查看: 2048|回复: 7
避雷器模型如何设置,以及遇到的问题如何解决,请大佬告知
    2020-12-11 11:11
  • 签到天数: 26 天
    累计签到:26 天
    发表于 2019-4-22 19:40:20 | 显示全部楼层 |阅读模式
    错误的提示,但不知道怎么修正。
    - O- w( J0 _- `4 B+ o* U4 X3 D. K& Y* c4 i/ e9 v$ w; F
    4 K& |7 N& O( G2 \; D/ V
    : r/ s5 x$ m/ b4 I9 [/ b3 h------------------------------------------------------------------------------------------------------------------------------------
    . Z( J3 j0 S6 _* v1 C5 [) N
    5 ?$ ]- u+ g+ r) k! @6 C' cERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/
    4 I5 E6 j: b! P; S3 }4 v* o: HERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/6 b& s/ `/ n) N6 a  |: w! i
    4 T  \4 U2 u9 ?5 aYou lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following
    3 n/ I; X: L; C( g' w5 b: M$ D1 o9 Hmessage summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where
    : U5 W/ h$ b! s5 P6 Rthe "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card
    . `" v8 ?; Y) h1 Y# k! c" S* V4 \3 @is generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been) Q% F( H( u& b2 h9 w) R9 T+ N
    displayed, so a copy follows:5 h+ _0 D+ n' p
    "        "6 b+ a7 r- Q7 ~" D" y( D
                  KILL code number                Overlay number               Nearby statement number
    + O+ e5 z# o( L! z" Q. m                        212                         18                               3522- x/ e+ c# z& d5 [: K) {
    KILL = 212.   A Newton solution for  3   coupled nonlinear elements has failed to converge within the iteration limit  MAXZNO = 50.
    1 T/ W9 \% t+ j# JThe current residual is  4.00346276E+01,  which exceeds the sloppy convergence tolerance  EPSTOP = 1.00000000E-01.   The first of2 H0 z4 X; g1 G8 |0 l+ f( k
    the coupled, true, nonlinear elements (in order of data input) is located in row  1   of the nonlinear element table, and it" @2 t; \8 H6 |
    connects node  "XX0023"  with node  "X0006C".   The final coupled element is in row  3,   and the matrix rank is  3.   Finally, the' a; k/ U7 k) h# `7 P% n
    simulation time is  T = 4.40000000E-08.   Possible corrective actions include a decrease in the time-step size  DELTAT,  an increase
    3 b0 C, S0 E$ k- Zin the iteration limit  MAXZNO,  an increase in the divergence tolerance  EPSTOP,  and artificial splitting of the subnetwork  in
    7 s; D; ^, H5 d/ c- U$ [1 A$ bquestion by distributed-parameter lines (to reduce the number of coupled elements).   In addition, it is possible for the user to3 E! B8 w! W* f5 \" @
    make a solution impossible by unrealistically limiting the Newton corrections.  The user should remember that there can be no& j& P# K( x# ?2 A' m
    solution if his bound on arrester voltage is less than the true solution voltage.  The bound has a default value of 1.5 per unit,
    9 }' t$ @  I3 V4 @$ ?0 Q" H$ Yalthough it can be changed by a"ZINC OXIDE"  special request (columns 57-64, variable  ZLIN(2)).
    " X" _; G% o. S( m. F------------------------------------------------------------------------------------------------------------------------------------
    1 A3 N, T. J: s: N# y# `3 @ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/: ?8 X) C4 p4 e' Y
    ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/2 H0 r9 i+ f8 ?) W) ^- l
    # D( w. H* N. n( z
    * s7 R) Z# ~4 {& A, H
    更多图片 小图 大图
    组图打开中,请稍候......
    2021-3-30 19:49
  • 签到天数: 153 天
    [LV.7]常住居民III
    累计签到:153 天
    发表于 2019-5-30 19:55:29 | 显示全部楼层
    强烈支持楼主ing……
    参与人数 1学分 +3 收起 理由
    抢楼评分专号 + 3 很幸运,你获得了抢楼奖励!
    回复 推荐 踩下
    使用道具 举报
    2020-9-28 10:46
  • 签到天数: 49 天
    累计签到:49 天
    发表于 2019-9-5 18:56:39 | 显示全部楼层
    看看,希望有帮助
    2 K  f9 K- Z0 ~2 G/ {
    避雷器相关资料.rar
    158.79 KB, 下载次数: 3, 下载积分: 威望 -2 点, 学分 -5 点
    回复 推荐 踩下
    使用道具 举报
    2021-3-30 19:49
  • 签到天数: 153 天
    [LV.7]常住居民III
    累计签到:153 天
    发表于 2019-9-9 15:34:53 | 显示全部楼层
    把设置面板里面的参考电压数据调大点
    回复 推荐 踩下
    使用道具 举报
    2021-3-30 19:49
  • 签到天数: 153 天
    [LV.7]常住居民III
    累计签到:153 天
    发表于 2019-12-4 08:47:52 | 显示全部楼层
    986305096 发表于 2019-9-9 15:34' v) o  I/ G$ ~' L( D% o
    把设置面板里面的参考电压数据调大点
    4 j+ n' _1 d' {) E本质的原因,还是计算不收敛,可以调大允许拟合误差试试
    ) X. R" \: Z, `. {* V9 {& d
    回复 推荐 踩下
    使用道具 举报
    2021-3-30 19:49
  • 签到天数: 153 天
    [LV.7]常住居民III
    累计签到:153 天
    发表于 2019-12-18 14:42:07 | 显示全部楼层
    我只是路过打酱油的。
    回复 推荐 踩下
    使用道具 举报
    2021-5-31 10:00
  • 签到天数: 56 天
    累计签到:56 天
    发表于 2020-7-31 09:37:21 | 显示全部楼层
    按李云阁《ATP-EMTP及其在电力系统中的应用》p402,把参考电压设定位额定电压的2倍再试试看# q, M* Y; U: A. M
    回复 推荐 踩下
    使用道具 举报
    GMT+8, 2026-11-15 09:51
