查看: 1296|回复: 2
Design_of_Direct-driven_Permanent-magnet_Generators
    2019-12-22 22:50
  • 签到天数: 11 天
    累计签到:172 天
    发表于 2010-6-24 01:44:01 | 显示全部楼层 |阅读模式
    电子图书
    电子图书名: Design_of_Direct-driven_Permanent-magnet_Generators
    编者: Göteborg, Sweden.
    所属专业方向: 电机
    内容简介: This thesis presents an investigation of how a direct-driven wind turbine
    generator should be designed and how small and efficient such a
    generator will be. Advantages and disadvantages of various types of
    direct-driven wind turbine generators are discussed, and a radial-flux
    permanent-magnet generator connected to a forced-commutated rectifier
    is chosen for a detailed theoretical investigation. Further, a design
    method is developed for the electromagnetic part of the chosen generator
    type. The generator is optimized with a simplified cost function which,
    besides including the cost of the active generator parts and the cost of the
    structure, also includes the cost of the average losses. Therefore, a method
    to calculate the average losses is derived. The design method is used to
    investigate the optimization of a 500 kW generator, and the size, efficiency
    and active weight of optimized generators from 30 kW to 3 MW are
    presented. A result of the investigation is that the outer diameters of the
    direct-driven generators are only slightly larger than the width of
    conventional wind energy converter nacelles. A comparison of average
    efficiency shows that direct-driven generators, including the losses in the
    frequency converters, are more efficient than conventional wind energy
    converter drive trains. Compared with other direct-driven generators, the
    proposed generator type is small, mainly because of the forced-
    commutated rectifier and because the generator is not required to produce
    a pull-out torque higher than the rated torque.
    出版社: Department of Electric Power Engineering
    来源: 网络
    Table of Contents. F" c# O& e3 F9 t( Z7 Y# {
    Abstract 3% {5 z/ h# _5 g  i8 H- o6 |6 N
    Preface 3
    / j% l+ V! ?0 \. CTable of Contents 4
    # A7 C9 z: j3 vList of Symbols 6
    + |8 ^/ Z2 e( p- {1 Introduction 11+ @" |, r2 [% I& R  t
    1.1 Why Use Direct-driven Wind-turbine Generators 113 G/ M- U3 I% a7 E4 l; C5 A
    1.2 Differences Compared with Conventional Generators 12( `& u+ C6 n, C1 k- c
    1.3 Proposed Generator Types 121 A% x6 ?- S  ?% B
    1.3.1 Sector Induction Generator 121 ~, r. p  n9 v; N0 w: T
    1.3.2 Electrically Excited Synchronous Generator 13) M, L; C$ V" O+ ]
    1.3.3 Switched Reluctance Generator 14
    # E- o/ v  ~& y+ C2 ?  w1.3.4 Permanent-magnet Radial-flux Synchronous Generator 14. c* S4 ]5 y) f: u; m
    1.3.5 Axial-flux Generators 16+ h" i0 |( e1 r- t
    1.3.6 Transversal-flux Variable-speed Generator 17
    3 D7 o$ \* l; e1 j1.4 Discussion of Earlier Research 19
    + f* d- P5 a  Y, N8 t1.5 Goal and Outline of the Thesis 19
    % c" a* S, m" V* @2 Generator Specification and Cost Function 21! `8 l$ H1 @, i  j/ D$ b; U
    2.1 Specification 219 v% A  Q2 _4 h7 L" w& a5 M' G
    2.2 Generator Cost Function 235 o- m0 K) C4 S7 O
    2.2.1 Cost of Active Parts 24
    3 B' u2 c/ k2 i0 z+ h7 B" s2.2.2 Cost of Structure 24
    5 m4 N4 N$ I: E; D  Q2.2.3 Cost of Average Losses 24( o3 g6 i1 Q8 P% Z
    2.2.4 Total Cost Function 26
    % z+ w# T0 ^( Y1 S5 h, x3 Calculation Method for the Average Losses 27& y$ o1 w3 W5 |9 W! F
    3.1 Average Losses 27/ e0 |9 f; D$ V# L2 {) p
    3.2 Average Efficiency and Average Power 29
    $ n5 s: m+ _$ b8 k" z# I% c4 j3.3 Determining Average Loss Factors 302 y% ^, A, |  d. ^$ U
    4 Generator Types 37
    7 k" k! _% @1 v, x1 d& m$ l4.1 Electrical Excitation or Permanent Magnets 37
    ; C" ]) Q; X+ c7 L% W8 u4.2 Direct Grid Connection or Frequency Converter 39- B  a  H/ e- E3 X0 O
    4.3 Surface Magnets or Flux Concentration 40
    - w. _, s5 s; l$ W4.4 Slot Winding or Air Gap Winding 41
    6 R3 ]8 E- ~/ D6 \- a: J& d4.5 Radial-, Axial- and Transversal-flux Machines 42
    0 ~7 x+ a- l7 r$ h& x9 \7 N4.6 Forced-commutated Rectifier or Diode Rectifier 44+ l6 @! X/ I" Q
    4.6.1 Generator Model 45
    . @9 x0 N' l: [* k, @1 d( r4.6.2 Diode Rectifier 450 s5 u: Z$ S) Y) n( \% J7 R! O7 U& n: }
    4.6.3 Forced-commutated Rectifier 46
    . k! h) L1 U5 p% k6 K1 Q( L& Q5 k4.6.4 Rectifier Comparison 48
    " F2 l# o; y# w" a; d4.7 Chosen Generator Type 51+ K0 a- d1 u2 k# l6 ?5 S
    4.7.1 Basic Generator Concept 51
    ; l) i6 P# [1 H0 e/ F. S. m4.7.2 Details of the Chosen Generator 51
    5 b( j! G' {3 s. k. l! B: x4.7.3 Materials 52
    # f% s0 ^( P! b" K& {) x5 Design Method for a Permanent-magnet Generator 55
    + u# s% c& P9 ?# c2 ?1 m" ^: R! H, V5.1 Design Variables 557 e! v: q$ a* g2 z# s+ `
    5.2 Design Equations 58! [0 n6 Z  F; Y7 U: v" c
    5.2.1 General Definitions 58
    " p! Z. B: O& j5.2.2 Magnetic Circuit 60
    & k& j8 [4 _$ }0 E5.2.3 Stator Inductance and Resistance 61
    ' w  l3 ]) ?2 r2 `5.2.4 Material Volume and Weight 63
    1 l5 s* {, Z3 y, m( j) S5.2.5 Losses 64, e& I5 x6 k: ]3 O, N
    5.2.6 Voltage, Power and Efficiency 67" y/ k. e( d* t: F, d
    5.2.7 Thermal Model and Temperature Rise 68* U1 i6 F: A( P
    5.2.8 Irreversible Demagnetization 69) q2 X; c4 c, c+ X+ r: H- B
    5.3 Calculation Procedure 719 N9 l8 e5 u2 d2 V
    5.4 Test of the Design Method 72
      H' e2 H( R& p% z$ V0 ^( i, i7 s5.4.1 Comparison with Finite Element Calculations 72
    # o4 o' L4 ^$ i- @- o4 D8 b5.4.2 Test of Thermal Model 73
    1 y2 w, `+ y5 q5 n- J6 Generator Optimization 77/ I0 ]) G- e2 T$ H
    6.1 Optimum 500 kW Generators 77
    ) T5 _6 f) h0 v2 N" Q6.1.1 Optimized Reference Generator 77
    * ]0 a8 i# D: R$ L6.1.2 Optimized Generators for 50 Hz and 200 % Peak Power 80$ b! T; C, @! S6 c: q7 b6 [4 u
    6.1.3 Optimization Using the Losses at Rated Load 82
    + }" ~# U( V2 O7 e: T0 W6.2 Sensitivity to Variable Changes 84
    % A* \  g1 U+ T$ e6.3 Sensitivity to Cost Function Changes 86; `( P( k" Y8 S7 i! l5 L* k
    6.3.1 Cost of Losses 86
    ' E/ \6 o: [+ b8 ]6.3.2 Cost of Iron and Copper 87* ]. @& x8 c; _* I/ E4 v- s; B
    6.3.3 Cost of Permanent Magnets 88" d4 F- a4 d0 p9 ^* K) I& M
    6.3.4 Cost of the Structure 89- k$ ~8 h8 o* H. y2 \( X
    6.4 Optimum Generator Diameter 90; `" m" ?6 M2 ?# H
    6.5 Typical 500 kW Permanent-magnet Generator 929 h1 o. q% q" P5 Y9 Y3 r
    7 Design and Comparison 95
    % f$ W' G4 U, m6 Y7.1 Generators from 30 kW to 3 MW 95
    " p( ^# n! ]9 I- t: P# r7.1.1 Generator Data 95; o/ f# V) V- _: r7 ?
    7.1.2 Optimum Variables and Parameter Values 97
    - ~9 `: D0 u( H0 s1 f7.1.3 Power Limits For the Direct-driven Generators 100* P9 R+ }5 }$ A: h7 `) _4 W: N; _0 V
    7.2 Comparisons 102
    ; ?- M0 ], \- @9 J; o: o7.2.1 Comparison with Conventional Generators and Gears 102
    ) A- f3 O$ e- X. }7.2.2 Comparison with Other Direct-driven Generators 104
    1 a* @4 k3 W5 C' m8 Conclusions 107" ~+ B/ G6 e  Y( C. {* U
    8.1 Different Generator Types 1075 g2 l; Q3 z/ M1 U
    8.2 Generator Design and Optimization 108
    3 V4 J# G; ]' _8 c8.3 Designed Generators and Comparison with Other Generators 108( n* N: i* ~2 Z* }8 p
    8.4 Further Work 109
      p! ]; _* ]& g! Q# O; hReferences 111
    " D3 q. P* p( a7 e" s; |' ~Appendix A   Magnetizing Inductance 1152 r0 x5 M" ~/ ?. ^3 N
    Appendix B  Thermal Model of the Generator 119
    9 O* ^0 I4 n6 J6 L( @9 sAppendix C   Average Efficiencies 131
    Design_of_Direct-driven_Permanent-magnet_Generators.rar
    464.56 KB, 下载次数: 13, 下载积分: 威望 -2 点, 学分 -5 点
    发表于 2010-7-12 22:03:31 | 显示全部楼层
    这篇论文还是不错的,谢谢
    发表于 2011-1-11 15:04:52 | 显示全部楼层
    如何提高积分
    GMT+8, 2026-11-18 08:58
