现在用matpower工具算潮流,发现一个问题。执行runpf('case××')算得某一个PV节点的无功出力是24.3,然后我修改generator data数据中的Qmax和Qmin,把Qmax改成了24,然后重新用runpf函数来算,可是得到最后的结果,这个PV节点的无功出力还是24.3。' f- Y( C" S' s1 e: V ?
我查看runpf.m文件,发现里面有关于无功限制的语句,就是当无功越界时,将PV节点转为PQ节点。那么为什么执行不了呢?求教各位朋友~~谢谢~~
2 }* [% y$ N2 |& Y- F( C+ m, N这是runpf.m文件中关于无功越界处理的语句,从234行开始:
! W' F0 f+ p/ E* i. Y5 A %% find gens with violated Q constraints
: o6 G) r8 p' c6 T! i mx = find( gen(:, GEN_STATUS) > 0 & gen(:, QG) > gen(:, QMAX) );
) d. D. h; V$ h, r& z mn = find( gen(:, GEN_STATUS) > 0 & gen(:, QG) < gen(:, QMIN) );# Y. S: R& A ^5 V% r5 g
if ~isempty(mx) || ~isempty(mn) %% we have some Q limit violations K, i8 s; |4 v4 g
if isempty(pv)7 n' ]* v& t8 L' \4 M j* m
if verbose! E' F4 B6 O6 q3 S4 b
if ~isempty(mx) # y1 L& \: h% E" E$ m5 k
fprintf('Gen %d (only one left) exceeds upper Q limit : INFEASIBLE PROBLEM\n', mx);, @ S! C% n2 s, h/ ]$ ^& s$ c6 @
else; [$ v8 o7 V+ S/ Z& n
fprintf('Gen %d (only one left) exceeds lower Q limit : INFEASIBLE PROBLEM\n', mn);1 V/ T% f% ]& F8 y7 M. t
end# S: R- y" ^0 y/ U5 u( L
end: O. S6 \/ S0 ?/ X x
success = 0;
' g# Y. [0 X: D1 ^6 P D H) y break;
" T& l# c- D' ~ end% ` W0 y4 h% O* F
8 J1 D& ^" b+ c4 v" `- h* V s0 V
%% one at a time?) [5 W! u8 R3 ?- S
if qlim == 2 %% fix largest violation, ignore the rest7 {1 r1 M) r# @9 G$ l" m) q2 B* v' ~
[junk, k] = max([gen(mx, QG) - gen(mx, QMAX);
/ e6 Z* O1 y& X7 x gen(mn, QMIN) - gen(mn, QG)]);
3 X1 ^5 b: X& M' c7 b if k > length(mx)
3 T+ b6 w; ^' J( O! @3 ?- G8 P) k mn = mn(k-length(mx));# g$ j4 K3 p' ?% W
mx = [];
7 l7 e( x; C9 s4 Y0 U/ x \; d7 D else
R8 H$ }! I+ ` [+ k5 G. v4 I0 h0 r mx = mx(k);
- F9 P( @& Y& h5 @) ] mn = [];
# e# [+ V* k$ J+ B( E# N9 o5 { end. U# w2 z) _/ V
end
- U' b1 h" M/ m/ R2 K7 e8 j) Q
% }. Y5 k/ Q' `8 C if verbose && ~isempty(mx)! N% k; B5 t+ I& z) A. K
fprintf('Gen %d at upper Q limit, converting to PQ bus\n', mx);
+ d. g2 x u; @% y end6 F( _9 v9 y; B# J \
if verbose && ~isempty(mn)
: k! P9 W' K/ x5 b fprintf('Gen %d at lower Q limit, converting to PQ bus\n', mn);* t8 R( p) {# a0 P0 J/ H$ g4 S3 \
end5 V) {) n0 Z/ x5 s
) V' [- z0 m; W! Q %% save corresponding limit values
' l) N$ B* s" _ I' M. _; J fixedQg(mx) = gen(mx, QMAX);
( d% J0 g$ e' i8 C! U5 [! J fixedQg(mn) = gen(mn, QMIN);
* D! d! x& H: k0 h, ` mx = [mx;mn];
, q/ Y8 _0 P, D7 T4 E t0 J 7 x, a) l* b$ `8 K8 p, k$ b1 L
%% convert to PQ bus, \- F4 `" z I$ O- p
gen(mx, QG) = fixedQg(mx); %% set Qg to binding limit
0 e# D( d) A1 \& W- N/ g3 N9 Y gen(mx, GEN_STATUS) = 0; %% temporarily turn off gen,
+ y- `; T2 \) b | for i = 1:length(mx) %% (one at a time, since3 y- m% Z4 D' c, l K4 V5 f! z/ b
bi = gen(mx(i), GEN_BUS); %% they may be at same bus)
; k1 d) y" B: e5 D8 l4 U bus(bi, [PD,QD]) = ... %% adjust load accordingly, J! h; A% O# N# N4 y
bus(bi, [PD,QD]) - gen(mx(i), [PG,QG]);
0 b ^& f2 G& i( ?0 P% D end
) j* D% s+ I- X; \3 [2 ]! g if length(ref) > 1 && any(bus(gen(mx, GEN_BUS), BUS_TYPE) == REF)% h8 a4 R- c3 G8 C
error('Sorry, MATPOWER cannot enforce Q limits for slack buses in systems with multiple slacks.');4 j: m* J7 ]( |; W& \8 c
end
+ b6 X! P/ I7 T$ r- `$ z1 a' \1 {. B* v bus(gen(mx, GEN_BUS), BUS_TYPE) = PQ; %% & set bus type to PQ |
