查看: 10229|回复: 14
RTDS Software
 荐 [复制链接]
发表于 2007-6-16 12:13:39 | 显示全部楼层 |阅读模式
The RTDS® Simulator employs an advanced and easy to use graphical user interface - the RSCAD Software Suite. This software is the user’s main interface with the RTDS hardware. The software is comprised of several modules designed to allow the user to perform all of the necessary steps to prepare and run a simulation and to analyze simulation output. All modules provide graphical representation and mouse driven operation by click, drag, pull down menus, or push button action creating a working environment familiar to the power system engineer." b% n5 w9 w1 F! Q5 U1 O
5 v: k2 h$ O- y, z. ORTDS Simulation has two main software elements:" B7 V  `; v) q4 @: }# c
4 _5 I0 b! |, |, Y6 R- H
1. Graphical User Interface2 E2 D; v3 @3 u' x
RSCAD provides the ability to set up simulations, control, and modify system parameters during a simulation, data acquisition, and result analysis. The modules of RSCAD Software Suite include: FileManager, Draft, Tline, Cable, RunTime and MultiPlot.! K- N  K* B5 ^  v$ w- u
0 N2 v9 @+ \: B) W
    * Details about the RSCAD Software Suite5 ^! m. Z$ x; b
7 R9 P( Q8 K' Z3 M  o7 u# E2. Library of Power and Control System Component Models and Compilers& j- ?- p# u& i* r' t/ B7 ^7 U
The RTDS software also includes a multitude of power and control system component models, which can be used to create simulation cases. These models have been designed and tested by our research team at RTDS Technologies and have been validated and refined by our clients during their daily work with the Simulator.8 G4 W1 _$ d% |& ~4 E9 C% z/ W" q7 D
, r* c2 N' X4 c2 g9 j8 c8 P
    * List of available Power System Models
9 i# N8 I" W2 e* [2 V. U
# a! `; Y: N9 V6 w& y( g    * List of available Control System Models, w. p) X( m  w- ~
4 z, r& W( Z  u: P4 H; N
The Power and Control System Software is an integral part of RSCAD for RTDS®. RSCAD allows the user to select a pictorial representation of the power system or control system components from the library in order to build the desired circuit. Once the system has been drawn and the parameters entered, the appropriate compiler automatically generates the low-level code necessary to perform the simulation using the RTDS Simulator. Therefore, this software determines the function of each processor card for each simulation.
    2018-9-4 16:38
    发表于 2009-5-21 18:18:54 | 显示全部楼层
    good !9 X! P2 b3 E4 o' H0 a2 u
    thanks a lot!!!!!!!!!!!
    发表于 2009-6-19 09:24:37 | 显示全部楼层
    I am working on RTDS recently
    + Z- e& k0 b! e- O6 M/ P: }. `8 Wthank you for sharing this O(∩_∩)O~
    2016-3-17 22:07
    发表于 2009-6-19 23:40:37 | 显示全部楼层
    感觉像是pscad配上几个芯片以实现实时性 没啥特别的
    发表于 2009-8-4 14:47:19 | 显示全部楼层
    学习了,顶楼主
    发表于 2009-9-21 12:35:46 | 显示全部楼层
    听说过,但不知道怎么样。
    2017-6-11 01:39
    发表于 2010-2-3 00:13:57 | 显示全部楼层
    回复 4# dawnchorus
    # ^9 u; a/ x$ `' H9 g1 _( [  N* }& y
    1 w; k0 _. @# t* K3 P    如果像你说的这样,谁还会买RTDS啊,可是要$30w的啊!
    2016-3-17 22:07
    发表于 2010-2-3 12:34:10 | 显示全部楼层
    回复 7# zju_xxf
    , Q  a0 f- m$ S% }( o  ]0 _2 g8 @事实上 本质就是这样的
    2017-6-11 01:39
    发表于 2010-2-24 00:57:27 | 显示全部楼层
    回复 8# dawnchorus
    9 _3 u! h  L- J" s* b( ^% Y. T2 m0 d6 o/ U0 L/ o! k1 ^
    $ {+ u, o7 Q: ^* [    同样仿真几秒,用PSCAD的时间可能是小时的数量级,但是RTDS就是秒的数量级。这就是为什么这东西那么贵还有人买。
    ! h; ?( m4 b, ~  u# C但是RSCAD真远没有PSCAD好上手。。。。
    发表于 2010-6-3 15:00:48 | 显示全部楼层
    GOOD!GOOD!GOOD!GOOD!
    GMT+8, 2026-11-21 11:45
