查看: 1038|回复: 0
Design_of_Direct-driven_Permanent-magnet_Generators
    2019-12-22 22:50
  • 签到天数: 11 天
    累计签到:172 天
    发表于 2010-6-23 19:59:59 | 显示全部楼层 |阅读模式
    电子图书
    电子图书名: Design_of_Direct-driven_Permanent-magnet_Generators
    编者: Göteborg, Sweden.
    所属专业方向: 电机
    内容简介: This thesis presents an investigation of how a direct-driven wind turbine
    generator should be designed and how small and efficient such a
    generator will be. Advantages and disadvantages of various types of
    direct-driven wind turbine generators are discussed, and a radial-flux
    permanent-magnet generator connected to a forced-commutated rectifier
    is chosen for a detailed theoretical investigation. Further, a design
    method is developed for the electromagnetic part of the chosen generator
    type. The generator is optimized with a simplified cost function which,
    besides including the cost of the active generator parts and the cost of the
    structure, also includes the cost of the average losses. Therefore, a method
    to calculate the average losses is derived. The design method is used to
    investigate the optimization of a 500 kW generator, and the size, efficiency
    and active weight of optimized generators from 30 kW to 3 MW are
    presented. A result of the investigation is that the outer diameters of the
    direct-driven generators are only slightly larger than the width of
    conventional wind energy converter nacelles. A comparison of average
    efficiency shows that direct-driven generators, including the losses in the
    frequency converters, are more efficient than conventional wind energy
    converter drive trains. Compared with other direct-driven generators, the
    proposed generator type is small, mainly because of the forced-
    commutated rectifier and because the generator is not required to produce
    a pull-out torque higher than the rated torque.
    出版社: Department of Electric Power Engineering
    来源: 网络
    本帖最后由 amfk2006 于 2010-6-23 20:01 编辑 3 s. D2 m6 u1 R+ b) X  r. R3 R
    4 C/ M2 M7 C3 w5 |" E9 e
    Table of Contents, s# M( h1 F' w6 f% _+ z  [" I6 w
    Abstract 3' q4 R5 n; U) ]! A5 f
    Preface 3
    ' m( f" r- c. C- R1 [Table of Contents 4
      x4 v2 K) }) o7 }  dList of Symbols 6( @9 E" A. |1 y" u
    1 Introduction 111 G/ W$ i/ K: x( D
    1.1 Why Use Direct-driven Wind-turbine Generators 11
    3 B5 @/ ^8 R3 e* O* a& l1.2 Differences Compared with Conventional Generators 12
    ( d$ U0 c1 W6 L& G3 v3 y3 N1.3 Proposed Generator Types 12
    ; ], T- }( e3 Y$ |1.3.1 Sector Induction Generator 12
    * Y: Z) Z. C1 h& D  G$ e1.3.2 Electrically Excited Synchronous Generator 13
    1 A6 @7 q3 R9 C0 O7 f1.3.3 Switched Reluctance Generator 14
    9 _! L& e' x5 X+ s  i; Y/ K/ q1.3.4 Permanent-magnet Radial-flux Synchronous Generator 143 {: Z6 M. v4 ^+ G6 d9 d- \2 P
    1.3.5 Axial-flux Generators 16! K* o) a, E) a
    1.3.6 Transversal-flux Variable-speed Generator 176 J$ a# b8 S# Q( ?6 _
    1.4 Discussion of Earlier Research 19
    ; T- g" Q2 g) {8 X6 E. h7 O1.5 Goal and Outline of the Thesis 19
    8 n+ ]/ Q: ^; \; v( K2 Generator Specification and Cost Function 21% x' c. _1 Q8 ^7 v4 ~- ]
    2.1 Specification 21
    ( V* w. y1 ~, z5 @/ C+ ]8 Q2.2 Generator Cost Function 23
    : n  k  j6 l5 d: v; k9 N2.2.1 Cost of Active Parts 24  j3 W3 t) Y" m4 X3 l  m
    2.2.2 Cost of Structure 24- ?% f% d- P* f' N6 r, F! ~" I4 ?( ]
    2.2.3 Cost of Average Losses 24
    # T4 J$ t7 a7 ]6 O# F2.2.4 Total Cost Function 264 }, L, u* T, T& l& p  q/ k
    3 Calculation Method for the Average Losses 278 Y) H' |8 l: H: M0 X
    3.1 Average Losses 277 V% |. T1 U+ g% t. u+ u  I
    3.2 Average Efficiency and Average Power 299 `8 w% L5 x' i1 Y  ^% E
    3.3 Determining Average Loss Factors 30
    4 m+ A7 p; U; {6 O$ S+ [4 Generator Types 37: w( B8 r% x2 T$ w" v8 X2 u" k% d
    4.1 Electrical Excitation or Permanent Magnets 371 j: }; H7 c- Y& A9 ~2 [7 i
    4.2 Direct Grid Connection or Frequency Converter 39
    ! ~4 B) k4 {* Z4.3 Surface Magnets or Flux Concentration 40
    4 h$ Z' [2 D* b" @0 b2 p4.4 Slot Winding or Air Gap Winding 41, Q! N5 s/ m4 U: c. l6 x; Z  O* z
    4.5 Radial-, Axial- and Transversal-flux Machines 42
    : o. y) J2 p6 n8 @" S% I4.6 Forced-commutated Rectifier or Diode Rectifier 44
    6 {1 x6 L0 [; }1 |5 ^8 E1 @4.6.1 Generator Model 451 r3 X; x; |$ d/ r  O1 V4 R$ T
    4.6.2 Diode Rectifier 45
    , Y8 {) x2 j5 ^- Y( a! l8 {3 s4.6.3 Forced-commutated Rectifier 46
    8 ?3 _" B2 E7 l% f& q4 E- @2 t4.6.4 Rectifier Comparison 486 \  |% U( F0 ~5 x. {* \6 I
    4.7 Chosen Generator Type 51
    0 _0 ]9 R" z) @! T/ R4.7.1 Basic Generator Concept 51+ [  y6 ]+ w3 V- |/ B
    4.7.2 Details of the Chosen Generator 51
    7 [$ J0 y3 e" m4.7.3 Materials 52
    : g  d: B" }# z. O5 Design Method for a Permanent-magnet Generator 55
    ) ~5 f6 n# |# |  M5.1 Design Variables 551 p/ V8 R' P& E, n2 l6 g( n( ]
    5.2 Design Equations 58# y) @9 V7 o5 f4 s5 P. Q
    5.2.1 General Definitions 580 Z. g* n/ X& y' K7 ?; I
    5.2.2 Magnetic Circuit 603 P: o- r) h1 i
    5.2.3 Stator Inductance and Resistance 610 [, }2 t+ l( j' d6 l
    5.2.4 Material Volume and Weight 63! k. Q" M3 s, d6 ]$ i
    5.2.5 Losses 64. o0 H1 s; ^3 x, X& r% n
    5.2.6 Voltage, Power and Efficiency 67) i; _" ?# L- C- A
    5.2.7 Thermal Model and Temperature Rise 68' [3 L5 R6 x6 F- |
    5.2.8 Irreversible Demagnetization 69
    ' U- Q+ G$ w7 k# a$ F; b5.3 Calculation Procedure 71& {- T- h" g2 @8 ?7 ^
    5.4 Test of the Design Method 72
    ! J* e! |/ b7 A* q8 d. s5.4.1 Comparison with Finite Element Calculations 72! S% i. @4 C6 P' u2 r# I( N
    5.4.2 Test of Thermal Model 73
    7 \; f4 l' o( D* M% x1 ^: i7 h* Z! Z6 Generator Optimization 77' S5 d4 {! U9 E2 w- P
    6.1 Optimum 500 kW Generators 77" F% \) S- l: V9 ?1 A5 t$ z5 }
    6.1.1 Optimized Reference Generator 77; @4 a- m2 b: ?6 a( z7 i& S
    6.1.2 Optimized Generators for 50 Hz and 200 % Peak Power 806 T9 o" T/ m* u4 E: s
    6.1.3 Optimization Using the Losses at Rated Load 82& f9 P. [4 ~- O
    6.2 Sensitivity to Variable Changes 84
    : L% `2 y) w; \2 @, V8 |) h6.3 Sensitivity to Cost Function Changes 86
    # k# z: c. f6 C7 B7 ]* S2 P6.3.1 Cost of Losses 860 y0 _& V0 o1 Y$ A: I1 [
    6.3.2 Cost of Iron and Copper 872 B* C5 O/ f. Y' ^' u* y% P# C
    6.3.3 Cost of Permanent Magnets 88
    & B! C6 u3 J# |. _( k6.3.4 Cost of the Structure 89' f! ^& l  N' x2 _0 r* H, ^
    6.4 Optimum Generator Diameter 90+ Q4 x' r. u+ B
    6.5 Typical 500 kW Permanent-magnet Generator 92# |$ x! P) F4 B
    7 Design and Comparison 95' E3 P9 ~4 F# g
    7.1 Generators from 30 kW to 3 MW 95$ C1 {4 C5 R0 N* z
    7.1.1 Generator Data 95* y4 T- q1 L6 L
    7.1.2 Optimum Variables and Parameter Values 97
    : T7 q9 K: M  k4 `3 P( P$ X1 x  l7.1.3 Power Limits For the Direct-driven Generators 1009 x4 Q3 s3 n6 x- p- B
    7.2 Comparisons 102
    & G" b# ?; E& j$ r; l. s7.2.1 Comparison with Conventional Generators and Gears 102# |) c( L. L5 o* w
    7.2.2 Comparison with Other Direct-driven Generators 104- S/ N/ Q  P. s" \, j( l
    8 Conclusions 107
    6 m+ H. K2 a3 @1 c' S& x8.1 Different Generator Types 107
    ! V' R( K9 a$ `' \8.2 Generator Design and Optimization 108/ P  c1 N: F: m+ N5 M2 Z) D
    8.3 Designed Generators and Comparison with Other Generators 108; n2 `. f. h! Q
    8.4 Further Work 109, \# W: P* `9 v% L  _
    References 111
    3 g; q  T9 Q1 Y6 z1 A" t4 t/ QAppendix A   Magnetizing Inductance 115  e5 g3 c: \6 P) f& g$ `
    Appendix B  Thermal Model of the Generator 1197 y9 h8 @1 H& D  `
    Appendix C   Average Efficiencies 131
    Design_of_Direct-driven_Permanent-magnet_Generators.rar
    464.56 KB, 下载次数: 4, 下载积分: 威望 -2 点, 学分 -5 点
    GMT+8, 2026-10-30 13:40
