查看: 1958|回复: 1
电力专业基本词汇
    2018-7-18 12:52
  • 签到天数: 6 天
    累计签到:6 天
    发表于 2008-1-22 22:39:13 | 显示全部楼层 |阅读模式
    (1) 元件设备) |+ c6 Q3 s- w
    三绕组变压器:three-column transformer ThrClnTrans. c+ i& X& x9 Y6 N2 K( i4 `/ l: V* N
    双绕组变压器:double-column transformer DblClmnTrans9 m' e. ^' ~$ d9 j6 j9 g" e
    电容器:Capacitor
    0 n5 E1 z/ ^: c; @- ^并联电容器:shunt capacitor
    * }8 j5 x* V3 L  F) M$ n+ R/ U电抗器:Reactor5 X0 j+ ^& W, ~5 C9 a0 [
    母线:Busbar
    % X* Z+ ~$ ]% K( i' d* L输电线:TransmissionLine
    ( _( L" y. R/ y% \) n1 }发电厂:power plant
    + e% v$ x" @) C1 Z6 Y断路器:Breaker
    " Y7 s8 W! u7 v* W) n" Q刀闸(隔离开关):Isolator' I' J& \$ w0 X1 }: v
    分接头:tap
    4 j. g4 N! C: O4 r( M电动机:motor+ k0 T" Q/ S" t2 ^) i
    (2) 状态参数: X- i* q- T7 H0 _) u" a. U4 [, y. Z6 X
    有功:active power& i8 ?5 _2 @$ ]* f5 e
    无功:reactive power
    % M5 y. Q! V8 Q9 U电流:current
      X& T8 z% r% X% W0 M) q容量:capacity
    3 `* ]) c5 O1 `  k( M% U% B! ~电压:voltage
    7 D& K1 ^( }) w% Y档位:tap position
    1 M) P7 m) @- c8 h有功损耗:reactive loss
    9 X0 K4 ]+ l5 c! N无功损耗:active loss! {! Q) l; Z; O* @$ I
    功率因数:power-factor! a/ Q% h4 y7 g" ?  k
    功率:power
    " y- I3 c# V3 V4 g功角:power-angle' j4 y4 t) r" F, W) Z1 j1 k
    电压等级:voltage grade% V  Q# i& z1 Q) s. a& q
    空载损耗:no-load loss: u: j! T/ L5 b# t
    铁损:iron loss% R  N1 A3 S6 {6 k5 j% H! p9 f8 i* |
    铜损:copper loss
    * _/ r$ P! z+ S1 O! z0 f2 w4 M空载电流:no-load current! h# M4 f1 K( @! j6 G
    阻抗:impedance
      t& i0 p* ?0 U8 [) z7 [1 _3 D正序阻抗:positive sequence impedance. V! y# ~% R2 b% b2 N
    负序阻抗:negative sequence impedance9 J4 {$ S4 |. T9 O& f, @
    零序阻抗:zero sequence impedance) U3 Q2 p0 F- C' S
    电阻:resistor9 d" t3 T8 A4 k: d
    电抗:reactance. N& w  ]  l( F9 y8 H/ A4 J( {
    电导:conductance; _4 ?6 a4 ~9 |0 k) \' {- i
    电纳:susceptance' q( ^# \, T. e" d/ X. d
    无功负载:reactive load 或者QLoad. w7 P+ m3 f3 W  u+ L$ j
    有功负载: active load PLoad
    4 [' ^2 \3 K9 f' T遥测:YC(telemetering)0 i# g( O0 C1 d# [
    遥信:YX
    " n6 G6 v* `1 \: d# @+ ]励磁电流(转子电流):magnetizing current+ a0 j  h: m8 j6 h
    定子:stator: P+ ?$ V8 a2 c6 d/ n- n6 {' A
    功角:power-angle
    & J  a  d4 h  J+ r1 G  T& ~上限:upper limit2 c0 @6 E0 ^$ |5 X. q, t  x
    下限:lower limit4 f+ b3 t+ H( Z+ V+ G, F# @2 \; h
    并列的:apposable
    & K5 j. r* ^) ?高压: high voltage3 h( J' ~' c# W2 [! l0 x+ ]" t
    低压:low voltage$ b+ V/ ~& T1 f+ j8 o: }" k
    中压:middle voltage( i( |" U$ o; R
    电力系统 power system% J* R, ^4 E. ]9 R
    发电机 generator- |* \( ~/ \! H0 g% {
    励磁 excitation+ e/ l9 l) Q1 u0 U% K
    励磁器 excitor
      ]3 v% V  Q' T$ [( b) Z4 J电压 voltage0 X" b' U6 r' \2 f. X7 f) G! e
    电流 current0 l' I! Q  N: C# R
    母线 bus
    4 _- o. p4 F  v/ m! i变压器 transformer! `- e) H. W* _, W: `% A& C
    升压变压器 step-up transformer
    9 s2 W4 `& b5 z  P, n$ M7 l% ]高压侧 high side  Z) O9 `: S) Y$ J- ~7 L
    输电系统 power transmission system
    + w& H+ Y' z5 h9 Q2 m- ~8 L3 E# q& g输电线 transmission line. w$ A, l; J% a0 @6 _2 W4 h5 W
    固定串联电容补偿fixed series capacitor compensation) J4 T& l6 s3 l- _" a: E8 b; B
    稳定 stability3 c! C( `( ~- x' X
    电压稳定 voltage stability
    ' ^( j/ e7 \/ z$ w) d  `9 i" I功角稳定 angle stability1 I2 h2 u2 f% ~! F- J6 G( w: z
    暂态稳定 transient stability, v. J+ ?; V0 P" I9 f& @
    电厂 power plant
    # J  u8 ]. E3 Y: Y能量输送 power transfer
    1 o4 D+ K) J% v& s7 A. ^交流 AC
    1 y2 |( g, m$ O装机容量 installed capacity
    7 w3 ~6 Y, x7 C2 l9 c6 i+ o( v0 I电网 power system9 E" t5 b7 y# R" p2 K1 q
    落点 drop point
    # R1 c- `/ S7 V4 [% K0 P开关站 switch station
    " Z7 w( i$ E2 ]; M  v, N双回同杆并架 double-circuit lines on the same tower& m- V3 O, w+ H; x
    变电站 transformer substation0 s& F. v$ E, a0 o& \; @% u4 b
    补偿度 degree of compensation5 [, ?% y2 M# T" w4 z
    高抗 high voltage shunt reactor
    : z4 |' ?- O$ e2 V" [无功补偿 reactive power compensation
    7 ]+ d$ K) o4 {/ N故障 fault
    ) ?8 J# m9 S6 t3 P" R调节 regulation4 H& z# o0 D2 F9 p/ h/ K) s
    裕度 magin
    $ R- a/ v1 i- i  k# a三相故障 three phase fault
    4 Y5 d  E" U3 l, a% m故障切除时间 fault clearing time
    4 {$ g$ R- `! E. Z! F7 S4 a极限切除时间 critical clearing time1 s: A3 Q4 G$ I5 U7 D* Z  |& d' g( H
    切机 generator triping
    ! @4 k# R- ^- |高顶值 high limited value
    , V9 }1 h6 U9 e/ }. Y; D强行励磁 reinforced excitation$ M. z, x" v- J: _6 ]% W
    线路补偿器 LDC(line drop compensation)
    7 B3 G, q0 d# c$ Q+ |! E+ K机端 generator terminal
    2 ?5 X$ x4 \6 D' w静态 static (state)1 G) ^5 x7 m0 I! L1 _. ~: K* B
    动态 dynamic (state)
    - p7 T6 a5 n, M4 f单机无穷大系统 one machine - infinity bus system; `( h( S7 }: n+ ?. \
    机端电压控制 AVR  X( r% u+ H. }: z" v3 s9 E
    电抗 reactance# Z" i( J* u& j$ p' a5 E0 I
    电阻 resistance; S6 g, e  ^0 ]& s; M
    功角 power angle
    ) o& x  n" ^; n5 @! P有功(功率) active power
    2 i) m+ h6 M7 l9 j/ Y+ k无功(功率) reactive power
    , f5 R6 @1 u9 {  ?+ _5 p/ h; X功率因数 power factor
    # y. P$ N; O8 [8 `无功电流 reactive current) n: [$ d  [' P( O8 G. R" {
    下降特性 droop characteristics
    4 B9 j: W: m! o& O2 `9 v- ]4 ^斜率 slope  G7 b/ J# g9 p' C# H
    额定 rating
    4 D1 v+ L. L8 U* W' u* h0 r变比 ratio) J% u' {. H: {* ?
    参考值 reference value! z5 e: ]  \. y2 K% M1 F
    电压互感器 PT$ H# `7 }2 @4 t& B
    分接头 tap
    1 |4 Z2 p8 k, X- l) F& `下降率 droop rate
    # D5 B- @0 M4 t6 v) e仿真分析 simulation analysis
    0 J% [( Y1 [, f1 Q- `% u6 N传递函数 transfer function: H, O8 p% F, ^) p. d
    框图 block diagram% E# L) Y# F0 D; i1 p
    受端 receive-side3 f/ y" f8 x( z2 G6 Y6 R8 Y, B
    裕度 margin4 m+ C" ~0 R9 F/ q1 o
    同步 synchronization
    0 ^& m0 B0 j  b" v失去同步 loss of synchronization& S( Q1 _! y% |) r1 _2 O
    阻尼 damping: F0 L/ ^1 A9 z/ m$ |5 B- n. t
    摇摆 swing
    / K2 O& O, w( ?保护断路器 circuit breaker  }1 T4 R( D/ q8 V5 D
    电阻:resistance5 }9 h7 M" n# d, V" b6 i
    电抗:reactance
      h" t* h. j- Q$ n6 O' v. X/ H8 j阻抗:impedance
    8 A% g2 Y0 j1 I2 `& F+ n6 ^电导:conductance7 l9 c, N$ u1 r. r% G: y3 I5 p  K% |
    电纳:susceptance
    % l; {, X6 |$ Z( s导纳:admittance- c. w5 p9 x$ `3 X
    电感:inductance% a. r. t) s( A, I2 M5 N9 f& n
    电容: capacitance
    2020-9-24 12:04
  • 签到天数: 59 天
    累计签到:72 天
    发表于 2008-1-23 09:40:41 | 显示全部楼层
    坛子里好多了啊。再看看。
    GMT+8, 2026-11-20 10:26
