我搭建了一个利用避雷器限制投切并联电容器组操作过电压的模型,未加避雷器就ok,但是加上避雷器后运行总是出错。 % }6 `' V) a2 i0 i. v比如加上避雷器后,如果电容器上有量相间电压的电压表,就会出现下面的出错信息:( j- ~2 h, o+ v- n8 Z" f
KILL = 209. ZnO solution by Newton`s method of 3 coupled arresters has failed due to singularity of the Jacobian matrix. This( q3 Z) _: P) k6 _) D. u/ `
is measured by tolerance EPSILN, which is defined by the floating-point miscellaneous data card. The iteration count is 0, and4 `& y% u" x E9 J: r
the coupled group of arresters can be identified from the knowledge that the first (in order of input) connects bus "XX0055" with 1 ]! l Y8 c! A" P4 c) o, s1 Fbus " ". The simulation time is T = 5.57200000E-02., [* m$ u! Z, v$ I" m7 E0 [, K. h9 j
把三个电压表移除就可以运行。* r1 D: y3 Y0 J C% p/ U& n4 t. a
如果线路中有重合闸,加上避雷器会出现如下出错信息:* K$ w( o+ p6 L/ p0 D7 h" v: B
KILL = 212. A Newton solution for 3 coupled nonlinear elements has failed to converge within the iteration limit MAXZNO = 50. - Q2 G# K3 H% S- J$ r' @The current residual is 3.07126887E+00, which exceeds the sloppy convergence tolerance EPSTOP = 1.00000000E-01. The first of / s) b. L1 G( `) Sthe coupled, true, nonlinear elements (in order of data input) is located in row 4 of the nonlinear element table, and it ! Y& D* D r7 m& \( u+ J+ kconnects node "XX0050" with node " ". The final coupled element is in row 6, and the matrix rank is 3. Finally, the9 K; G) O0 x) T; W* i
simulation time is T = 1.26380000E-01. Possible corrective actions include a decrease in the time-step size DELTAT, an increase, K" `' Y# ~* [
in the iteration limit MAXZNO, an increase in the divergence tolerance EPSTOP, and artificial splitting of the subnetwork in : i* l) ^9 x. X; J! s7 A: [question by distributed-parameter lines (to reduce the number of coupled elements). In addition, it is possible for the user to ) j+ A- k5 K! ?) H/ dmake a solution impossible by unrealistically limiting the Newton corrections. The user should remember that there can be no 9 T9 R J% B! `) qsolution if his bound on arrester voltage is less than the true solution voltage. The bound has a default value of 1.5 per unit, : z: z0 k! E; E; Ralthough it can be changed by a"ZINC OXIDE" special request (columns 57-64, variable ZLIN(2)).# k; r3 N& |' y; B9 P4 T$ Y \
已经试了很久,还是找不到解决办法,实在没辙了,请各位帮忙,万分感谢。
