查看: 3020|回复: 7
求助四机两区域动态仿真
发表于 2012-6-2 15:22:14 | 显示全部楼层 |阅读模式
潮流结果和PSASP的完全对得上,但在不设故障情况下在0.17s失稳,G1的Pelec如图
( O1 {4 e+ F3 c* j9 B QQ截图20120602151401.png + v4 Y1 J! ~6 H9 _7 p* C
" y  l4 x0 O+ A# d: H. C+ c4 llofl' A  f  {4 m" u( h; l. X, n8 @
ACTIVITY RTRN TO RETURN TO DYNAMICS--ACTIVITY? : l3 G1 a* ?$ F6 G4 l( Q
Executing activity read,file% g* o! E/ N4 q6 m4 F7 @
read,file
( f, T, m9 n4 ? ENTER INPUT FILE NAME (0 TO EXIT, 1 FOR TERMINAL): 4g2a+ Y+ Z% B. V9 v0 q# l
ENTER IC, SBASE
$ q( D: N& Y4 E' b" u( B. g2 T8 o ENTER TWO LINE HEADING4 A6 Z  ?! a6 r( u) f
ENTER BUS DATA
' E" C9 B9 x5 C, C1 Q ENTER LOAD DATA
4 ^$ M! [8 j6 U ENTER GENERATOR DATA
. O7 K4 {9 B; u4 `* ? ENTER NON-TRANSFORMER BRANCH DATA
. u. a( Q  l  d* n ENTER TRANSFORMER DATA
. C3 y& m9 V5 F4 \) J. R* J ENTER AREA INTERCHANGE DATA5 C; d5 g( a! s8 s+ R
ENTER TWO-TERMINAL DC LINE DATA) A) F& H% V6 V% b4 l
ENTER VSC DC LINE DATA! G, M8 h& H! @5 h9 B+ J6 v
ENTER SWITCHED SHUNT DATA1 Q( [" x  K! `
ENTER TRANSFORMER IMPEDANCE CORRECTION DATA
  N! `% y* Z2 z& {; N; i% Q ENTER MULTI-TERMINAL DC LINE DATA
4 x: o5 W( _% d3 S* ?  u ENTER MULTI-SECTION LINE DATA
' z" i: N* B' z, B4 ` ENTER ZONE NAME DATA& C2 r+ `( t0 m* c$ C" W6 ]; L9 s7 [6 ^
ENTER INTER-AREA TRANSFER DATA# |5 Q! z  J. d0 N
ENTER OWNER NAME DATA
% |' X' q1 V. G0 h1 h ENTER FACTS DEVICE DATA3 S' X) d( S3 T3 V* q
: h' w" t1 b8 I+ y4 o5 {1 T Executing activity fnsl! T0 y0 R3 u) K9 X
fnsl
% ^# K9 M& X. i0 t8 e0 O1 W ORDERING NETWORK4 [" X/ y8 d9 v/ A4 U2 V
DIAGONALS =     10  OFF-DIAGONALS =      9  MAX SIZE =     181 j3 ]. O# y$ D5 E; V- P  @+ A3 g
ENTER ITERATION NUMBER FOR VAR LIMITS
2 s! L2 h5 ?% s/ u% y+ f& Q- m9 L  0 FOR IMMEDIATELY, -1 TO IGNORE COMPLETELY: 99
) q8 _2 a7 K; A$ C0 y8 K  ITER       DELTAP      BUS         DELTAQ      BUS        DELTA/V/      BUS       DELTAANG      BUS6 S6 I+ n: f- `+ k# D, v
   0        21.2968(      401   )    2.7013(      801   )    0.12761(      801   )   0.58266(      801   )
' T; K: W' O( N6 n  P; p   1         4.2106(      801   )    8.1793(      901   )    0.12606(      701   )   0.04352(        1   )
/ V- [  j* [* [- s   2         0.2518(      901   )    0.7799(      901   )    0.02045(      701   )   0.00508(        1   )
4 q' e0 t8 R7 I0 `, c   3         0.0122(      901   )    0.0124(      901   )    0.00048(      701   )   0.00029(      801   )
0 D" b! i4 I1 L* ?- Y$ d) t   4         0.0000(      801   )    0.0000(      901   )    0.00000(      801   )   0.00000(      801   )3 O' d. r  |- C* j% W7 n# @
   5         0.0000(      801   )    0.0000(      801   )
+ `$ r; E& w! N REACHED TOLERANCE IN   5 ITERATIONS
) S) w8 i: [1 R2 W6 u+ G1 Q LARGEST MISMATCH:    0.00 MW    0.00 MVAR     0.00 MVA AT BUS    801 [9           230.00]
' Z. e: j4 G  v8 f" ^! f& Q. b SYSTEM TOTAL ABSOLUTE MISMATCH:               0.00 MVA
! w  c, O  c% C  l  h, p! k SWING BUS SUMMARY:
3 x: ?* c4 s4 E  b; w2 x" |" j' S% r   BUS# X-- NAME --X BASKV      PGEN     PMAX    PMIN      QGEN     QMAX    QMIN7 l' W1 l/ Z  @3 D* c4 d
    301 4           20.000     700.1   9999.0 -9999.0     202.3   9999.0 -9999.02 v/ H1 }9 [# k9 D
9 }' Q% a- S3 }8 c Executing activity save,4g2a00
  I: q- _* C5 bsave,4g2a004 t6 N6 c! m6 k: K+ w
CASE SAVED IN FILE 4g2a00.sav ON SAT, JUN 02 2012  15:06
' P; |; a! y+ I- y ACTIVITY RTRN TO RETURN TO DYNAMICS--ACTIVITY? + l3 [1 Z$ |* l0 @4 W8 @
Executing activity cong
' i; L$ X& Y" l0 a/ |cong
* k! C8 L2 v5 a3 S GENERATOR CONVERSION COMPLETED
' o' z$ x/ |% Z0 @0 j ACTIVITY RTRN TO RETURN TO DYNAMICS--ACTIVITY?
( S. ~" v5 m# U8 D Executing activity conl all
7 I2 L6 }4 S* \9 R* {% Jconl all! {# s7 Z0 e+ @- a
ENTER % CONSTANT I, % CONSTANT G FOR ACTIVE POWER:
' q$ Z& q; a/ V' [* c& M ENTER % CONSTANT I, % CONSTANT B FOR REACTIVE POWER: # Y- K. q/ c$ }! X- R
LOAD TO BE REPRESENTED AS:$ R2 L5 M" ?- S: y
    ACTIVE  REACTIVE$ R" k* A5 ]- ]0 o3 j. x% P
   100.00%   100.00% CONSTANT POWER) }0 E# b* W# h4 Y5 E. y) S1 z
     0.00%     0.00% CONSTANT CURRENT* l* K  d5 N+ C. |
     0.00%     0.00% CONSTANT ADMITTANCE
# B* H: C. |# e- H& o6 b6 _, a ENTER 1 IF O.K., 0 OTHERWISE: 1: q, D0 ^3 v9 M. ]& p
      2 OF      2 LOADS CONVERTED
. V$ h/ o+ o3 Y/ G ACTIVITY RTRN TO RETURN TO DYNAMICS--ACTIVITY?   o1 i* q# X, g
Executing activity fact% _- c3 a" v& e' c+ M4 i/ ]" h
fact
2 d- W6 _; k* \. } ORDERING NETWORK( n5 ~5 ^/ `$ z6 C1 M2 @  ~# I
DIAGONALS =     11  OFF-DIAGONALS =     10  MAX SIZE =     20
2 _4 U& _' ^3 L( O+ h     11 DIAGONAL AND     10 OFF-DIAGONAL ELEMENTS* g% Y7 N$ N% s1 @4 W
! j5 H0 A) U- O( K Executing activity tysl
) U9 Y1 Y& r# {8 K* c0 H4 L: ltysl# g$ W2 ~' C+ H: V. Q; V
ITER DELTAV/TOL X-------- AT BUS ---------X  REAL(DELTAV)  IMAG(DELTAV)
5 ?) ^7 C& T7 p2 v# D9 I8 C2 m" S% J    1     0.003       1 [1           20.000]    0.3029E-07   -0.1089E-07# \- ?# \" E, `/ U
REACHED TOLERANCE IN   1 ITERATIONS
! ~5 q/ v. T8 m LARGEST MISMATCH:    0.00 MW    0.00 MVAR     0.00 MVA AT BUS    601 [7           230.00]
* t8 Q" L0 ?- k+ m SYSTEM TOTAL ABSOLUTE MISMATCH:               0.00 MVA- H1 a. _# X' z( a  y7 y
  K8 F3 e# J% y3 p Executing activity save,4g2a00/ a+ D0 X% ~, O6 g. v8 G
save,4g2a00
' P3 F3 W' a1 ]9 { CASE SAVED IN FILE 4g2a00.sav ON SAT, JUN 02 2012  15:07
; V3 {( N! \1 P; j3 Z% ~& W) ^ ACTIVITY RTRN TO RETURN TO DYNAMICS--ACTIVITY? + I5 n0 j0 v/ |- a( \
Executing activity RTRN  h# u7 H8 M' O; c9 x
RTRN
. ^$ u5 ?/ k5 ?- n3 v ACTIVITY?
$ c9 C! Y2 K1 t5 J Executing activity DYRE, K; N+ a0 P* U5 v! k! K' G. g
OUT OF FILE DATA--SWITCH TO TERMINAL INPUT MODE
, H2 g8 k3 V3 O# l  Q9 ] GENERATOR MODELS USE:5 @0 t6 ]7 ?- i9 z0 W
  CONS        1-    56' K- L- I1 u, g; F. y6 x
  STATES      1-    24
7 P! ?8 A" A0 I. E& `' h
" s! D$ J/ h! m SUMMARY OF MODELS READ:3 W" n8 O6 @: I; `1 U
GENS:  GENROU
/ Y% {+ ?% I- a$ l$ }4 G$ J; o; ^           4
+ N% F6 }$ v" b2 w NEXT AVAILABLE ADDRESSES ARE:
/ E1 F% J* `2 h: v  {* P    CON  STATE    VAR   ICON
. I  M+ W+ U* I9 f+ L) `  ^     57     25      1      1- [, P7 e1 Q( G- \  R
NO MODEL CALLS IN CONNECTION ROUTINES--DYNAMICS SKELETON MAY BE USED' ^( {5 b- @- @3 x6 b
Executing activity CHAN
: m! i" `; @6 J( k1 M+ a
% r. K1 y8 P. c. L5 w- T3 v# d: J6 S      3 OUTPUT CHANNELS HAVE BEEN ADDED
, C1 Q1 X* p) r0 c: h$ x NEXT AVAILABLE ADDRESSES ARE:
: ?! t4 P( D) Q3 F+ O: b   CHANNEL   VAR   ICON  [7 E7 j9 E$ K9 r9 g2 J& U
        4      2      28 b0 N2 ]( G# |4 g( x
Executing activity STRT
: E3 A% b0 A# b, j& g: @1 E6 h GENROU AT BUS      1 MACHINE 1 : X'' =0.25000 IM(ZSORCE) =1.00000* g+ S+ I8 y' o! B# n6 D, O
GENROU AT BUS    101 MACHINE 1 : X'' =0.25000 IM(ZSORCE) =1.00000
, O# s  n' j! x, A GENROU AT BUS    201 MACHINE 1 : X'' =0.25000 IM(ZSORCE) =1.00000% M+ ~4 q+ W, R
GENROU AT BUS    301 MACHINE 1 : X'' =0.25000 IM(ZSORCE) =1.00000. }6 H7 i% T  B' V5 m
     PTI INTERACTIVE POWER SYSTEM SIMULATOR--PSS/E      SAT, JUN 02 2012  15:08
4 Z3 Y; K! q9 F  e  x 1# q2 I+ c! @5 ^% }* t3 o
26 C- l3 a4 ~) W3 J! `2 Z7 h
INITIAL CONDITION LOAD FLOW USED  1 ITERATIONS
4 s1 b4 p0 B2 h. R ----------------------------- MACHINE INITIAL CONDITIONS -----------------------------" S0 {3 [5 y6 _5 Y( [- \# o
   BUS# X-- NAME --X BASKV ID  ETERM   EFD    POWER    VARS   P.F.  ANGLE   ID     IQ
$ h) r: A' c- t- o+ d/ i& e- Q- }) [$ K      1 1           20.000 1  1.0300 2.4652  700.00  185.25 0.9667  70.87 0.7104 0.3249
+ r& ?. g4 e. U- z* I$ r+ A    101 2           20.000 1  1.0100 2.5768  700.00  234.84 0.9481  59.45 0.7504 0.31095 ?8 l; ^- J- G4 o5 T9 u/ v
    201 3           20.000 1  1.0300 2.4910  719.00  176.22 0.9713  44.98 0.7270 0.3303
0 T1 x  @* R8 P% `6 F    301 4           20.000 1  1.0100 2.5189  700.10  202.33 0.9607  33.50 0.7359 0.31810 v$ f$ v; ^+ W' ?8 n
INITIAL CONDITIONS CHECK O.K.
+ x4 X4 E5 L& h# i8 |7 e# G2 d SNAPSHOT STORED IN FILE D:\PSSE30\EXAMPLE\4g2a.snp AT TIME =  -0.0208 {; _; d4 b" F' `) u
CHANNEL OUTPUT FILE IS D:\PSSE30\EXAMPLE\4g2a.out
% x0 t: E8 O' F  g9 C3 z NETWORK NOT CONVERGED AT TIME =  0.1700
+ P+ h$ X% C& p6 g6 C0 F; r  26   191.996    801 [9           230.00]     0.1697E-01     0.8974E-02
% B, ?2 @( t& b: B5 [$ f$ FDecimal number outside allowable range!9 H8 k7 ]) c. n8 I
CHANNEL OUTPUT FILE IS D:\PSSE30\EXAMPLE\4g2a.out8 S% O9 v1 X- _
( \3 }9 z. f( K; F8 G8 i" f% M4 l$ y* Y9 V2 S- _% E
潮流数据预处理应该没问题,dyr文件只包括发电机模型,用PSASP6型模型仿真结果正常,到PSS/E就出问题了
1 {  R( j  _- @! Q7 ~ QQ截图20120602151855.png : e. p0 h1 ?+ u& x6 q2 K
最后两项饱和度是自己随便写的,其他数据来自kunder的书
    2018-9-17 09:22
  • 签到天数: 4 天
    累计签到:4 天
    发表于 2012-6-7 01:07:16 | 显示全部楼层
    问题很明显,你在执行STRT初始化操作时提示:
    % t) Z) S1 I) C, h( O! `, M. hExecuting activity STRT3 {3 @6 i1 H4 A. W
      J' @# p/ S/ PGENROU AT BUS    101 MACHINE 1 : X'' =0.25000 IM(ZSORCE) =1.00000
    ' i+ `. H; H: I: x# J5 u9 A) y  xGENROU AT BUS    201 MACHINE 1 : X'' =0.25000 IM(ZSORCE) =1.00000- Y7 B: o% ~+ H5 F4 g
    6 w& T; ^2 e) N8 b+ G7 ?( n4 }, }: G! X( Y
    这表明,你在潮流数据中的ZSORCE(CONG操作中将发电机等效为Norton电流源就是用的这个ZSORCE)与动态仿真中的发电机的次暂态电抗X"不相等。两个不相等,仿真就是错的。/ i6 K( ~. j" M) M
    这就是问题的所在。4 Y/ R9 \8 i! A
    看起来你的X"可能是对的,ZSORCE用的的默认值1.0,那么将潮流数据中发电机的ZSORCE的电抗值改为对应X"就可以了。
     楼主| 发表于 2012-6-7 12:46:15 | 显示全部楼层
    厉害!!!光看INITIAL CONDITIONS CHECK O.K.去了8 X; S* [  a6 }, v- B0 m
    多谢
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
    发表于 2012-6-7 14:54:02 | 显示全部楼层
    学习一下。
    2017-9-26 15:28
  • 签到天数: 21 天
    累计签到:21 天
    发表于 2012-6-7 15:17:33 | 显示全部楼层
    看不懂呀
    2019-5-12 15:22
  • 签到天数: 37 天
    累计签到:37 天
    发表于 2018-3-29 20:39:13 | 显示全部楼层
    强啊强啊强啊强啊强啊
    回复 推荐 踩下
    使用道具 举报
    2019-8-27 10:23
  • 签到天数: 13 天
    累计签到:13 天
    发表于 2019-8-14 20:35:29 | 显示全部楼层
    谢谢!谢谢!谢谢!
    回复 推荐 踩下
    使用道具 举报
    2019-12-19 20:58
  • 签到天数: 63 天
    累计签到:63 天
    发表于 2019-8-14 20:44:44 | 显示全部楼层
    同问,哪位大神指教一下?
    - o! ?. R1 J- O& V0 _" G
    回复 推荐 踩下
    使用道具 举报
    GMT+8, 2026-11-20 10:05
