楼主 |
发表于 2010-4-21 21:04:42
回复 4# 大笨蛋 " Y* V' x: J# V# ^4 e
2 ^" J4 D6 T* H, h1 Q
是不是从生成的lis文件中查找?
! ]2 P4 j. Q2 W. u8 @Alternative Transients Program (ATP), GNU Linux or DOS. All rights reserved by Can/Am user group of Portland, Oregon, USA.& e9 Z! V, n2 K2 S, P
Date (dd-mth-yy) and time of day (hh.mm.ss) = 13-Apr-10 16:56:55 Name of disk plot file is lin750_4.pl4& n( R6 \6 B7 o: r9 x/ a! r6 W. r
Consult the 860-page ATP Rule Book of the Can/Am EMTP User Group in Portland, Oregon, USA. Source code date is 21 February 2003.' b6 g B2 W% z3 H
Total size of LABCOM tables = 9868232 INTEGER words. VARDIM List Sizes follow : 6002 10K 192K 900 420K 1200
4 v4 v9 z. f/ ?6 k2 | 15K 120K 2250 3800 720 1200 72800 510 90K 800 90 254 120K 100K 3K 15K 192K 120 30K 160K 600 210K 300 60" q8 W- ]( t/ A E! f: `
--------------------------------------------------+--------------------------------------------------------------------------------& D2 n& i- }5 _
Descriptive interpretation of input data cards. | Input data card images are shown below, all 80 columns, character by character
- O- z0 f/ S; Z* w5 [% ? 0 1 2 3 4 5 6 7 8+ G0 s U4 m/ T7 g, L8 V2 ?( a E
012345678901234567890123456789012345678901234567890123456789012345678901234567890
# g. _- w8 [$ U% Q4 B2 Q% k--------------------------------------------------+--------------------------------------------------------------------------------) m/ h( M+ a1 n7 x) H
Comment card. KOMPAR > 0. |C data:LIN750_4.ATP: @: i! d2 O1 b1 I9 n8 r
Marker card preceding new EMTP data case. |BEGIN NEW DATA CASE, |! V5 M* r% {4 U" @% ]3 K. p5 c
Jose Marti`s line fitter. PDT0 = 0.00000000E+00 |JMARTI SETUP3 U5 O. u. R4 _- _ z1 W( I6 Q; w+ e
Erase all of 0 cards in the punch buffer. |$ERASE
5 l* E! `8 l" A. H! B$ x3 @Pairs of A6 terminal node names for each phase. |BRANCH IN___AOUT__AIN___BOUT__BIN___COUT__C
* E9 H/ P9 s( q# v* `Compute overhead line constants. Limit = 120 |LINE CONSTANTS
/ m( k! F! h$ B7 L/ QRequest for metric (not English) units. |METRIC
6 O/ x) a& N3 a; [Line conductor card. 2.590E-01 6.900E-02 4 | 10.259 0.069 4 2.9 -19.5 25.1 10.1 60. 45. 4
( i& F7 W1 d+ @Line conductor card. 2.590E-01 6.900E-02 4 | 20.259 0.069 4 2.9 0.0 25.1 10.1 60. 45. 4
3 D( L- k' J. B( Z _' rLine conductor card. 2.590E-01 6.900E-02 4 | 30.259 0.069 4 2.9 19.5 25.1 10.1 60. 45. 4& ]4 y2 N [/ C
Line conductor card. 1.750E-01 4.400E-01 4 | 00.175 0.44 4 1.54 -15. 39.7 24.7 0.0 0.0 05 n3 ^7 ^! n, V, Z- b3 h
Line conductor card. 1.750E-01 4.400E-01 4 | 00.175 0.44 4 1.54 15. 39.7 24.7 0.0 0.0 0
% k$ F t4 X4 o) x- m+ kBlank card terminating conductor cards. |BLANK CARD ENDING CONDUCTOR CARDS
' X& `! ^! z K+ p" l+ L+ {Frequency card. 2.000E+01 1.000E+03 7.570E+01 | 20. 1.E3 75.7 1; H% \$ [( ^& e% _# r8 W
8 {6 W, e$ X3 s/ i: k
Line conductor table after sorting and initial processing.3 t6 s3 R, H; _ t
Table Phase Skin effect Resistance Reactance data specification Diameter Horizontal Avg height: D1 s2 V0 o! S$ x1 S
Row Number R-type R (ohm/km) X-type X(ohm/km) or GMR ( cm ) X (mtrs) Y (mtrs) Name: Q+ m$ M. _! C; V
1 1 .25900 .06900 4 .000000 2.90000 -19.200 14.800
) U- g! s% ~! T 2 2 .25900 .06900 4 .000000 2.90000 0.300 14.800
& m/ l5 ]0 Z: @1 P) b: W. C r 3 3 .25900 .06900 4 .000000 2.90000 19.800 14.800
( }0 y! M1 Q0 `2 r% B! M% _0 F 4 1 .25900 .06900 4 .000000 2.90000 -19.800 14.800
: o- h7 _$ R, ^7 O2 \ 5 1 .25900 .06900 4 .000000 2.90000 -19.800 15.400
" _8 n9 h4 n" A, p1 Z3 U 6 1 .25900 .06900 4 .000000 2.90000 -19.200 15.400$ p8 V! J6 D" `& o# j0 N
7 2 .25900 .06900 4 .000000 2.90000 -0.300 14.800
# f/ Q; Y/ L! r 8 2 .25900 .06900 4 .000000 2.90000 -0.300 15.400
. d( d8 G1 x8 z+ E5 f" w 9 2 .25900 .06900 4 .000000 2.90000 0.300 15.400
7 j& n0 ^3 e- m+ o1 ]% U: N( v 10 3 .25900 .06900 4 .000000 2.90000 19.200 14.800
8 O- P3 |9 M# k4 B) o( o 11 3 .25900 .06900 4 .000000 2.90000 19.200 15.400
: X. k: Q' W4 r* q 12 3 .25900 .06900 4 .000000 2.90000 19.800 15.4006 n7 `2 N6 L. w8 f7 u* r. ?) Z o
13 0 .17500 .44000 4 .000000 1.54000 -15.000 29.700
: Y0 ] j8 j+ E/ _# T4 n 14 0 .17500 .44000 4 .000000 1.54000 15.000 29.700
1 T2 u* J% Q' a7 ` 6 O8 L6 n7 ~4 z4 k0 ]
Matrices are for earth resistivity = 2.00000000E+01 ohm-meters and frequency 1.00000000E+03 Hz. Correction factor =9 b4 K4 M8 B' k u$ K% j
1.00000000E-06
1 v+ c# Z8 H" n1 k$ @2 z0 i- R 7 n1 A2 \1 n3 L: B. B3 c! T% _& \% g
Modal parameters at frequency FREQ = 1.00000000E+03 Hz* d' Y! o# E% z9 L
* [0 N& k2 q' [* T6 }* [& Z; f3 d
Eigenvector matrix [Ti] for current transformation: I-phase = [Ti]*I-mode. First the real part, row by row:& X% Q! q1 o: [" I: O
5.748140047158274E-01-7.071067811865638E-01-4.281225696572995E-01/ l- ^- F! z7 V9 v2 B
5.823896633398591E-01 1.700454252111332E-14 7.958782134849792E-01
) c" ?: R4 C# F& m; ?/ i3 z) R; D 5.748140047158198E-01 7.071067811865313E-01-4.281225696573222E-01 o2 R% I+ \/ v$ o1 b% m: c' k
Finally, the imaginary part, row by row:
$ R- Z( [$ }6 r* n& x% z% L 0.000000000000000E+00 0.000000000000000E+00 0.000000000000000E+00/ l, x0 o/ Z* K0 F/ X) I3 ~
/ r$ [% P1 _% E: M0 ? 0.000000000000000E+00 0.000000000000000E+00 0.000000000000000E+002 L2 B1 z% l# |# q0 H) V
Frequency card. 2.000E+01 5.000E+01 7.570E+01 | 20. 50. 75.7 1 e) j9 x' M* }4 k- @
* C! U5 W1 v; z" tMatrices are for earth resistivity = 2.00000000E+01 ohm-meters and frequency 5.00000000E+01 Hz. Correction factor =
- o4 N/ K2 ~& w1.00000000E-06+ V9 f# d4 R% G- Z. V6 a: |# o
Frequency card. 2.000E+01 5.000E-03 7.570E+01 | 20. 0.005 75.7 7 10 1: d( {" v' H+ Y6 p
Blank card terminating frequency cards. |BLANK CARD ENDING FREQUENCY CARDS
- C/ \8 V; R+ OBlank card ending "LINE CONSTANTS" cases. |BLANK CARD ENDING LINE CONSTANT0 |. Q8 `: E2 ^* _; }" I+ C" s# S- N$ P- U
Request for default fitting (= 3 blank cards) |DEFAULT9 o3 h: g% }# o7 f
. Y5 P8 q8 S# p7 j: U7 r===== ===== Begin Zc fitting for mode IMODE = 1 ===== =====' F8 N$ Z) R( U) F! m8 j
The number of poles NPOLES = 41 in this loop exceeds the specified limit NORMAX = 306 i* @5 G: w1 F5 s7 s
" F+ f" U) D" p! X/ @+ T
@@@@@ @@@@@ Begin A1 fitting for mode IMODE = 1 @@@@@ @@@@@
+ P! E! s: K# s; {! i: _. U! M + N T# A0 W, J7 G
===== ===== Begin Zc fitting for mode IMODE = 2 ===== =====
! @0 P* A2 x. tThe number of poles NPOLES = 34 in this loop exceeds the specified limit NORMAX = 30
& n/ {. Q! u, C- a: Y, g3 P8 e " ]3 S P4 j! @. I) P% O( @
@@@@@ @@@@@ Begin A1 fitting for mode IMODE = 2 @@@@@ @@@@@
5 K7 ]" G4 f0 n $ |/ Z2 y6 K# e; Y! _) Z) X- v
===== ===== Begin Zc fitting for mode IMODE = 3 ===== =====4 n% o0 _: `( Q
The number of poles NPOLES = 31 in this loop exceeds the specified limit NORMAX = 30- t, m# q' h2 i) z1 ^' ] a7 Z' i: E
" s; }2 e5 i: w1 Z. P8 f
@@@@@ @@@@@ Begin A1 fitting for mode IMODE = 3 @@@@@ @@@@@) ?0 G; s4 u, h& [" _3 `
) ^9 U+ q: P; c5 T+ S4 f# _Request for flushing of punch buffer. |$PUNCH6 ^7 |: b" u1 X |# j
0 W' z! u! q& q W5 b' Z6 Z& U
A listing of 80-column card images now being flushed from punch buffer follows./ K2 V' r0 e0 V
===============================================================================- ^) a- i9 M, E1 m% v) y9 i
" `' M; X% z4 L2 ]5 X7 L( s4 T===============================================================================9 j# a L1 A @& {# y
C <++++++> Cards punched by support routine on 13-Apr-10 16:56:55 <++++++>
i6 w5 g) ^3 `. H: V8 ^C ***** UNTRANSPOSED JMARTI line segment ******
3 b1 d0 W) W) w8 z% w+ c) FC JMARTI SETUP8 f g/ ^4 Z0 N7 j" F; }8 v2 a- |
C $ERASE
2 M1 A: s9 w3 v+ ZC BRANCH IN___AOUT__AIN___BOUT__BIN___COUT__C" j6 r* O4 ~" a+ N
C LINE CONSTANTS
! K) i; Q9 y5 y( o3 h" X$ \3 v" W; t+ DC METRIC1 l" N* U* U/ _. S' R
C 10.259 0.069 4 2.9 -19.5 25.1 10.1 60. 45.9 {1 i2 j) h. V' g
C 20.259 0.069 4 2.9 0.0 25.1 10.1 60. 45.
# i) v. G8 j3 {+ ]( oC 30.259 0.069 4 2.9 19.5 25.1 10.1 60. 45.' d% _& g) K/ z4 c- i
C 00.175 0.44 4 1.54 -15. 39.7 24.7 0.0 0.0
# a, e! F) l/ t; TC 00.175 0.44 4 1.54 15. 39.7 24.7 0.0 0.0
" l& O, l& N+ H( ~# E3 i7 T! xC BLANK CARD ENDING CONDUCTOR CARDS: l) c3 F- E7 X' c; O
C 20. 1.E3 75.7 11 B9 }1 g. e$ o8 |
C 20. 50. 75.7 1
0 R9 ~* R4 Z" `7 B$ a# [4 E# h9 p$ ^C 20. 0.005 75.7 7 10 1
- `) `) T4 t4 }; l. P9 W \C BLANK CARD ENDING FREQUENCY CARDS1 R; L4 k( p I' Q' [ M. ~4 G
C BLANK CARD ENDING LINE CONSTANT
* l( z% f* @0 ~! t; GC DEFAULT
* W& [* ?* D% \) V2 ~6 _-1IN___AOUT__A 2. 0.00 -2 3
% q; W4 [2 G7 O7 R; P" N4 v u 17 3.3876136028747050000E+023 T# Z2 \+ ~& b0 S4 o4 z$ H' t
1.56748087606698020E+02 1.53350246690381570E+02 5.91752415177784810E+01, c. H$ _+ n! [. E% M# n6 t
2.01342311994593360E+02 2.35228649588483170E+02 2.53692631526845670E+02
8 U0 a$ ?4 p; n 1.66995629609519800E+02 3.13013616521086590E+02 7.77592731836887200E+02
# ~, g( r/ A7 S8 S 2.92709376085682020E+03 8.36186324719264120E+03 6.39337717296788010E+039 \' ~3 m3 L) @ i
1.11850636212671030E+04 4.41394197432314540E+04 3.57997951874029590E+05
, ^2 W K! R O3 ^% E4 _2 @ 7.56151786639699950E+05 1.36950810507648970E+06
- i) a% r5 Y: _9 w0 R* F3 O 1.42216936124761770E-01 2.00869674971664410E-01 2.46548549642172290E-01* w! w- [' G( B. {0 ]+ F
4.83183838918269940E-01 8.90165197319727430E-01 1.60597725665316450E+00
$ J# l6 s; f/ H. v 2.89724575888037260E+00 5.22044042049842180E+00 1.93205621429485000E+010 y; n! j+ S- [. [/ r) k N
6.43540045186946370E+01 1.19989060419415150E+02 2.38618178257245120E+02
( r2 A- I1 p" C z) t 7.72151589982453290E+02 2.99346013405561330E+03 1.27367479883974610E+04. Y5 r, I/ a) G. T4 ~; U
5.61967457160417400E+04 1.12259275941284690E+05
( `2 x* Q# }& H2 G; W3 { 18 2.5648081591925806000E-04
. g' \, i4 A7 ~6 F# d* A& E8 ` 4.39088902072225850E-02 2.51823882949434860E-01 2.09625388083036990E-01# J- y& j6 K5 [& `
3.78494708253580230E-01 4.21222198449916040E-01 1.12875930767027930E+009 w$ V% [5 p" o) R9 z; j
1.71876255372116240E+00 5.22622351239333400E+00 2.87507803450135600E+01$ T2 q9 T' w4 F& p4 n$ ~
3.11711415283725670E+02 -4.25029687238800080E+02 4.11909331052564360E+03
# r. k9 ^) b, U: ]5 Z 2.03169322161820860E+04 9.92298833352391920E+03 9.73079142175107300E+07: o5 k, r+ ?# ?, m% \
-9.55146506480773540E+07 1.78452787243354890E+08 -1.80280334637975660E+08
' Q3 H$ L/ _+ T$ L1 }) o 1.71037480519741610E+01 8.83202394182148960E+01 9.05344339387639390E+01: I' L: p% q+ T% l6 a
1.45765976458050060E+02 1.67604264020870910E+02 4.33406916110919100E+02
& H& t6 T7 j$ I' S/ K 6.63140374794807490E+02 1.92887674552758430E+03 1.33200718265846740E+03
5 [1 c+ a) \; V$ ?0 c6 W 5.71524437659357950E+03 1.42342855758340520E+04 1.25142080353191360E+04( i% y& w: ~& m- p: J3 O, d* O
3.62317843255328920E+04 5.63019677971675190E+04 2.08969723652870020E+051 [& X5 J5 [. a H5 p
2.09178693376523150E+05 1.79625128065165980E+05 1.79804753193231360E+05% e, _! B& d8 r3 w3 E& x
-2IN___BOUT__B 2. 0.00 -2 38 I* }4 P/ v( d
16 2.7356159603025270000E+02
5 N. V" h8 m' `( i5 D) a6 O/ B! z 3.69404660026332070E+02 -6.57736076515949720E+01 3.81922741682533400E+02* D1 r- A' T. l) p; D9 I
7.08453587370238780E+02 5.41167797769398360E+02 3.06226540265072910E+021 X) n1 A' w) j; |2 {, g
9.12429137114825860E+01 1.45546235045872410E+02 4.35671648435959070E+02$ V- b' m1 ?5 H; B
9.89457112977898990E+02 1.20421629942927280E+04 2.52441351892631970E+04) {5 ~9 k& H) o% K
1.31721403134872210E+05 1.00702634087143390E+05 1.00067739988421900E+05
& P4 A9 l8 i) ~3 E3 T7 s1 i% v 1.98945562771848960E+05- _5 y( T9 o7 o1 `
1.48932587810283570E-01 1.91111259756068880E-01 5.23244958961560200E-01' I, s& ?& G* p
1.98685487501559810E+00 5.99260600202752600E+00 1.07800276387683840E+01 j, u' G) N- E' n
1.40587613181405300E+01 2.26773470722948250E+01 3.15477144275676150E+02! n/ i) _7 f/ s: ]
7.20661772011409880E+02 8.57135008822161760E+03 1.81290494844508870E+04 L0 ^# x( d+ d- F: D& Z3 ]! V
9.82444873325722870E+04 6.84224792084696670E+04 7.51320465443383440E+04
4 Q# q& S( y. x, J 1.48835602821329780E+05
7 |8 V9 J* L+ ]7 _' Z3 m4 } 8 2.5331274985951097000E-042 ]4 i3 N; @$ p8 H
9.77519359442743510E+00 9.06749971882869370E+01 3.89917698321721050E+02
: O( |0 ~" ?' a 2.14763901924745410E+03 3.21139859861504280E+03 7.78666160670429240E+033 N6 h- S& W& l+ {6 Q
-4.35590044273043600E+04 1.46424632739437020E+054 C3 [: j3 [* I3 u" e
1.34347544158826870E+03 1.11481723747429880E+04 2.13548802821824830E+04
3 W# T* r8 ], U7 `2 F9 | 3.88406059295760640E+04 4.48673492254774170E+04 6.34696015771263410E+04 s+ o3 n: L p* T& A: L2 k" \
5.71514355618160570E+05 1.84730022532517380E+054 f/ Q. O5 @, K* i! s9 K
-3IN___COUT__C 2. 0.00 -2 30 S" l5 n: Y1 k/ X C" K9 f
12 2.4217757892053910000E+02
4 T. W* Q4 Q! r' \3 ^8 l" I8 J 3.11081567238861170E+02 -2.67647353791795130E+01 3.71876217221247710E+02
0 [: o# H! a; p. H( w 7.07422509445779840E+02 7.84485674697519240E+02 5.15644097900284780E+01
8 @3 G$ l& f. v, u0 @# X 8.62357151535732380E+01 1.33677642835807010E+02 1.31608612652184290E+025 U9 S6 Y$ ?$ {, w
1.14893287428216410E+02 9.93716544256342760E+01 5.59773592553784180E+047 Z) I" m( [! [$ O. c. _) k. O; m
1.34344252475530860E-01 1.81414794097451400E-01 5.11374925899225950E-01
0 j& i1 r2 z& Q* ~8 W3 r% p( h* a5 A 2.04824350656590370E+00 7.03072667690498320E+00 1.02204034540275260E+01 y" N% @. j0 i. g A) S- `
1.40807516766374870E+01 2.26422726843327060E+01 3.61527808309766810E+01+ x5 ]/ _" [4 c, q7 O6 m( c/ F2 b
5.66127229741269180E+01 9.24983189391125220E+01 4.52655232370584050E+04
* S+ n+ z& T* f" Q0 b 6 2.5172653258524589000E-04) ]+ t2 B K, t6 G9 M, [ C
9.16195806109742070E+00 3.77612637640999710E+02 6.49218461519983410E+02
; {# V. x h1 F/ E 2.16338680527304540E+03 -2.80386507590504550E+04 4.81761010930565240E+059 g& o% g# X& V2 K* C
1.48053740522388740E+03 4.65974978309593280E+04 5.01953038655574710E+04+ M& ]# y7 `. ? r5 _* I5 j! N$ h
7.89025069563385330E+04 2.89584576325553890E+06 5.04629561166254750E+05
$ {. c+ O7 j; a1 B- E 0.57481400 -0.70710678 -0.42812257
" K% I. D0 C) t! p& |; z 0.00000000 0.00000000 0.000000000 k ]( c0 D: @8 x2 D# T% h" `
0.58238966 0.00000000 0.79587821
6 I2 J. c4 v* B# n 0.00000000 0.00000000 0.00000000! l9 X# h0 c! s3 S" g
0.57481400 0.70710678 -0.42812257
- H* O) n7 C; C( Q7 { |5 H5 @- ] 0.00000000 0.00000000 0.00000000
8 `: }6 R+ B$ j5 m" }=========< End of LUNIT7 punched cards as flushed by $PUNCH request >=======+ F* u2 ^# `# D) P. }! n/ R
8 d9 U1 Y- E( L6 @
Blank card ending "JMARTI SETUP" data. |BLANK CARD ENDING JMARTI SETUP
/ o x+ s/ _9 x1 xTotal case timing (CP, I/O, tot), sec: 0.219 0.000 0.219
2 h9 w- c$ O8 k& B d R L C参数是那些啊?麻烦您一下 |
