ATPDraw 运行时老出现这个是怎么解决的啊 +++/// Caution. Disconnected subnetwork. During the Y-matrix elimination for phasor voltages, a near-zero diagonal element for node "XX0014" exists just prior to reciprocation. Statistics follow: Original ABS(Ykk) = 0.00000000E+00,
: N2 a0 x# z2 R+ S0 q questionable value = 0.00000000E+00, tolerance ratio TOLMAT = 1.00000000E-08 . The node in question might be! t1 _, L" q6 W: Z. v! @) \4 p
connected to other nodes, forming a subnetwork, but that subnetwork has no, or only very weak, paths to ground or
, I/ ~ S( n! r& ^ to any other known voltage node of the steady-state network. The solution voltages for this isolated subnetwork7 C6 ], x% q( n' P3 c$ E+ V
will now be set to zero, as the solution continues.1 C# z* m: f& B8 ^: ?" ~7 I
4 s; G( x& V1 A N for node "XX0004" exists just prior to reciprocation. Statistics follow: Original ABS(Ykk) = 0.00000000E+00,1 L. v! S8 W! S! {4 s" F) A
questionable value = 0.00000000E+00, tolerance ratio TOLMAT = 1.00000000E-08 . The node in question might be6 K5 U* A V3 {
8 g8 F1 t4 N" ~5 I4 R/ i to any other known voltage node of the steady-state network. The solution voltages for this isolated subnetwork( d* T2 l% P5 ^) p
will now be set to zero, as the solution continues. |
