查看: 8670|回复: 9
ATP运行出现错误,求大神指导
    2018-2-6 07:00
  • 签到天数: 55 天
    连续签到: 5 天
    累计签到:55 天
    连续签到:5 天
    发表于 2012-12-5 16:54:19 | 显示全部楼层 |阅读模式
    You lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following
    $ g. _0 u' j; q; C) T: m2 @. `message summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where
    8 v! M- [" b8 _) n0 U, Qthe "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card
    8 U0 f5 U5 T; J7 n/ k, his generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been7 u. I" P. {! I4 F
    displayed, so a copy follows:  B0 ?& z2 t3 x  M" Q: A* ?
    6 }% e* c4 D7 ^. s              KILL code number                Overlay number               Nearby statement number
    ; }% O& r/ G6 N+ ]                          1                         13                               8109
    ; y8 R  _% c" H1 }8 `) P2 c- ~( PKILL = 1.   Storage exceeded for EMTP List Number 8.   See the dimensioned limit in the case-summary statistics below.  The problem
    6 l: v& \6 \7 Jis simply too big for the program as currently dimensioned.  Yet, do not forget dynamic dimensioning as described in the Oct., 1993,8 R5 i$ o, S% |) t  q
    newsletter.   In this case,  edit  LISTSIZE.DAT to increase table sizes,  and then try again.   Of course, such dynamic expansion is
    9 a7 J3 S1 g- H$ X  fpossible only within limits fixed by  LISTSIZE.BPA  (used by variable-dimensioning program  "VARDIM"  as ATP is to be linked).
    & K# p( l; q1 j( ]Sometimes the reason for EMTP table overflow is unclear, and Program Maintenance might wish to inspect the contents of the error
    4 S4 [; s4 R' B- ^% B# Iinterface vectors  LSTAT  and  FLSTAT.    These now follow.   First comes  LSTAT,  using (12I10) encoding; then comes  FLSTAT,6 }+ v6 ?: w- j  `/ r, L% Z" L7 c
    using (8E15.6) encoding:* I4 X6 A$ Z% \& B" D
    LSTAT =     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999        10        80
    1 a$ G% [9 D2 J- _5 {3 q7 z) C9 YLSTAT =       323         0     -9999         8       324         0      8109     -9999       116       155       323         7
    $ V3 e' Z3 B* f5 s& w8 CFLSTAT =   1.562500E-02   1.562500E-02   7.812500E-02   7.812500E-02   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+009 d. w5 A& x1 O/ y
    FLSTAT =   0.000000E+00   0.000000E+00   0.000000E+00   5.000000E+01   6.000000E+01   0.000000E+00   0.000000E+00   0.000000E+00
    7 ]! o9 R/ j8 G* m% c$ q8 a' wFLSTAT =   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00! P& I1 z# I! ^% N
    Yet maybe the user would like some suggestions as to why the table in question  (List Number 8 )  has overflowed.   If such further
    3 t0 H7 m7 {$ y" Ainformation is available,  it will now follow immediately ....! b9 d7 j" m, S; G; s
    List 8 stores past history points for distributed-parameter transmission circuits (lines or cables) in modal form.   Each2 `. ~1 x3 u6 k6 j
    propagation mode requires storage, and there are as many modes as there are coupled conductors or phases (e.g., a double-circuit
    2 N& ~# \7 y" h2 @* Dline will normally have 6 modes).  Each mode requires TAU / DELTAT  entries,  where TAU is the modal travel time of the line,) B6 r2 x# |! V5 _. T8 d
    DELTAT is the time-step size,  and the division involves integer truncation followed by the addition of unity.
    + R  V7 g3 i: E7 P8 MIn order to effectively trade memory space among the different EMTP tables (EMTP List Sizes), the user must know how many arrays% A7 _* z5 S1 h# R" C# O4 e
    (columns) there are in each table.  The following tabulation shows the effective multiplicities that are associated with each2 b) I* Q/ D9 u0 \- K1 ?
    independent EMTP List Size (those lists whose lengths are under user control by means of the EMTP variable-dimensioning program8 a) z1 o, Q( ^) ~
    "VARDIM").
    9 z; ?9 w. V/ W) p-------------1------------------------------------------------------------------------------------------------------------$ I5 B( B, ]6 w" ~. M4 `' P  M* o; `
    0 A0 h% v) f1 C, D7 p8 E8 s  ?: nList Number  1   1   2   3   4   5   6   7   8   9  10  11  12  13  14  15  16  17  18  19  20  21  22  23  24  25  26  27
    7 l/ M; _5 l$ a4 w+ L
    ' Q3 s8 M& h) w0 Y# V-------------1------------------------------------------------------------------------------------------------------------; Q& l+ E$ `- ~. _
    5 ?3 u7 r* }/ p. D  ~
    Floating Pt. 1   6   5   3   6   1  12   2   2   8   3   1   4   8   1   2   2   0   6   1   1  24   2   1   #   *   1
    1 c; d6 m, V6 `* vInteger      1   4   7   0   2   1  10   0   0  11   0   3   0   4   0   0   2   1  10   2   0   0   0   0   0   0   0/ m; _9 p6 O8 X% i- b
    Total        1  10  12   3   8   2  22   2   2  19   3   4   4  12   1   2   1  16   3   1  24   2   1   #   *   1
    0 H! B/ h  t5 H/ R
    ) c0 w) W. p6 N-------------1------------------------------------------------------------------------------------------------------------
      N9 U& @- ~6 B$ ^2 J9 }: P/ u. z! `; D: D
    # --- Used only for virtual computers (Burroughs, PRIME, VAX, Apollo, etc.).    Others can ignore this List.
    ! @) |( U! M  b2 v; N* --- Rather than count List 24 itself,  add the value to the floating-point  and total counts for Lists 1 and 6.
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
    发表于 2012-12-5 18:05:48 | 显示全部楼层
    乍一看一堆乱码?
    发表于 2012-12-6 05:04:04 | 显示全部楼层
    你的数据溢出了,需要重新设置一下LISTSIZE.DAT; ?; l6 j, b5 N  w. I
    开始菜单-ATP-ATP Launcher-Tools-Make Tpbig.exe( d6 V) F1 k5 d
    Change Listsize打勾,然后把第八个值改大一点,然后再运行一遍试一试* B9 [5 l8 Q4 m- {4 ~
    我上次遇到过相同的问题,就是这么解决的2 I% ^: S% ]/ Z; p! h$ T7 i& R
    https://tech.cepsc.com/thread-85044-1-1.html
    2018-2-6 07:00
  • 签到天数: 55 天
    连续签到: 5 天
    累计签到:55 天
    连续签到:5 天
     楼主| 发表于 2012-12-6 12:21:21 | 显示全部楼层
    回复 3# 螃蟹飞飞
    7 t9 e  l3 n2 Q  T3 Z6 l. Y非常感谢,我试了一下,还真是这么回事。多谢了啊!
    发表于 2012-12-13 12:16:06 | 显示全部楼层
    想请问一下listsize中的参数的修改有什么限制么?
    2021-3-30 19:49
  • 签到天数: 153 天
    [LV.7]常住居民III
    累计签到:153 天
    发表于 2019-4-2 18:24:10 | 显示全部楼层
    螃蟹飞飞 发表于 2012-12-6 05:048 P& @7 f6 I  j( f4 m
    + A0 t4 l' ^, _4 W/ a9 {开始菜单-ATP-ATP Launcher-Tools-Make Tpbig.exe* |; `  V, n/ |6 R4 P
    Change ...
      h! s, w- U9 v7 _$ f" W& Q
    6 v' n3 m# O0 D) h  G6 C! m
    登录/注册后可看大图
    第一行第八个数吗?改成多大合适呢
    3 ]% p5 z+ A0 P* m
    回复 推荐 踩下
    使用道具 举报
    2021-3-30 19:49
  • 签到天数: 153 天
    [LV.7]常住居民III
    累计签到:153 天
    发表于 2019-4-2 20:35:04 | 显示全部楼层
    heshuiniubi 发表于 2012-12-6 12:21
    % |% O. m3 H' {% k" @回复 3# 螃蟹飞飞 , Q" n7 H/ s5 O  L5 S
    5 R2 Y3 B% f* v2 t* x: D3 f' m3 E具体是哪个数据啊
      M5 d) G* j' X3 J" T
    回复 推荐 踩下
    使用道具 举报
    2020-12-11 11:11
  • 签到天数: 26 天
    累计签到:26 天
    发表于 2019-4-8 22:08:18 | 显示全部楼层
    986305096 发表于 2019-4-2 20:35- j2 C% F% q6 J6 v& }: K7 V
    具体是哪个数据啊
    % a5 y* T" q# g" I# ]" s1 H
    从第一个数到第八个就好了呀& P( o1 v1 l3 N7 [9 T. u
    8 a& r8 C5 N5 j+ E
    回复 推荐 踩下
    使用道具 举报
    2021-3-30 19:49
  • 签到天数: 153 天
    [LV.7]常住居民III
    累计签到:153 天
    发表于 2019-4-12 10:38:54 | 显示全部楼层
    wangchaoqun 发表于 2019-4-8 22:08
    7 v5 ~; p4 P: q; l( b3 P从第一个数到第八个就好了呀
    2 D0 D6 k+ H; Y) }4 X7 X0 v
    横向数第八个数吗
    % ]6 I) B5 P- `% b" s+ J% f( g$ [
    回复 推荐 踩下
    使用道具 举报
    2020-12-11 11:11
  • 签到天数: 26 天
    累计签到:26 天
    发表于 2019-4-12 20:14:20 | 显示全部楼层
    986305096 发表于 2019-4-12 10:38
    ) M5 y5 r, L! ]; i横向数第八个数吗
    6 g% l" k' v7 R; C- g8 X* D是啊,我修改的就是
    3 v( ]! b# F- h8 a* x4 l1 ~
    ( e5 U0 ?( d: h" E- k
    / U7 E& ~1 e: a; B$ t3 D  d; E; Z
    回复 推荐 踩下
    使用道具 举报
    GMT+8, 2026-11-20 08:41
