查看: 3465|回复: 7
高手进 ATP仿真提示错误
发表于 2010-5-24 09:19:07 | 显示全部楼层 |阅读模式
错误原因在哪里?  高手指点,谢谢!% ^) ]9 y6 O8 x, i! A
& b. t& V3 v# f# h! ?You lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following6 E& w$ G1 W+ g: p$ I
message summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where
  h* t8 w+ P, L2 gthe "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card/ g& R: D: A, J3 }( \. P! |/ `6 s
is generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been
$ F' k( Y, F) K$ udisplayed, so a copy follows:
' R% w, Y$ N% T/ G# y5 J& `+ g: V "  X0002A        "8 C( z5 ^, j. o: f. ~
              KILL code number                Overlay number               Nearby statement number/ P" Y( d" G7 {2 q. D: I% x. a
                          1                         12                               1537$ S2 W" a0 r( x% c; [
KILL = 1.   Storage exceeded for EMTP List Number 8.   See the dimensioned limit in the case-summary statistics below.  The problem
! z6 ]1 b5 E3 l& e7 }+ R, m# zis simply too big for the program as currently dimensioned.  Yet, do not forget dynamic dimensioning as described in the Oct., 1993,. m- w! \" N) r' {
newsletter.   In this case,  edit  LISTSIZE.DAT to increase table sizes,  and then try again.   Of course, such dynamic expansion is
2 E9 ]; u" I! l& s; ~, Ypossible only within limits fixed by  LISTSIZE.BPA  (used by variable-dimensioning program  "VARDIM"  as ATP is to be linked).
5 R/ l9 |. }0 T* Q7 L- _( T/ DSometimes the reason for EMTP table overflow is unclear, and Program Maintenance might wish to inspect the contents of the error2 Y  u; s) s7 `! e9 h2 B
interface vectors  LSTAT  and  FLSTAT.    These now follow.   First comes  LSTAT,  using (12I10) encoding; then comes  FLSTAT,! u& H- T: d2 V% [, I: b
using (8E15.6) encoding:2 x: V/ f+ m4 d# W3 m  V# n' P) T9 S
LSTAT =     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999         0         1
' u2 t0 |- p( g2 x" P/ Q) i7 B4 DLSTAT =        12        73     -9999         8        13         0      1537     -9999         7         6        12         3
7 Q& X: H' h. D8 sFLSTAT =   1.562500E-02   1.562500E-02   1.562500E-02   1.562500E-02   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00
% |' o( b" V8 U7 b- s8 mFLSTAT =   0.000000E+00   0.000000E+00   0.000000E+00   5.000000E+01   6.000000E+01   0.000000E+00   0.000000E+00   0.000000E+00# Z8 Q: p5 u( z) L
FLSTAT =   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00' p  J( \* _5 Z; [% O( d6 P3 c
Yet maybe the user would like some suggestions as to why the table in question  (List Number 8 )  has overflowed.   If such further, f5 V5 ]/ T: Q0 j2 j; z
information is available,  it will now follow immediately ....  @& F& z) o7 G" y; Q6 y5 K* r; u
List 8 stores past history points for distributed-parameter transmission circuits (lines or cables) in modal form.   Each
+ }' ^1 Z2 w1 ~2 `' W1 \' O& apropagation mode requires storage, and there are as many modes as there are coupled conductors or phases (e.g., a double-circuit
! a" d4 X! x& ?+ w2 Dline will normally have 6 modes).  Each mode requires TAU / DELTAT  entries,  where TAU is the modal travel time of the line,
' w+ n" G: n4 z% P$ f% C( U' D7 q6 GDELTAT is the time-step size,  and the division involves integer truncation followed by the addition of unity.
, ]) @/ D& a6 E( @6 x% T& yIn order to effectively trade memory space among the different EMTP tables (EMTP List Sizes), the user must know how many arrays4 ], t1 P- K- N) v: M4 F  _8 y
(columns) there are in each table.  The following tabulation shows the effective multiplicities that are associated with each
* w4 F% x) C; O. R- a' Cindependent EMTP List Size (those lists whose lengths are under user control by means of the EMTP variable-dimensioning program
1 b9 R  w. R7 S- c4 L: S* q. |"VARDIM").
发表于 2010-6-3 11:10:25 | 显示全部楼层
你是做什么的仿真。最好把仿真图贴出来
    2021-2-15 22:47
  • 签到天数: 9 天
    累计签到:12 天
    发表于 2010-6-11 14:04:09 | 显示全部楼层
    hhhhhhhhhhhhhhh
    发表于 2010-6-11 20:07:25 | 显示全部楼层
    不好意思 帮不了你 不太会
    发表于 2010-6-11 21:38:19 | 显示全部楼层
    回复之后看帖子了~~~
    2019-11-15 14:39
    发表于 2010-11-2 15:25:36 | 显示全部楼层
    试着增大步长,此外再检查下各元件参数看是否合理。。。
    发表于 2011-11-17 11:01:59 | 显示全部楼层
    计算规模超过了软件参数设置的限值。
    发表于 2012-2-15 16:30:33 | 显示全部楼层
    路过,顶一下
    GMT+8, 2026-11-20 09:29
