TA的每日心情 | 慵懒 2016-4-21 12:07 |
using System;4 |# ?" z% l; F& v! q" m( u, z! ?
using System.Collections.Generic;0 G8 I7 m" Q3 d( v- g% z8 ]# k
using System.Text;
5 L9 |7 c. ^" `$ Ynamespace ConsoleApplication18 O: J$ A; G# M4 f: f' Q4 q
# i. z# ?2 q4 C+ w class Person8 f: n. Y" K b. }; N5 @
% `6 O0 y5 n t- s. ~; m private string name;
& j, K4 H( s. F6 [ public string Name
2 i" r& u1 Y+ n) h$ g; X {% {9 ? \4 O$ E" B+ @
get { return name; }' Z# @2 v) f# R
set { name = value; }/ ?# P/ c; y. V& w3 B
}, v/ M% J3 v% j- {3 X
s2 b$ _ x: x9 }0 n, _6 e
public Person(string name)
( {0 K( ?( x2 B8 j; O; h* Y/ b. p i) f {3 b/ ?( V# O$ O1 k2 t0 S
this.name = name;
/ Q: Q0 p M" H4 u N }/ p7 g+ D; y" x$ E+ i6 {
}+ X: C& V. M, S- n/ K ~
class Program
" H7 ]2 Z% I* u7 g! H) T% x) b {
3 Y1 X! l9 @8 R. Q static void Main(string[] args)
( w1 d2 |7 N" m" p. b9 E* X9 p1 K% `- E {
; z. |# ]% ?4 T7 Z6 Y string a = new string(new char[] { 'h', 'e', 'l', 'l', 'o' });) @% Q; S/ Q2 y! b
string b = new string(new char[] { 'h', 'e', 'l', 'l', 'o' });- O& } _- ~; [" i G/ {
Console.WriteLine(a == b);
5 s- H' k4 G# t# t3 P$ V* T Console.WriteLine(a.Equals(b));7 p5 f4 l1 m% w9 O
object g = a;
; Y8 L l, R, D S3 |, G q object h = b;5 i7 s( g7 ]% j
Console.WriteLine(g == h);4 W0 |7 `& W' C& W# \- D/ L
Console.WriteLine(g.Equals(h));( _3 r7 q1 U7 J2 x, A/ j- ^ E8 H3 L% Y
Person p1 = new Person("jia");
" I/ k. v* z* h% }9 l Person p2 = new Person("jia");* x3 Q. H5 r9 R+ s. ?! E
Console.WriteLine(p1 == p2);% d+ u5 x$ \' f8 u5 M0 c/ o3 [/ g
Console.WriteLine(p1.Equals(p2));, f7 y) B) E" z* ?& o& E/ m
Person p3 = new Person("jia");
) z* M. [: p9 ~2 h! V$ I, } Person p4 = p3;
5 j5 e: T$ s/ F9 ~7 O Console.WriteLine(p3 == p4);
: i/ {8 N; g# l; y- S Console.WriteLine(p3.Equals(p4));- o6 i; ]1 `' F( ]. F
Console.ReadLine();( v G# c1 e9 ?& v5 P! L
9 C9 K$ v I S+ A8 J3 ~! @$ d }
~3 M' } d/ Z}
; s3 y" k7 I5 y8 v答案为何为true true false true false false true true
- a$ |* j" J6 o! C @, f5 n因为值类型是存储在内存中的堆栈(以后简称栈),而引用类型的变量在栈中仅仅是存储引用类型变量的地址,而其本身则存储在堆中。
, c; y8 ^) N5 r "==" : 操作比较的是两个变量的值是否相等,对于引用型变量表示的是两个变量在堆中存储的地址是否相同,即栈中的内容是否相同。+ S6 i N# F2 J; |# A: J/ m: |6 [
"equals" : 操作表示的两个变量是否是对同一个对象的引用,即堆中的内容是否相同。
3 d% z3 Y F' y 而字符串是一个特殊的引用型类型,在C#语言中,重载了string 对象的很多方法方法(包括equals()方法),使string对象用起来就像是值类型一样。8 f, ~* j) r$ a. ?6 K& G' o! h
因此在上面的例子中,第一对输出 ,字符串a和字符串b的两个比较是相等的。+ ]3 A8 R& m2 `/ o8 V
对于 第二对输出 object g = a 和object h = b , 在内存中两个不同的对象,所以在栈中的内容是不相同的,故不相等。而g.equals(h)用的是sting的equals()方法故相等(多太)。如果将字符串a和b作这样的修改:' N; ~" K* N3 C7 z7 Y$ J& B
string a="aa";$ [( O: s+ T1 G- M$ m2 c. j5 V
string b="aa";
# c/ B- U7 M, z* G7 ?则,g和h的两个比较都是相等的。这是因为系统并没有给字符串b分配内存,只是将"aa"指向了b。所以a和b指向的是同一个字符串(字符串在这种赋值的情况下做了内存的优化)。0 j, v' R2 F/ V0 ^$ ^
对于p1和p2,也是内存中两个不同的对象,所以在内存中的地址肯定不相同,故p1==p2会返回false,又因为p1和p2又是对不同对象的引用,所以p1.equals(p2)将返回false。! z' M8 G K2 N; f# M/ u! P
对于p3和p4,p4=p3,p3将对对象的引用赋给了p4,p3和p4是对同一个对象的引用,所以两个比较都返回true。
' W' j9 B0 n! @1 Y4 iMSDN中就有介绍啊:( S0 s/ x r/ V8 O; @
下面的规则概括了 Equals 方法和等号运算符 (==) 的实现准则:3 Z2 o! E( ~: U. s, }% x3 ^- }
每次实现 Equals 方法时都实现 GetHashCode 方法。这可以使 Equals 和 GetHashCode 保持同步。- |/ y4 b, u5 a
每次实现相等运算符 (==) 时,都重写 Equals 方法,使它们执行同样的操作。这样,使用 Equals 方法的基础结构代码(如 Hashtable 和 ArrayList)的行为就与用相等运算符编写的用户代码相同。6 L6 S/ Z* d: ^1 }2 @ p
每次实现 IComparable 时都要重写 Equals 方法。. B y& N ^5 J% q5 c! e& }7 J" K
实现 IComparable 时,应考虑实现相等 (==)、不相等 (!=)、小于 ( <) 和大于 (>) 运算符的运算符重载。+ ?+ Q8 M' W1 \0 t& _1 ?: V' { A, G
不要在 Equals、GetHashCode 方法或相等运算符 (==) 中引发异常。
1 G7 ?& F- S1 T# e6 @有关 Equals 方法的相关信息,请参见实现 Equals 方法。1 T! k6 j( A' H( X3 O
在值类型中实现相等运算符 (==)6 T2 j0 A5 x$ k( Y. o
大多数编程语言中都没有用于值类型的默认相等运算符 (==) 实现。因此,只要相等有意义就应该重载相等运算符 (==)。
" N, b" u% }1 f: e, Z* g$ o应考虑在值类型中实现 Equals 方法,这是因为 System..::.ValueType 的默认实现和自定义实现都不会执行。
: N ^- E P6 y! D每次重写 Equals 方法时都实现相等运算符 (==)。! X/ N+ s" R8 Y( Q& D
在引用类型中实现相等运算符 (==)# [& T1 T2 G. D, E2 t5 R* j
大多数语言确实为引用类型提供默认的相等运算符 (==) 实现。因此,在引用类型中实现相等运算符 (==) 时应小心。大多数引用类型(即使是实现 Equals 方法的引用类型)都不应重写相等运算符 (==)。* B/ [. N6 z% E; a8 H
如果类型是 Point、String、BigNumber 等基类型,则应重写相等运算符 (==)。每当考虑重载加法 (+) 和减法 (-) 运算符时,也应该考虑重载相等运算符 (==)。$ D6 D/ d0 }, W; u8 b! ^6 b2 m0 n
好了,下面是考题,相信答案大家都知道了。
- \6 [8 Z$ `$ o+ |3 n G Console.WriteLine((2 + 2) == 4);# v4 M) p) G& C8 r" Z0 O
object s = 1;
) d. ]% e! M f ~0 ~8 B object t = 1;% Z J4 S$ f3 c1 \
Console.WriteLine(s == t);$ W) a( p& i+ @
string a = "hello";
$ s% Y# |5 o$ g* R string b = String.Copy(a);
2 H% P( f! Z) S* Y% m) W string c = "hello";: a0 `& q5 `+ }8 x) P% X W/ g
9 b. C/ I! e+ G4 U# ?5 n Console.WriteLine((object)a == (object)b);) g4 Z! g* Z. n4 X- x' ^
Console.WriteLine((object)a == (object)c);( m! ^" M, q* Q/ S7 p; `' r
答案:TRUE, FALSE, TRUE, FALSE, TRUE |
