S8 |, Y! {) G6 k# |! aTo prevent islanding, a DR unit operating in parallel with the Area EPS should disconnect from the
. I9 S' g* I" fsystem within 2 seconds of sensing a voltage sag or discontinuity of service on Area EPS side of the PCC.9 Q5 D+ R, M4 Z' e+ n6 R
This is typically fast enough to allow disconnection prior to the shortest reclosing times found in( u8 k, K. Q; x2 w
protective relays on the Area EPS. It should also prevent reclosure into an out of phase DR unit, as well" }) g( k) T6 q3 C% R
as allow the fault arc to deionize prior to reclosure. Once a DR unit has disconnected from the Area EPS,
/ O, M, E/ u8 _' A4 x/ lit should not reconnect into a de-energized system |
