查看: 4340|回复: 8
电力英语1
    2020-12-22 16:34
  • 签到天数: 7 天
    累计签到:7 天
    发表于 2008-11-4 12:04:52 | 显示全部楼层 |阅读模式
    电力英语  : e# V. {; j( _$ Q0 j% `2 F* G
    ignition voltage 点火电压; 引燃电压
    2 r" u' N, M3 `" k1 A% _
    & F7 j3 p! `( H! ~  Aimage accelerator voltage 图像加速极电压
    , d: B" u3 B4 L3 a- v, w3 U8 {
    6 C. l8 {% T% s: i' h; Yimage focus voltage 移像聚集电压
    / d5 Y% Z2 X7 ^) m0 `0 G
    ' Z: t) u: |9 P0 t* himpedance voltage 阻抗电压
    6 H+ O/ a3 z4 E% A- Q
    : C9 _7 B; J3 Qimpedance voltage drop 阻抗压降 ' o* F3 F: A- ^* u5 t0 F
    # a! ]' f& y4 h/ ]1 s
    impressed-voltage 外加电压
    $ J6 d6 o0 c6 t) K- x; i5 N2 r2 _3 I( h8 ]1 t( F  Q
    impulse flashover voltage 脉冲闪络电压 " t7 ^5 r; w4 O- C
    " a. [* Y8 V4 {1 ?
    impulse type voltage regulator 脉冲式电压调整器 ' c& j, {4 Y' f' c4 s* L4 H
      X7 f8 |% X& M  g$ o/ b4 O
    impulse voltage 脉冲电压; 冲击电压
    9 X& y8 p! T$ @- w
    " w8 P  A4 ]2 r) d0 eimpulse voltage characteristics 脉冲电压特性
    . W1 E' g0 V7 }  j# S4 C' r  S0 J+ x. T) M
    impulse voltage divider 冲击分压器
    ( T4 ?+ g& z2 V$ q  i; m7 b" T& u( n6 L& |, W6 M+ B
    impulse voltage generator 冲击电压发生器; 脉冲电压发生器 * u, O% b, v! K
    # g; X$ B: T4 V# J  Gimpulse voltage oscilloscope 脉冲电压示波器 & e& Z: u8 z) D$ c
    & N+ p; r% d  j: uimpulse voltage test 脉冲电压试验; 冲击电压试验
    ( S4 u" \& k* M4 s9 D2 @) w5 c
    1 a$ q4 ^3 W; i% X) R1 v, \impulse withstand voltage 冲击耐压 . k$ i$ N* z" N% a. V
    $ ?6 R1 \9 C$ U% Limpulse-type voltage regulator 脉冲式调压器 4 B$ j7 V% q2 E7 r, U
    0 p# A  M$ [  A) g  ?: Tin-phase voltage 同相电压
    ! @4 q3 |7 ]2 x& R. T+ p$ z  v( i0 N  ], k
    indoor high-voltage isolating switch 户内高压隔离开关 : V7 v1 o2 u7 U; n2 p( N
    ! c; x0 X% A4 z" y* Iinduced over voltage withstand test 感应耐压试验 4 ]' c. f: k( b
    % v4 T/ q* _& W- winduced voltage 感生电压
    9 y5 ]' a+ w  J) g* Q1 K
    2 X9 r* V& ]& q$ Qinduced voltage regulator 感应电压调节器
    , N  ~/ c  V4 f. X; n$ B% u  G0 b$ J3 T& S
    induction type under voltage relay 感应式过低电压继电器
    6 x1 P% l: i9 C/ o  N4 Y0 V" H" W) Q  I
    induction type voltage regulator 电感式电压调节器
    ! K4 v; W% t9 e/ s( g) @- u# {6 g7 l
    . G/ b1 V0 I+ K8 B6 h2 Einduction voltage 感应电压 7 J" O: @7 g; ]9 p$ X
    1 |% U) T$ T# h& Q; Ninduction voltage regulator 感应调压器; 感应调压器; 感应式调压器
    + q4 w( Z- b, t; r, ^! y
    : V2 i, k. T  i# ~2 P+ Dinductor voltage regulator 感应式电压调整器
    : S9 i0 M9 P8 J# {! O) t2 g, P& @" V+ u1 J1 T. {4 d" \7 [* z: G
    inherent voltage regulation 内部自动电压调节
    + O, {6 v8 o! R& z3 J
    2 ?/ {8 J$ Y& }$ n; Rinitial ignition voltage 初始点燃电压 + @9 N; C1 J: d; @5 J* M
    1 }$ O: W3 h# o& n
    initial inverse voltage 起始反向电压; 初始反向电压
    % G  B. \. b) [0 q, e; o. x# a$ ~- Y- ?1 k0 ~
    initial surge voltage 初始浪涌电压 7 {' Q5 a9 H1 ?" @& E' p. k2 [
    ! d$ C9 A+ V! v( d4 s' |7 t& v0 oinitial voltage response 起始电压响应 3 H( V8 O' {+ V6 ]! j3 R
    & d( K# y! e, i) f. F3 u3 A
    injecting voltage 注入电压
    1 [  X: n2 g* _* M+ {% [& p. e: c$ _2 ^) w# ~- @* w. p
    input gap voltage 输入隙电压
      T3 e3 I1 _* ^: `( L' j. n4 _& w8 d% y/ r2 g- g4 Y) [9 Y
    input offset voltage 输入补偿电压 6 y! G5 |# N" b& m" f
    - K( Z4 x! ^5 o1 H
    input offset voltage drift 输入补偿电压漂移
    2 F1 J3 U9 g9 @1 o& R! s9 e% i3 P. \, _
    input voltage 输入电压
    ' ?$ b3 n! J# d/ U; I7 p7 X3 G8 K% T/ i/ p  T! N8 b( D; E
    input voltage filtration 输入电压滤波 4 r! a7 L$ B7 D
    % K0 W) m' h  H2 w8 B' y& `input voltage range 输入电压范围
    ! M, c9 N7 G' R' J+ e* J' G" w4 v3 |
    instantaneous voltage 瞬时电压
    ) U8 p. G4 Q' g) n- w" T. x; V3 d  i; b! m% u: e  u3 w5 Z9 v
    intensity-voltage dependence 强度电压关系 0 q, g$ \# \4 p- B! P
    & C1 y& k9 z& m  [
    interdynode voltage 倍增极极间电压
    & l9 ^) B, U4 _2 p2 p. N0 U3 ^& p$ ?0 q+ X6 A
    internal abnormal voltage 内部反常电压 $ z; ?* z3 _- h- Q$ _$ @5 ~
    8 R" c! c; Q1 ?1 j" K! linternal voltage 内电压 , q9 ?7 n( q  a" K
    ! ]$ Y2 T  |; M4 o# i: o" Ninverse peak voltage 反峰电压; 反向峰压 ( X' e$ S' u1 ?* o+ ^* V" w
    + \6 S9 C6 B1 q0 N
    inverse voltage 反电压; 反向电压; 逆电压 : ], ~# y+ `( c7 h
    ; F6 x  [& e3 w$ y6 o% j/ n: _ionization voltage 电离电压
    9 r$ j' Z- V; n! y
    - L$ |8 p( B- q7 t) eIsenthal automatic voltage regulator 振荡型自动稳压器; 爱生塔尔自动稳压器
    , g+ |' m% [. P, q- _+ K
    ' w5 c  [' W( S  c3 c9 f( W' jJohnson noise voltage 热噪电压; 热噪声电压; 约翰逊噪声电压 , X$ x1 s# G% H/ n
    ; Z1 S" Q( D$ N/ f, v! F- M5 akeep-alive voltage 激励电压; 维弧电压 0 h  f; o4 M6 u4 B2 k. a
    ; N9 {" O( V" F
    keeper voltage 保持器电压 $ w6 e* S, E4 L( \2 X, B
    4 c4 j" u$ f& i9 ]! i- @" n& i
    Kirchhoff's voltage law (KVL) 基尔霍夫电压定律 1 W$ n8 @9 w4 J, C! t# M0 ]6 v
    0 D. w. C* Z$ @& N" e
    knee voltage 膝处电压
    - h$ c- T) a; D# ~4 ^, _5 C  \6 \- W0 M0 Y& ^& o+ n5 x- r
    knee-point voltage 膝点电压 + P' N. l7 Z# j3 ~# |5 K( q0 b( A
    $ u7 I3 \" Q5 p6 [; |3 {7 clagging voltage 滞后电压 + W' y1 p: Q# ]
    ' ^* N0 j7 R& \. H6 n& _0 V& _lamp voltage regulator 白炽灯稳压器 4 C, ^2 e, y! O' z" W3 D# x4 m
    % R8 A+ o- o1 Slamp-voltage regulator 灯电压调整器
    * w; r* K) q3 [
    " Y, E# w: O1 j+ z) u* O/ X. xlarge over-voltage operation 大过电压运行
    5 V- j- {/ ]( |
    / K6 \- \/ I* K4 C4 u4 n' hlatching voltage 闭锁电压
    . a% l1 P4 C6 r3 {6 V, v  A' Y  Q8 l7 V) G& i: J  a9 `4 i
    lateral voltage 横向电压   `, w- X1 [& g, G! y1 X& X
    6 s/ ?2 e/ E; W+ T% y2 h5 bleading voltage 超前电压 - i8 N5 G- D8 S1 \
    7 t1 A" H0 z' U2 T# j6 ^* j/ Z7 Vleakage voltage 漏电压
    + f! a5 p1 z: B
    0 P9 p: V# D2 i2 }- ^( @lethal voltage 致命电压
    4 E' L! x. B7 q" s1 W% b+ F+ C( w3 C0 e; G$ A
    lighting voltage regulator 照明网络稳压器 ( P5 n8 ~7 O/ j6 e, S
    3 k# M  w' n# a7 v, g0 {) e
    limit voltage 极限电压 & r6 ?# x9 ]& Q' m, _' W6 N) H
    " X0 s% D% X% h
    line charge voltage 线路充电电压 , u1 W, t0 F% p1 a* Y: b
    ) {' q8 h' o' b( \2 r
    line voltage 线电压; 线路电压
    5 \: @3 H/ m: ~; S8 v1 O
    * J1 N* v7 B! m; aline voltage controller 线电压控制 ) p; m. K# V' X, g  \5 x" g
    + z4 I) k6 y1 y: @
    line voltage start 线电压起动
    7 C+ _$ q9 F+ G2 c
    7 K7 X! j# b+ C' ~; {line-to neutral voltage 线与中性点间电压 2 \- |3 u1 q7 z5 [1 C" r. k5 D- s
      w, h- f3 S* L  c+ f' p  xline-to-earth voltage 线对地电压; 线路对地电压 - ]2 @8 q9 A' ?9 E% w
    . }8 D) f, s" B5 Fline-to-line noise influence voltage 线间噪扰电压 % z5 T5 b, R$ l3 e$ ^  q( f  y* Z
    ! K1 p9 @4 H3 k% |# g- l5 V6 y! F
    line-to-line voltage 线间电压
    7 i* `! b) z: n* ^9 \2 M% ?2 d# v4 O; O& u- E) _8 t: J
    line-voltage distribution 线电压分布 . f9 y8 [" ~$ Z6 Q: V( t$ v
    ( |# }; i( k6 z, Z6 W$ @: Yline-voltage regulator 线路电压调整器; 电源电压调节器 4 U: b  U: w* `; Z/ v
    + o' G  Y2 J# N: A* r. ]5 A) i7 t
    linear decrease voltage 线性下降电压 $ S( j' B9 i; R/ t  u& Q6 Y6 x4 L! `. w
    ' S, V: W: x6 N# ?linear increase voltage 线性上升电压
    参与人数 1威望 +2 收起 理由
    liuqingrui + 2 谢谢分享!
    2016-10-18 19:12
  • 签到天数: 5 天
    累计签到:5 天
    发表于 2009-3-28 11:07:16 | 显示全部楼层
    不错啊,谢谢分享
    2017-3-14 09:46
  • 签到天数: 10 天
    累计签到:10 天
    发表于 2009-4-4 23:09:05 | 显示全部楼层
    多发点吧,哈哈,,
    发表于 2009-4-9 23:13:33 | 显示全部楼层
    其他字母开头的呢?
    发表于 2009-4-10 16:57:25 | 显示全部楼层
    嗯,好,先把这些消化了!
    发表于 2009-4-11 11:01:22 | 显示全部楼层
    谢谢你的资料
    发表于 2011-9-18 11:38:45 | 显示全部楼层
    好多啊 谢谢楼主。
    发表于 2011-10-20 21:45:10 | 显示全部楼层
    搞翻译的时候有用,谢谢分享。
    GMT+8, 2026-11-19 07:22
