TA的每日心情 | 开心 2016-5-9 13:24 |
签到天数: 4 天 连续签到: 1 天 [LV.2]偶尔看看I 累计签到:4 天 连续签到:1 天
发表于 2013-2-24 23:43:40
7 G# u0 v+ i3 ?- k: n9 DName : LINEZT_3 - Distributed parameters (Clarke) 3 phase. Transposed0 D) l+ Q' \: M& S8 j O
Card : BRANCH9 C J4 D; I" n/ H% T2 |9 x
Data: Values are entered in the two independent modes of the system, here called + and 0.# t$ y4 T! N( j' ~- Z$ Z( {8 k
R/l= Resistance pr. length in [Ohm/m]
7 ?" E4 N- U7 n1 S; l7 ]) E2 @2 l! X The lossless part can be described in three ways% i9 [8 T& H9 h" ? t/ p8 y% R
0. Inductance L' in [mH/m] if Xopt=0 or in [ohm/m] if Xopt=power frequency% w4 k1 g' `" z+ ]3 n( g
Capacitance C' in [uF/m] if Copt=0 or in [uMho/m] if Copt=power frequency4 ]" t; M) R# ?! d, j+ w
1. Modal surge impedance in [ohms]; Z=sqrt(L'/C')7 d% }; j- T6 [; o @
Modal propagation velocity in [m/s]; v=1/sqrt(L'*C')
( p) y( G @) [1 |1 H0 f 2. Modal surge impedance in [ohms]
: u6 j8 e. I9 f+ S* o! j Modal propagation time in ; T=sqrt(L'*C')*length ! I f. F+ r8 r6 M/ K0 o0 F. F
Xopt. and Copt. are set in menu: ATP|Settings/Simulation.
. C6 l6 A, x5 `, Y The user can choose conductance modeling G=0 (the usual case) and G=R*C/L (distortionless)
2 o2 ] g! _9 k6 C length= length of line in [m]9 r) V; V5 f# o/ g# L
Node : IN1= Start node. Letter 'A', 'B' or 'C'
5 Z; j5 ^2 X* Y3 T N is added to nodename for node 1, 2 and 3.
& U$ T4 O$ j7 C OUT1= End node. Letter 'A', 'B' or 'C'
2 j& x. P' @# b, L1 w0 a is added to nodename for node 1, 2 and 3.
) S( G+ m/ M* t' w: e; z$ l1 `Only branch voltage output is reliable.+ Z2 U9 Y o. _$ q# f
RuleBook: IV.D.1 |
