查看: 1123|回复: 0
ETAP发电机启动
    2019-5-20 11:02
  • 签到天数: 18 天
    累计签到:18 天
    发表于 2015-6-11 11:54:26 | 显示全部楼层 |阅读模式
    The etap Generator Start-Up module is a special feature of the ETAP Transient Stability  y$ g6 p0 |* w; o* V$ Q  c
    program. The type of analysis provided by this module is particularly necessary for special
    4 O4 Y4 T3 _3 h: v# \# aconditions such as when the connection to a power grid is lost and recovery of the power supply
    # _/ H6 E% }/ `- vto critical loads is mandatory. Under these conditions, a cold stand-by generator is started up as
    " P. O' l# u; e- U5 e2 r& u1 o& z" Qan emergency power source and progresses through acceleration and load acceptance stages
    * \8 U( p' @& Q* L- e( [before reaching its final state.
    9 L0 L$ B! b& l) P" iThis module will allow you to study the dynamic behavior of the starting generator (generator0 @# z) j$ q8 n4 @
    frequency, speed, mechanical power, voltage, etc.) as loads are added during the start-up
    4 D6 s+ k4 R1 `) C$ Ttransient. It also allows you to observe dynamic behaviors of accelerating motors (both induction7 X" k1 ~6 l# M' X2 J. K
    and synchronous motors) as they are energized by the starting generator.
    : H$ W9 A2 N. \! rThe following is a list of requirements and conditions that apply to the Generator Start-Up2 ^  Z' W7 l- s' ~4 t0 R; V
    module:
    + c. Q* O3 \8 n  L0 M1) This module is designed for the simulation of a single starting generator, which initially is+ V1 j( n! c* S. L3 w7 |
    connected to a de-energized network. The starting generator should be the only source8 Y& ]( J; E* t' `( ^
    in the network that is studied.
      B$ N5 }7 G5 X8 t8 }2) Only Subtransient Salient Pole model is supported for the Generator Start-Up module.9 E0 G. z. F6 V- J8 G
    Thus, the starting generator needs to be modeled as a salient pole machine.6 s+ O* e( S2 y, [1 L: T
    3) The exciter and governor models of the starting generator need to be modeled with
    , ]) ?7 b: n$ V9 ?. D6 w) K' _special capabilities and control mechanisms for the start-up process, including fuel flow# q4 p$ S  E$ d
    at reduced speeds, exciter field flashing, etc. Note that standard exciter and governor: T' B0 e1 c8 p+ f& G  N; X
    models are suitable to represent generator operations starting from the steady state,
    ( D6 Y2 H" e2 T  p) Nthus they do not have these special capabilities.# b+ H  D) o+ E- }% o8 Q; l  h; m
    4) Currently, ETAP includes only two control models in its standard generator control model
    # j& O, |9 G) S" Q/ q+ G. wlibrary (exciter type ST1D and governor type HYDR) that can be used to simulate the
    8 r2 y2 \$ O8 seffects of generator start-up process. To simulate other types of exciter and governor" Q1 }! f1 ?5 @  Y! G1 t
    models for generator start-up simulation, the User Defined Models (UDM) module needs
    0 S3 L$ {# k+ G4 M* D+ g" ^( v& M/ Xto be used.
    GMT+8, 2026-11-18 03:12
