查看: 1841|回复: 3
电力英语2
    2020-12-22 16:34
  • 签到天数: 7 天
    累计签到:7 天
    发表于 2008-11-4 11:58:41 | 显示全部楼层 |阅读模式
    电力英语 2# S! p! Z3 n6 ^1 a  M" ^, |
    9 F3 r2 M" c1 h4 g! Xlinear voltage 线性电压
    $ O! S* z9 P3 ~) d% i" i1 _# D- ^$ u$ }- U/ ^7 E' L: U
    linear voltage wave form 线性电压波形
    ! p1 @" l! b, s* Y! ?3 K- Z9 X7 N* w6 u. x) Y
    linkage voltage test 连续加压试验 ) J) ^( N1 r4 U6 }' P
    ) t1 r) W# h+ j# l1 z
    load ratio voltage regulator 带载电压调整器; 负载电压调整器
    ( Y! H" o- e  B5 L) U
    9 s+ E& h% ]+ bload voltage 负荷电压; 负载电压; 工作电压
    3 G) X! I2 U8 N: H5 Z1 g! {+ {6 \" g+ f# ~7 C7 r. K
    locked rotor voltage 转子停转电压
    ! m% I* w( y" p" l
    - V3 u% i1 B- W) z4 y1 d  s4 ulocking control voltage 同步控制电压
    6 p7 H* x% Y& e: W3 {. R
    0 u7 b  }2 @/ V1 Wlogarithmic voltage quantizer 对数电压分层器 ! u" ]6 G: ]; i
    ) v  H2 \( ~8 b3 n. R
    longitudinal disturbed voltage 纵向扰动电压
    0 }: n. t/ u) l/ Z# D& Y
    2 @, n2 l$ g' _" Qloop voltage 回路电压 6 {& K) u$ \/ |2 Z% Y3 P9 A
    + @) Z1 E1 Y" A2 R' q
    loss of voltage 电压损失
    & y7 H6 R. ~; T0 C% {7 F7 i+ d2 M
    low & high voltage power capacitor 高低压电容器
    5 L3 O. C" f0 n3 R5 v- z3 o2 X! Z! L4 c  ^
    low idle voltage arc-welding power supply 低空载电压的弧焊电源 9 ]) T$ ?& s- p8 r. ?) a. _
    2 U$ c5 t  ^+ ^# |4 u
    low tension voltage 低电压 & o5 N. G9 \. V, d2 H
    / u7 T6 y9 G$ l* r: g
    low voltage 低压 * j, Q) U) W# S/ r4 b* _' ]
    ( ~) x" X( |) y8 k5 I! Z
    low voltage automatic air circuit breaker 低压自动空气断路器   ?, A/ r3 W% ^% u9 T- E# t6 n
    $ l. e; D" I) n$ ?$ z0 U
    low voltage bulb 低压灯泡
    0 M! R0 ^+ W: w! ^2 G' T( [/ R
    ' `5 P" T5 W8 L& [- h4 ~  y, Clow voltage cable 低压电缆
    7 ^) |' A$ b) C7 U$ S. s6 n0 u' D5 V/ w
    low voltage cable end box 低压电缆端箱
    , i1 X0 i1 x9 N2 p/ ]  k- ~
    $ E: I* e, U) P$ `0 _4 h( Rlow voltage capacitor 低压电容器
    2 b$ A* [  ^% [# T
    0 Z% u4 A; S6 _" ?+ olow voltage ceramic capacitor 低压瓷电容器
    ' W3 x' N4 d- ^$ A& `
    ) g* R- E& _8 H% \! glow voltage circuit breaker 低压断路器
    * N% U0 ~7 T' l, K7 L# B9 a) V. A' B& p) N( L  u
    low voltage electric porcelain 低压电瓷 - B! f2 j& i# s* E/ ?
    * a3 d! r" _+ ^: L1 i2 z* Zlow voltage focusing 低电压聚焦 ( ^* ]5 }! G. g& W$ q% F  K' s
    " j4 _, ]+ H* m. [6 F
    low voltage fuse 低压熔断器 2 |3 G; g/ Y  q/ v8 N
    6 I  d  A+ a, ^# ]' G$ k
    low voltage fuse element 低压熔断器芯子 2 E  h4 ~- k* ]! ~# i8 M- T
    : `9 ]% g8 v+ b% N4 ]low voltage generator 低压发电机 9 ~, Y/ G# c: L# Z! M5 m$ R2 \- \
    " B6 E1 ]# ^7 I; t! O) Vlow voltage He filled proportional counter 低压充填氦正比计数器
    & R  q# l: L$ L
    ! |) E" k: c0 _" F! llow voltage insulator 低压绝缘子   j9 p- k4 u! O- ~" O$ g
    + g7 o1 C2 C0 b# K5 g
    low voltage klystron 低压速调管 ; m4 B) A* E7 i: z' [) _
    5 A+ _4 e/ B( S* L5 [  s# glow voltage mercury arc lamp 低压水银灯 / m8 Z+ r; e* v
    . ^! V- d* ]3 l* l# C( Y
    low voltage mini-relay 低压弱电继电器
    8 L0 l- u8 l, d( T- Z) q$ C6 |
    " g% X. f* L' ilow voltage oscillator 低压振荡器
    4 O, \* G4 s, C7 @# n$ q* K, q5 z# s' f0 e' k* @% z1 R; [
    low voltage potentiometer 低压电位计
    7 O; W7 r* k0 o8 H5 s
    ! U) L) O' G0 r) Dlow voltage rectifier 低压整流器 $ z. E1 X9 b$ D. v/ x
    9 @9 Q1 Q5 U& b% h3 k- \low voltage rectifier tube 低压整流管
    ( q9 O* C, l1 C" X6 c! E: v5 F1 F
    . f. J7 t0 u+ A4 clow voltage relay 低压继电器 ' h0 F! t0 |8 \0 K6 P7 k. E
    3 a: c& U' U+ X% q
    low voltage release 低压释放器
    , X/ Z, a0 r1 v; P- C+ G
    ' C4 O* C( P; I+ F& ~; plow voltage release relay 低压释放继电器
    ; d. F/ w. {9 E
    4 g2 {1 f5 f3 |7 f. ?low voltage starting control box 低压起动控制箱
    0 w5 g* F' A1 d9 s) u) S6 o9 R. C/ K9 s* z& |( g. `& n
    low voltage surge arrester 低压避雷器 1 I' t8 s$ q6 f  x; F( ?, z. Y0 n. E
    # v0 B# D" ?& U. ~' Xlow voltage switch 低压开关 - G. a* H. V3 z9 b+ G
    4 ?+ B1 q3 A, }/ elow voltage switch board 低压开关板
    7 j6 j( h7 p6 |- q, c$ l! M. t& x6 K7 f( B8 M
    low voltage transformer 低压变压器
    + p# ]+ I6 N' P( n- K0 S! }  r8 a5 {- @' f
    low voltage tube 低电压管; 低压管 & n6 O. Q3 U$ Q8 x5 t
    * Z8 ?, ?* B* J2 j6 c6 j, jlow voltage winding 低压绕组
    / \6 m' c1 z7 f+ L' X5 H" d
    ' K7 j% A7 T! E( G* A9 ulow-frequency dry-flashover voltage 低频干闪络电压 7 I( C, W8 m4 |: o7 O; T
    ( O# `* x9 p4 n
    low-frequency puncture voltage 低频击穿电压
    9 L) X! m9 T) c* y2 e% }0 t8 H- b
    3 I2 d0 g+ Z9 K/ G( clow-frequency wet-flashover voltage 低频湿闪络电压
    ! m: Y( c' X& B2 T5 _
    ; [1 F. R3 Y3 u0 J0 S7 p% _low-power voltage regulator 低功率调压器
    1 B7 _7 F: w. l. U, H6 ~" [$ U/ \
    . Q* y9 ^( c) m! m; F- g: jlow-voltage 低电压; 低压; 欠压动作
    ( |0 W& c3 B* x2 Q! S& F+ S
    0 \& g. C: x) J& Xlow-voltage apparatus 低压电器
    5 Z" f- D: q, n! h9 O
    % |( b5 ^' G$ y) Flow-voltage arc 低压电弧 ) C* D; w# M' {/ M4 J7 ], W5 u
    - N( x8 E1 E$ x
    low-voltage circuit breaker 低压断路器
      d  T' T' j6 g
    , }- N. C" m' b0 W; v6 j2 ilow-voltage coil 低电压线圈; 低压线圈
    ! E: d6 V/ S6 U; ?# M# f0 \/ \' c: s2 ?
    low-voltage commutator 低压整流子 ) w) x* s3 Y' }. d
    4 z0 \2 D2 h% Z5 J5 g
    low-voltage distribution system 低压配电系统 ) [- x2 G* |( O" n2 W
    0 i( u7 N6 m# |" o. Q9 N4 Slow-voltage equipment 低压设备 2 `# m1 ^$ j, C
    / L3 e6 _0 v$ Z9 Z/ ]: V
    low-voltage generator 低压发电机
    0 ~) l  x2 W# N4 {/ i# R
    * f4 E  i/ |8 n0 x3 r- r$ G7 tlow-voltage heating 低电压加热 9 v; G% K2 |4 ]7 u
    3 H& ?2 e  x( v/ x
    low-voltage insulation 低压绝缘 & h5 b0 f- ]" X: G+ Q9 q
    8 [+ ~& c- z# }7 L% ?4 I, G$ O0 d
    low-voltage insulator 低压绝缘子 1 |+ s* o2 K  f  [
    : n; Y! a2 F: V
    low-voltage lighting control 低压照明控制
    ( J9 O' x4 ~! ]( A5 c6 b  M
    " m; j9 M, y& n; e9 Wlow-voltage line 低压线
    . ^, @; S4 m$ k
    1 j: S) H8 h' D- a1 glow-voltage network 低压配电网 2 ^& T/ w1 [' c! A6 ^# @
    ; T8 m* F  H+ z3 ^& `
    low-voltage oscillator 低压振荡器
    , E/ h2 H$ i1 m  j5 }
    6 U4 h2 N  \; o4 B9 j0 J: x1 w9 ?low-voltage power supply 低压电源 4 U+ T; Z5 n  n* @
    5 d$ v$ b/ R- i7 S$ _' Qlow-voltage protection 低压保护; 欠电压保护; 欠压保护   D; z0 e9 p, b, h5 g( L; P8 j8 o+ e
    1 I8 k& q. |6 w* g# blow-voltage rectifier 低压整流器 0 Z9 T! |" T9 x2 V" z7 d
    1 u" b7 S0 M, ]0 v' {: L9 u- |
    low-voltage reflex klystron 低压反射速调器 : ^7 e7 w4 Q7 h9 S* m8 T
    - J1 O* P& U' M4 r  b
    low-voltage relay 低压继电器
    8 F; {! N" o+ Q7 z& U+ T
    1 w% N. c9 R7 ^# V# j1 Hlow-voltage release 低压释放 & k2 u( n# J' B& [! k- D  D
    ' u. t; j- t3 m5 C: _
    low-voltage release relay 低压释放继电器 ( K# t% z7 X7 Y) P) A
    & n/ j. _. D# g9 r- {
    low-voltage state 低电压状态 8 O' I/ w  z0 }2 q6 H: P" u& A# {; {. m
    . F% H' T( j8 ]low-voltage switch gear 低压开关 ; Z7 c( j) A2 X" m
    5 L9 q3 t8 ?: k  f3 h: ^. P8 ylow-voltage system (750伏以下电力系统) 低压系统
    + J* [" W, m" a% _0 @
    4 B, |- t9 F4 b! i4 j) Flow-voltage winding 低电压绕组; 低压绕组 5 J" T/ M" {- t3 X6 p& S
    . S" K- [6 D  i) w- T, W2 iluminance voltage 亮度信号电压
    2018-9-23 10:25
  • 签到天数: 23 天
    累计签到:23 天
    发表于 2018-8-27 16:46:37 | 显示全部楼层
    谢谢楼主分享
    回复 推荐 踩下
    使用道具 举报
    2018-9-23 10:25
  • 签到天数: 23 天
    累计签到:23 天
    发表于 2018-8-27 16:46:50 | 显示全部楼层
    谢谢楼主分享
    回复 推荐 踩下
    使用道具 举报
    GMT+8, 2026-11-19 07:31
