查看: 2436|回复: 8
求书(《High Voltage Engineering by Lucas J R 》内容如下
发表于 2008-8-23 22:01:16 | 显示全部楼层 |阅读模式
High Voltage Engineering    # H* K1 p& J4 j" |
& p1 j) W3 W2 R' G! B+ qby Lucas J R
+ l. H* J0 r- E! H3 s" N. j/ n9 m% K4 n, v( \! W: P# l
First Produced in Cyclostyled form 1970
( z9 c" d! g# }" j+ v[Revised and Reproduced periodically]
% O! P, B% W, P; q. gNew Edition 1995+ F& W* N: _6 O& l  G! Q1 ~5 q. Y
Revised Edition 2001
+ s) F1 p3 Z6 X) U9 W1 W8 _- n, s/ I1 s( o. `
1 BREAKDOWN OF GASEOUS INSULATION 8 e4 M' b6 z9 i4 b9 h9 \
2 BREAKDOWN OF LIQUID AND SOLID INSULATION........... ..................................... 22( c$ y! @+ Y! l2 Y
3 LIGHTNING PHENOMENA.................................................. .......................................... 34
, L! B' r1 p* @% `( c9 a6 g3 W4 HIGH VOLTAGE TRANSIENT ANALYSIS............................................................................................................... 45) M' d7 F( ]: h0 O& }+ k
5 HIGH VOLTAGE CABLES............................................................................................................................................. 640 T0 i8 o/ E: m8 L: ^# c2 `
6 MEASUREMENT OF HIGH VOLTAGES.................................................................................................................... 91
( I* p% C0 f* \6 K6 w( X2 Y7 HIGH VOLTAGE GENERATORS FOR TESTING .................................................................................................. 1236 }% h1 t7 @0 i- S2 D
8 HIGH VOLTAGE SURGE GENERATORS ................................................................................................................ 132
% E* \6 I7 V  u" J6 T4 I& R9 HIGH VOLTAGE TESTING.......................................................................................................................................... 1485 o  ~& w5 t2 j1 g) B
9.0 High Voltage Testing Procedure............................................................................................................................ 148
- k, ]8 \% d8 t. F9.1 General tests carried out on High voltage equipment ........................................................................................ 148
7 W9 }4 K" q; W9.2 Testing of solid dielectric materials....................................................................................................................... 1512 `' b  k$ Q+ F7 _/ V( i1 P
9.3 Impulse Testing......................................................................................................................................................... 153
& e$ X6 d# p  y/ D9.4 Voltage Distribution in a Transformer Winding.................................................................................................. 155' e2 s: m2 Y6 J2 V
9.5 Tests on Insulators.................................................................................................................................................... 158
2 F' u& V. j2 F) x6 G9.6 Tests on Transformers ............................................................................................................................................. 160
, C: }5 b1 A$ C! N. E' u& X9.7 Tests on Cables.......................................................................................................................................................... 161* ], F4 G' P' G; s+ |
9.7.1 Tests on Pressurised Cables.......................................................................................................................... 162( m* L' O1 z& |; P2 Z& c9 R) Q% ]# _
9.8 Tests on High Voltage Bushings............................................................................................................................ 163' E/ C! `" W% R) x: n5 R
9.9 Tests on Porcelain and toughened glass insulators for overhead power lines............................................... 1643 R. H) G: f5 w
10 INSULATION CO-ORDINATION.............................................................................................................................. 166
% ?# e; ^4 Q' I- l& j9 R! t10.0 Insulation Co-ordination......................................................................................................................................... 166) K" W  M9 y3 i- C" c
10.1 Terminology .............................................................................................................................................................. 1668 D2 m4 p* l4 w# w+ {
10.2 Conventional method of insulation co-ordination .............................................................................................. 168# J, Q: @( I6 D7 v4 I
10.3 Statistical Method of Insulation Co-ordination .................................................................................................... 1698 _  V4 t6 w( k# _# X, @: F
10.3.1 Evaluation of Risk Factor ............................................................................................................................. 170
. }# d" q, `4 r  h0 ^; U% ^3 X10.4 Length of Overhead Shielding Wire ...................................................................................................................... 170
( {, N: {/ r0 J$ \  j4 s. {1 d10.4.1 Modification of Waveshape by Corona..................................................................................................... 171
. G  o! C, w9 _; O4 i10.5 Surge Protection........................................................................................................................................................ 173
, Z7 M: N5 ?5 m1 c11 HIGH VOLTAGE DIRECT CURRENT TRANSMISSION..................................................................................... 184
) W9 P! `* R0 c$ N' u11.0 Historical Background............................................................................................................................................. 1847 l3 A5 Z3 f( h6 X; c0 Y3 v
11.1 Comparison of a.c and d.c transmission................................................................................................................ 185
: E1 N5 o' E6 x6 |  G) B& \8 e11.2 Convertor arrangements and operation................................................................................................................ 190
3 t1 P! g$ Y, A) q0 M/ F11.3 Control Characteristics ............................................................................................................................................ 199
3 h; i1 R$ h/ y* I4 Q11.4 Classification of d.c. links........................................................................................................................................ 2034 Q+ R' s$ y1 a: Y. r* U
INDEX......................................................................................................................................................................................... 205
发表于 2008-9-28 01:48:15 | 显示全部楼层
try this one' a$ W* ]( X, R9 e
8 A  }# h, }3 s. D$ a
[ 本帖最后由 peter 于 2008-9-28 02:07 编辑 ]
High Voltage Engineering (2nd Edition).part1.rar
5 MB, 下载次数: 2, 下载积分: 威望 -2 点, 学分 -5 点
High Voltage Engineering (2nd Edition).part2.rar
High Voltage Engineering (2nd Edition).part3.rar
High Voltage Engineering (2nd Edition).part4.rar
342.42 KB, 下载次数: 2, 下载积分: 威望 -2 点, 学分 -5 点
发表于 2008-10-7 16:07:15 | 显示全部楼层
2楼提供资料是好事,可是分组也太小了,下载花费很多
发表于 2008-10-9 11:34:29 | 显示全部楼层
回复 3楼 sargent 的帖子
I am not in China, so I couldn't upload large files.
2 B. g9 x5 R* ]1 A8 N# ~: ?( u; {# S( E& S9 K! Y
sorry about that.
    2019-11-15 20:29
  • 签到天数: 11 天
    连续签到: 3 天
    累计签到:11 天
    连续签到:3 天
    发表于 2008-10-9 12:26:12 | 显示全部楼层
    不管怎么说还是应该感谢二楼的热心
    2019-11-15 20:29
  • 签到天数: 11 天
    连续签到: 3 天
    累计签到:11 天
    连续签到:3 天
    发表于 2008-10-9 12:32:50 | 显示全部楼层
    我下载合并成一个文件了8 h! d8 W# J  G1 n& J) Z
    : P8 r% |* ?% s/ s- y# y0 Z( Q
    [ 本帖最后由 meng823222 于 2008-10-9 12:38 编辑 ]
    发表于 2015-5-8 23:15:38 | 显示全部楼层
    我下载合并成一个文件了
    ' D+ e9 ^* U$ `: F3 ^) p: J  |1 H2 I4 L. |' R) @
    [ 本帖最后由 meng823222 于 2008-10-9 12:38 编辑 ]3 y$ m" ]* G% w6 e. s6 N. c6 D+ m6 `% S
    meng823222 发表于 2008-10-9 12:32
    , F$ ^3 ?! T' a& P% p
    - K& f- b2 V  N# m太感谢您的工作了!!!!!省了不少钱。。。
    2018-11-17 00:03
  • 签到天数: 23 天
    累计签到:23 天
    发表于 2015-5-15 15:51:40 | 显示全部楼层
    这个是圣经啊
    发表于 2015-8-28 20:46:52 | 显示全部楼层
    高深呀~~~
    GMT+8, 2026-11-14 14:34
