查看: 2559|回复: 2
电力英语4
    2020-12-22 16:34
  • 签到天数: 7 天
    累计签到:7 天
    发表于 2008-11-4 12:01:23 | 显示全部楼层 |阅读模式
    电力英语
    8 E& U( O/ E: l. w) }# n* I+ h6 Z 2 M0 u. `8 ]. Y$ k- a
    noise voltage 噪声电压
    " V( u5 X' ?5 v% L0 @+ t' U2 y  t, W7 g* L6 `9 e
    noise voltage generator 噪声电压发生器 ' y1 o0 Y1 \1 Q/ B5 R$ O
    9 ~; q* j( @: ~$ snominal circuit voltage 额定电路电压 4 ?# R; B. x0 z" O# x. {4 |* x
    : n% S$ @- h: m  I+ J+ U4 a- b
    nominal insulation voltage 额定绝缘电压
    / t; Q$ Q  ?5 ^# t$ |
      t9 b: ?# `( y* ]/ }nominal short-circuit voltage 额定短路电压
    # `5 x6 i7 `8 w6 }2 H
    0 E. C* m" d- {4 }nominal system voltage 标称系统电压
    , _. S0 U, k0 D" |2 ~
    * |( q! ?  k' m; k* h5 ]nominal voltage 标称电压; 标定电压
    : \+ ?# S/ H. D, Q. r  x
    ; [' N; V# j8 _: \' m" C/ r, Qnominal withstand voltage 标称耐压值
    $ Q5 n# }' E( [5 L% J+ [) T, c9 E3 |2 F5 }3 ]  c
    non-conducting voltage 截止电压
    / R9 A' y! R& f; W5 w
    3 l2 Y: t1 P8 A, q3 Q  enon-load voltage 无负载电压 * R- _- X4 I* \
    , V2 O6 }- J4 b  k" Z& J& v
    non-repetitive peak reverse voltage 非重复性反向峰值电压; 反向不重复峰值电压 5 g  V: t" e# x! B9 M. Y& ?0 [
    * T* W. ]8 l! {* ~$ anon-sinusoidal voltage 非正弦电压
    . N8 \& O! e2 H. ~" ?* L" l* u, V7 L0 P+ G; R- i* z# m
    nonzero pinch-off voltage 非零夹断电压 : _7 Z3 ?& r4 H! F2 G
    . g3 c3 B/ q' pnormal dropout voltage 正常释放电压
    # X3 [* H, i5 k3 [$ K0 M) M. E4 z9 T, d6 }0 f4 u
    normal voltage 正常电压; 标准电压
    ' B' Y4 L- i) i# a! _+ M
    # `! u. u9 }' Q* ~' d4 gnormal working voltage 正常工作电压
    $ L* I: I" L; C5 [
    3 `/ ]$ u' _; i6 x$ o! E2 r" onormal-voltage rating 正常电压下的额定值 ; F' K/ [6 S$ O$ \
    ! c4 |6 s+ A1 Z; znormalized voltage 归一化电压
    1 ~( _9 }# j5 l' D9 N+ b$ C# Q7 f9 V" W' d; O4 {) o5 r
    off-standard voltage 非标准电压; 不合标准电压
    % Y6 ^( D5 z6 F' F- Z& O, I2 @" J, |$ i( w( U( g4 ~& m
    offset voltage 补偿电压; 失调电压 2 Y( Y5 K9 d8 T0 J
    : G" ?5 D& n) x$ f" z+ h
    oil-operated voltage regulator 油压操作电压调整器 ( ^2 C$ N' g: o" m( `: g, r
    * Q) {6 F1 v7 g. Y
    on-load voltage 加载电压
    9 @  {! Y; G6 ?% P4 @4 S) |5 m; t  m3 G% T
    on-load voltage ratio adjuster 加载电压调整装置
    4 K. d! A- k3 b% \+ O
    , x8 S. S4 B. G1 ^open-circuit voltage 开路电压; 空载电压
    : b" w( Q" K: |: g6 e- ]
    4 U  s: R6 j$ x& [open-loop voltage gain 开环电压增益
      d/ G: ^2 l" g/ }, f+ {
    * S  T" z% h/ O) ^# J9 H5 J" ?operating voltage 工作电压 7 S8 g  ?; P8 V+ l6 Q
    4 Z7 H* t& i) p" a# k& u  P
    operating voltage indicator 工作电压指示器 . I# Q- r3 s2 J! n6 v, `) L/ S1 X
    9 y8 f( w7 M6 q, E/ k
    opposed-voltage protective system 对消电压保护系统; 起动保护系统
    * ~& ?1 z" v+ H# y
    2 r% L) g" u7 Q5 F+ e5 [opposing voltage 反向电压
    2 i2 f- x2 O& m) i
    5 p4 d$ O5 v$ K3 f, Xoptical fibre voltage sensor 光纤电压传感器 6 `( n/ P* K" w
    , l0 q" b1 I8 ]optimum anode voltage 最佳阳极电压
    + F8 ^; p0 Y# s( j* T! k6 c1 u
    ; {2 H0 \  [  M: j" H) A  moptimum operating voltage 最佳工作电压 + i- p5 ^% J2 f7 R% w
    2 q7 Q5 l5 o+ D! d9 X; j# U: B2 v
    optimum voltage 最佳电压 " J. i4 @. S; Q6 q! c
    $ J& A5 o% b7 O: b" J& H8 _oscillating voltage 振荡电压 1 Q: |6 E1 G) t, }1 Y/ {9 k
    / Z2 n9 y8 T6 f2 D
    oscillator actuating voltage 振荡器动作电压
    # ~  C  t# r+ y" j" a7 y4 l' G! k; z" ?0 |! ?* y
    oscillator voltage 振荡器电压
    0 ?& ]8 s! Z# [5 K6 S5 X" w; N% |* W) ?) m* [
    out-of phase voltage 异向电压
    " E0 [9 Q' F1 @4 G  z% r
    ; F0 I! n- O3 T+ C' eout-of-phase voltage 异相电压
    0 R; F- c! \& j1 L2 h  R- M! u) [/ A: z1 q5 z( @* \6 g
    outdoor high voltage transformer 户外高压变压器
    4 c& I  E0 V% L* \/ k3 q! |, G' ~. h0 q( i% S% n
    outlet voltage 出线端电压
    2 e1 V5 o# m9 o, U+ N- N
    / C) D6 w6 d7 r, B+ b% r9 ]! soutput indicating voltage 输出端指示电压 1 M) C6 t0 S* y# ?& U9 R" T7 W. X
    3 x$ W0 u! ^6 o1 n
    over-voltage protection 过电压保护 ) _" D0 m1 D4 i7 a% Y/ M! K
    + F$ ]* L0 H7 ]$ Goverrating voltage 超出额定值的电压
    7 V$ ~' Q+ P7 L4 M/ k) h- K
    # n( x0 T) O/ }9 P$ X* Cpace voltage 跨步电压 $ ?7 ^/ ?8 y: K" d" @" P- L5 O
    : u* T# \+ V' e! n$ u" tparabolic voltage 抛物波电压
    9 a4 P; j0 H' h/ t* \* g1 L
    % x6 f9 m1 o% N5 E: Sparameter voltage stabilizator 参考稳压器 5 Z  R4 V/ ?; g9 l3 J5 o% G
    # {* f; t* L* Y7 @" N2 t, pparameter voltage stabilizer 参数稳压器
    7 U& v0 M  n0 v2 D  a/ x" M5 F0 w
    * B3 Z; \+ [2 C9 j) D6 b) dpeak forward anode voltage 阳极正向峰压; 阳极正向峰值电压 7 g2 g1 Y* n. l8 {
    / d1 O; V, m9 k+ M2 y
    peak impulse voltage 脉冲峰值电压
      M" \7 F5 S% Q; ^6 i% T/ c" V) C# o1 s- ~
    peak inverse anode voltage 最大反向阳极电压 6 V* k* {% [6 [
    " M$ y' z9 x+ J5 e
    peak inverse voltage 最大反向电压
    ) @/ L5 @2 g7 \& p
    4 q) u( g  |# k  J" t$ M+ Xpeak negative anode voltage 阳极反向峰值电压
    , I1 E5 i* F6 r  D' g2 W6 V# O0 h5 h' q5 U: J
    peak of back voltage 反峰电压
    . x5 _( A( ~# L$ P5 k
    ; U5 ~9 u  }- f, d) J1 Z) }1 zpeak point voltage 峰点电压 " T6 b$ c8 Z" E. o: o1 x# i
    $ D; H9 n$ L4 `peak pulse voltage 脉冲峰压; 脉冲峰值电压 4 t* h3 o9 p' v7 K  `, P; T, O2 [' @
    " r+ D) v7 ~4 zpeak voltage 峰值电压; 最大电压; 巅值电压
    6 I3 h, q' P; e" f+ s0 {/ M2 O4 `; d3 G1 P1 P. E
    peak-to-peak ripple voltage 波纹电压全幅值; 波纹峰间电压 9 c: [9 Z; X. q, \& _
    " f+ N9 A3 N# t0 O( V) w2 npeak-to-peak voltage 峰间电压; 正负峰间电压 3 @; Q8 a5 G1 a% t2 N5 V+ I9 t
    / R+ B! A- J1 i0 i4 Apedestal voltage 基座脉冲电压 / O/ C6 `& N# u/ S; M
    7 o$ I  O/ R5 f8 I! |8 v4 g9 Gphase control of grid voltage 栅极电压相位控制 . H: r6 Y; y# Y. V& ?' w5 h7 R/ S
    ) c2 y8 v( l. b! Q$ Q; f; Zphase voltage 相电压; 对中性线电压 6 m% x" ]9 G6 g0 @% v" p! Q, V/ X$ X
    " z* n5 V5 I6 J, i
    phase-angle of a voltage transformer 电压互感器的相角差
    : G) w# F1 w* z+ P, K! {
    5 c" i% g* t: H. ?, Fphase-under-voltage relay 低相电压继电器 ' V' B) X: x3 ~6 Q/ W
    ( e" l4 H% x9 T0 s. `% x7 J
    phase-voltage regulator 相电压调整器 6 ~/ T+ e1 j' u6 C1 {( f
    . @/ v! h$ c2 L3 Z) Vphotodiffusion voltage 光扩散电压 % |( I- e8 a5 f/ U# Q, }
    1 t, _) s5 n! U/ X, A) }( S7 }pick-up voltage 拾取电压; 接触电压 & Q* |' s2 s! b& `
    6 w! I: T% M3 Ipickup voltage 始动电压 # n/ z3 U, K# w& L) J
    & L5 f; K: A5 zpicture cut-off voltage 图像截止电压主 - `. l& Y" i0 }5 H5 P; }/ t
    * Z  y/ Z3 |: z! i
    picture tube high voltage 显像管高压 ) N) O7 D% j# N' X2 H* }9 I
    6 b* W8 {/ i6 E9 J6 Lpiezoelectric voltage 压电电压
    & l5 B4 f8 Y6 X8 k! {5 [
    1 l. |' Y4 V5 u* ipiezoelectric voltage constant 压电电压常数 : f5 j' ^6 T# h+ ^
      \! U0 v, G( }  K
    pilot voltage 标准电压
    7 i/ u( t. Z. Z! U/ c, D; F- Y; d* j2 A8 t0 w
    pin type insulator for high voltage line 高压线路针式绝缘子
    / L7 k9 q" e: R9 |% D/ J
    ) |; D: ~# [7 {6 m! Y- npin type insulator for low voltage line 低压线路针式绝缘子
    , p6 m2 S$ v  o& ~. s# j" t; F4 C, Q1 B1 A) e0 W
    pinch-off voltage 夹断电压; 箍断电压
    参与人数 1威望 +6 收起 理由
    liuqingrui + 6 谢谢分享!
    发表于 2009-2-17 01:27:42 | 显示全部楼层
    支持楼主的整理工作,顶一下
    GMT+8, 2026-11-19 07:31
