查看: 1412|回复: 1
ATPDraw运行时出错:Disconnected subnetwork
发表于 2013-5-28 10:38:28 | 显示全部楼层 |阅读模式
ATPDraw运行时的error. log 如下:
) a6 ?7 Q$ {* z: y( }' H* q1 H% T
. [# E$ F# N$ e& Z# U9 [! I3 \
+++///  Caution.  Disconnected subnetwork.  During the Y-matrix elimination for phasor voltages, a near-zero diagonal element8 u8 N  w) G) E
                 for node  "XX0013"  exists just prior to reciprocation.    Statistics follow:  Original ABS(Ykk) = 0.00000000E+00,+ v+ w7 ?2 l$ D3 u% R& a8 t
                 questionable value = 0.00000000E+00,   tolerance ratio  TOLMAT = 1.00000000E-08  .    The node in question might be
& V1 j5 L$ K6 N  m                 connected to other nodes, forming a subnetwork, but that subnetwork has no, or only very weak, paths to ground or
* z, M5 T) r) b  S  O                 to any other known voltage node of the steady-state network.   The solution voltages for this isolated subnetwork
8 h- `- w# s) e3 s                 will now be set to zero, as the solution continues.. r' l/ L2 V9 n) o8 F
+++///  Caution.  Disconnected subnetwork.  During the Y-matrix elimination for phasor voltages, a near-zero diagonal element  L) x4 u. [/ x3 ~! Y# G
                 for node  "XX0003"  exists just prior to reciprocation.    Statistics follow:  Original ABS(Ykk) = 0.00000000E+00,
5 ?; P- X) Y) e9 n                 questionable value = 0.00000000E+00,   tolerance ratio  TOLMAT = 1.00000000E-08  .    The node in question might be
3 u8 T8 J# G! @9 f0 W                 connected to other nodes, forming a subnetwork, but that subnetwork has no, or only very weak, paths to ground or
2 ~; N1 F( t) F; j) }. ~                 to any other known voltage node of the steady-state network.   The solution voltages for this isolated subnetwork( U. ^) m: `/ F
9 A9 L$ `$ L3 ^) |! g' }4 \% X7 ]7 i( M1 [+ M7 I% h- [) a6 f
& W; x9 v2 \* Q! Y+ E7 p: D1 V( }$ s, `6 N# L9 L
有没有高手遇见过这样的问题呀 这里我仿真的是电弧模型
 楼主| 发表于 2013-5-30 09:43:24 | 显示全部楼层
这个问题迟迟没有得到解决啊  有没有遇见过的啊 指点一下下巴
GMT+8, 2026-11-19 06:39
