楼主 |
发表于 2007-12-27 23:39:09
(HIR) - HIGH RESISTANCE OPEN PHASE (HIROP) SCHEME:
I% h5 w D% I1 H0 d$ u, p: X# B1 |- m! G3 U- ]
General Information:8 \1 m) N- H# E
) K. [/ P* \' e( e3 R- q2 x
HIGH RESISTANCE (Ground) and OPEN PHASE (HIROP) protection schemes have been installed on HV transmission lines, 500/230kV Autotransformers, 230/115kV Autotransformers, HV Lines terminating in an Autotransformer, Generator Transformers and Bus Tie Breakers to help detect and clear open circuit and high impedance ground fault conditions.
* u" \% F" N! o% H0 n# u% R2 s
( Q& P2 S$ L) ?$ ~6 [The advantage of HIROP protection scheme is that it can help to detect both the open phase conditions associated with load-carrying broken conductor (or malfunctioning switches/breakers) as well as extremely high impedance faults which may not have been detected by other `conventional' relays. In general, it is intended to improve the selectivity and coordination of power system operations
5 F0 S6 p, D* V3 @# K0 \0 N. }% a, y3 |' v0 c, {* F
Whenever an OPEN PHASE occurs, load current creates an imbalance in the system phases and in the neutral (ground), compared to a PHASE GROUND when fault current creates an imbalance in the system phases and neutral (ground).# p$ ] R( s5 G0 U: Z9 j
5 O% i# B) \' J6 ~) GNote: Only those open circuit or high impedance ground fault conditions in which the necessary minimum pickup current exists will be detected.
+ O7 m. h I$ u+ m
6 d. p1 n4 O& l& [. ~: ePrinciple of Operation:" N( T8 Z5 Z0 f" H2 g a) L
+ M- M# D+ ~0 o1 d! R' k
The protection is designed to detect current imbalance situations and initiate the removal of affected apparatus from service. The Hydro One system configuration is such that the terminals of the element affected by HIROP detectable conditions will be subject to more imbalance current than any other element. Thus, it follows that relays on all terminals set with the same pick-up and time settings would support selective removal of the faulted element. In situations where this selectivity can be compromised (e.g. so much fault current that a difference in relay operating time is virtually non-existent), additional features have been provided to enhance selectivity.& U5 g3 C0 _, c! ~8 A! ~0 C. ?
; D+ T: I+ i' m& U
Actions Upon Loss of HIROP: & [& k( m8 \; T- _! }
( W) G+ B* p4 Q5 NHIROP is normally a duplicated protection (i.e. installed on both `A' and `B' schemes), therefore:
2 L0 E5 l$ l- I& ? q# R- Loss of both HIROP protections would require the immediate removal of the related element from service. (This is necessary in order to prevent uncoordinated operation of other HIROP protections for faults/open phases on the `unprotected' element.)
5 x& K+ P& z- {, N+ u! b- Loss of both permissive tones/channels (where such are used) could result in timed clearance of high impedance in-zone faults; this may involve a second element.
p" K3 D( \ F0 b. A/ L5 T
* `# T& K3 o) }1 fNote: Most 115 kV circuits do NOT have duplicated `A' & `B' protections. Thus, the single 115 kV System HIROP may be considered the duplicate protection.
" ]: K$ t/ o; b2 F; w2 ~7 X0 Z6 Y, L6 z. C, f- g4 z6 A
Sequence of Events / HIROP Components:
9 F! j& ]# h3 N
) W! ^3 b/ ?0 U& R P8 H7 ABasic HIROP consists of:
& ~8 C" P0 x* _
! S6 f# g( G. C1 f" k5 n+ B2 C. ZTimed Trip: an inverse time ground overcurrent relay (51N, 500ms pickup @ 360 a; the greater the current, the faster the operation). This will detect open phase conditions and very high impedance faults on a per element basis provided the imbalance current is >360 amps. This annunciates separately. Inverse Time tripping will trip locally and send transfer trip for 35 s; reclosure is blocked. 1 J" z$ P/ Z @
5 p( Q* @7 o* Q6 t/ m# _4 k
This is due to the fact that the inverse time relay could, for light-current conditions, take longer than 10 seconds to operate, and breaker reclose capability takes only 10 seconds to recover after a breaker is closed (or recloses); thus, the breaker could reclose after being tripped and be closed for 10 seconds before the inverse time protection operated again, which would allow reclosure again after the next trip, etc.
. [7 h- X; E2 f! O: `. q6 N
" h/ X+ @6 N" R8 l! ]! x( yInstantaneous Trip: an instantaneous ground overcurrent relay (50N) is used to detect high impedance ground faults on a per element basis provided the imbalance current is >1000 amps. Instantaneous tripping will trip locally and send communication signals to the remote end, allowing reclosure. / y" x9 D! d' [3 o. i6 Q0 S
9 q; ~' }1 [; q1 Y2 \4 jIn some cases, the level of current could be so high that a number of different relays could all operate with virtually the same speed. To prevent this, HIROP will include a permissive directional ground relay (67N) supervising the instantaneous ground
- S/ f& L6 j6 i0 Dovercurrent relay (50N), operating through a 120 ms timer, as follows:1 R( l5 q9 r) K8 A6 b
' p5 @8 }, M& o B4 G& ?( {% S
(i) If a fault is detected (67N and 50N operate) and the associated timer times-out, permissive signals are sent to the other terminal. If permissive is not received, no tripping occurs. This allows for clearance of out-of- zone HIROP faults via protections associated with the other zones.3 V/ `1 Z- n9 n( e: t! O# i+ a2 a. a9 L
. V+ w+ W& z% v! T9 ?(ii) If a fault is detected and permissive is received, both local and transfer tripping are initiated. # d; g: l8 B0 z) h, ^7 A8 @
7 w9 v8 i2 b* w0 ?! UBus HIROP:
# c0 t2 X9 ~8 D% C; o/ [9 G m3 H8 N6 Y2 V4 G5 F
When the other bus tie breaker is closed, the imbalance is contained within the station buses. HIROP will detect this situation if the current is greater than 360 amps and) }8 Z/ a2 R* R& s
annunciates ONLY.5 G% N) t# k5 [' N( i
& q. [4 f, p( c: B
When the other bus tie breaker is open (or is opened), the imbalance currents could impact on the system (i.e. unwanted protection operations, voltage imbalance, etc); HIROP will detect this situation if the current is greater than 360 amps and will trip the breaker and initiate breaker failure. A similar set-up is used for very short lines (e.g. Bruce `A' X Bruce `B'.)% j7 [& F2 c; C! f1 V4 \( S
4 k$ n* c0 }8 T _# E. m' ^9 y6 ~. O
Notes: While Bus HIROP could detect open phase conditions anywhere on a ring bus, the likelihood of such a condition occurring on a bus is minimal. Terminal In bus
* t. Q7 N) N* }. @5 _( d(circuit or transformer) breakers are the most likely location for an open condition to occur. Circuit or transformer HIROP protects the respective circuit terminal and transformer breakers/buses and both are coordinated to operate for in-zone HIROP conditions before Bus HIROP. The operation of Bus HIROP by itself indicates an open phase on either the bus tie breakers or those portions of the bus not contained within the circuit or transformer zones (i.e. the main buses).% S9 v4 h3 I) [' O/ {
1 ]9 a9 E9 H6 [. T, F( ?6 S
Bus or Line-Connected Autotransformers HIROP:
% z4 g! E$ U4 v
9 D5 n- J/ C* L9 dHIROP protection will detect on-load open phase conditions. Conventional differential protections take care of internal high impedance faults.
( _& z( ?3 ~7 k
) i* P, K# I& ?$ F2 [. x1 `! u115 kV Circuits:! l) u! A! O: G; F
9 N9 G* f, o. \' O# C+ d0 Q
Most 115 kV circuits have a low-set ground overcurrent protection that will clear most open phase or high impedance ground faults. Thus, they will not be provided with HIROP. (Note: Some critical 115 kV systems do have duplicated HIROP, e.g., Leaside, Buchanan and will be noted in the “Key Info” field.+ S6 M1 J4 Z9 [ O5 O4 C
- ?0 |+ N0 m2 a6 f) P7 i" A9 c( `$ VIn such cases, in order to provide coordinated backup protection for 115 kV systems (much of which does not have duplicated line protection groups) a 115 kV system `group' HIROP protection will be provided with CT’s connected at the secondary of the autotransformer. This timed residual ground relay will provide the backup protection by tripping all autotransformer LV breakers.0 B1 t% b9 J/ E U% h
- s' k9 l, S7 x) R- N- P
HIROP Operating Considerations:
1 _) p" f$ q8 o; x, ~2 J$ ^" l: e- k* l% ]) |
Some directional comparison schemes will have their timed (.4 s) feature removed since this could operate faster than HIROP's inverse timed (500ms) feature. This means that the only tripping from conventional directional comparison schemes will be in the instantaneous mode (when the block signal has not been received).
! z, C. @$ t: j2 P
7 D; `3 E# Y; @( Z4 g+ W! H u- t6 xBACKGROUND:$ z" s2 w. ^5 O$ M7 f, P
/ l( H" {9 l! t, U" `! `' EHigh voltage protection on Hydro One lines are presented in a form of protection groups made up of individual schemes, this above scheme is one that is part of the protection group listed for this element. 6 l" n: p! t+ K# O3 u3 x7 t) M6 G
4 F" e" |: ]- D1 F1 H- I A0 F, ]Both open phase and high resistance grounds produce zero sequence currents manifested as ground or neutral currents. They circulate in the power system and are distributed across all system elements in inverse proportion to their sequence impedance. The affected element carries most of the zero sequence current since it is the “source” of this current. Therefore, inverse time overcurrent based protection in the neutral, set with the same pick up current and time characteristics for all power system elements, provides selective isolation of the affected system element.. f0 }$ g$ _* R% T- n
$ O5 |* w& G" @; k% I* iIdentical inverse time characteristics for all HIROP protection ensures that the faulted element is cleared first since it carries higher zero sequence current than adjacent (non-faulted_ elements. Existing transfer trip facilities are used for fast clearing of the remote end of the faulted element. * J# Q- {4 h, a* M* Z& ^
+ g8 ^& w. |1 r* r4 Z
To further ensure proper coordination, sufficient margin has been incorporated in the settings, minor variations have been introduced in the nominal pick-up setting of the overcurrent relay (set for 360A primary in the neutral) and instantaneous and directional protections have been employed where appropriate.& }0 w* O* ]- u+ c+ f% W4 l
$ e& T" H! Y+ H1 \0 n0 v% ~
Existing (or lack of) open phase and ground fault protections may not detect the above abnormal conditions. The wide implementation has raised some questions whose answers may have implication for system operations in the following areas.+ m5 E: N7 |8 |+ z& f8 B$ x' x. z* [
: N* z1 {3 S; J. b
Standard high voltage protection provides high speed tripping at the local and remote line terminals from Zone 1 directly and from Zone 2 via permissive over-reaching or directional comparison, using communication media. Timed and Line Test tripping involve the local terminal only. Reclosing is only provided from the high-speed protection. |
