楼主: 晓夜寒风
Matlab入门(英文)
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-20 15:01:24 | 显示全部楼层
    Branching
    $ |8 b- }2 C2 g$ c  i& I) k: g4 M  SBranching is the construction ( i: L4 l. \  |# j0 \
    % p  t- e# t! Z2 jif <condition>, <program> end
    ' \5 r' l$ y8 {) `; t
    , ^$ R: e" x% r: }- z" w! m1 RThe condition is a MATLAB function usually, but not necessarily with values 0 or 1 (later I will discuss when we can vary from this requirement), and the entire construction allows the execution of the program just in case the value of condition is not 0. If that value is 0, the control moves on to the next program construction. You should keep in mind that MATLAB regards a==b and a<=b as functions with values 0 or 1.
    8 B# r) k9 p+ Q6 r) \; vFrequently, this construction is elaborated with
    8 t. L; w2 t8 f; T! J# A) q$ l7 y( `* H% a  D7 Z6 S
    if <condition1>, <program1> else <program2> end
    ! Y1 s: [. ~( n* B/ b
    ! U; Y7 ~  p/ ?4 z5 R8 G$ aIn this case if condition is 0, then program2 is executed. + d* W+ N: m( @" C, ^9 p. q
    Another variation is
    9 }7 u7 d: I" M/ ^- B" j/ M+ }7 Q" R' i9 A+ m4 a' e4 r5 }; u
    if <condition1>, <program1> % b$ x& l+ F& I# \" C4 T
    elseif <condition2>, <program2>
    7 _+ Y" q  \' A* uend
    # B# x1 e0 E& z! N  H/ x& R; {$ n/ J1 ]
    Now if condition1 is not 0, then program1 is executed, if condition1 is 0 and if condition2 is not 0, then program2 is executed, and otherwise control is passed on to the next construction. Here is a short program to illustrate branching.   i# ~( B* P- r. H, n, ~& k6 Q, j/ J
    6 `) o8 N" ?1 P; J% V1 V
    function b=even(n)2 h% b5 I. n, D3 G* F( U1 u! G
    ! p1 t$ o, f" Z7 R+ g* Q$ \2 N
    % b=even(n). If n is an even integer, then b=1
    ; T, a- {6 _7 [- o  y1 j) O% otherwise, b=0./ W! h: e# b( X5 z, A# t
    7 `4 Z4 p& C% N
    if mod(n,2)==0,
    6 c0 q1 F5 f( L* i4 _( j3 y7 h   b=1;. w! J8 f. l; _7 p
       else b=0;
    ! v: _, i+ R/ V# [, y* v; Hend
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:56:20 | 显示全部楼层
    3 K+ Z5 T5 L  H( a! v
    1 _: W9 o* c4 l3 R- G( P: ?if <condition>, <program> end6 @; g. S& s7 f* H) m% |/ b
    + ^7 [' o: K9 o6 ?The condition is a MATLAB function usually, but not necessarily with values 0 or 1 (later I will discuss when we can vary from this requirement), and the entire construction allows the execution of the program just in case the value of condition is not 0. If that value is 0, the control moves on to the next program construction. You should keep in mind that MATLAB regards a==b and a<=b as functions with values 0 or 1.
    + _* `' B# U" Q  R+ [* w" gFrequently, this construction is elaborated with 1 _( i. _- ?1 l, {
    $ l" m+ m: i, b0 Kif <condition1>, <program1> else <program2> end
    & G+ u/ G" o+ S; Q* P& I% F# A) \: K1 W5 J; R$ @
    8 A) k# C' V5 f+ m& DAnother variation is & u& i# z/ E6 h  f
    , d; E9 N) R9 C$ B
    ( Z9 @! N+ D" m6 P/ K0 j1 Relseif <condition2>, <program2>5 L; A' D. O) r4 m1 H0 R
    end5 n3 g/ w1 s3 ~; b# C
    6 r; L  u! ?" v, u5 x2 f) A  [; fNow if condition1 is not 0, then program1 is executed, if condition1 is 0 and if condition2 is not 0, then program2 is executed, and otherwise control is passed on to the next construction. Here is a short program to illustrate branching.
    0 j* `, {6 @4 o5 e0 p
    ( K+ e) @6 d$ W% i, _9 I" a9 Hfunction b=even(n)9 L2 ~: K5 j# W& s
    % m1 H7 h& P8 K( ^" _4 \/ k- I
    0 D* n' g0 n9 n2 R% otherwise, b=0.' H+ ]  @8 I  i) b9 w) |! T
    , O( ~  b, W5 W" ]
    if mod(n,2)==0,
    & W9 ^* N/ S! Q2 Z   b=1;
    ' ?- d* K5 k9 y: r8 s$ W! o   else b=0;1 i& }7 v, Z" P$ T6 f! K
    end
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:56:55 | 显示全部楼层
    A for loop is a construction of the form
    1 f- [% J7 \, d* P; g$ W
    % j: `% R! F0 R7 [- Wfor i=1:n, <program>, end 9 g! y; r* ?& B. X: U; Y5 E" ?* G
    * E( d/ J0 g1 ?4 E! @Here we will repeat program once for each index value i. Here are some sample programs. The first is matrix addition.
    0 y* g2 `5 t7 ?
    ( z! z. H9 g2 t, `( J! K/ A5 V- `4 X! Y6 b
    function c=add(a,b)
    6 i1 d2 R5 e" l* D6 V, |( t- Z* [; @' O; d5 b  ]. J9 d
    % c=add(a,b). This is the function which adds 1 c  F) H& O8 K" X; `$ Q- i
    % the matrices a and b. It duplicates the MATLAB
    4 Y, ~/ {: E& F0 {1 [: g3 T% function a+b.' k: a9 R8 ]9 t
    9 n- y" W: p# b6 Q$ U
    [m,n]=size(a);5 U9 a( z: |$ |) v9 l# {+ u5 Q
    [k,l]=size(b);1 {: H+ j1 K' O' A  i$ M" X/ D
    if m~=k | n~=l,
      m% _- t$ P; j1 E   r='ERROR using add: matrices are not the same size';& U$ v- d: c3 H8 W6 R) \
       return,
    & V. \" E. y# S4 W8 O* E) Oend# j" x; e7 ?4 M5 J. a
    c=zeros(m,n);
    % l, p( F+ Y3 p: C. U) gfor i=1:m,: o( f5 M9 k, V
       for j=1:n,
    3 K# F  i4 u+ S- R* C      c(i,j)=a(i,j)+b(i,j);) B6 E7 E3 Y8 `: X. W( n. |5 o
       end
    ) ~! n5 O2 ^7 Y! z" Z0 ]" ]5 v7 mend% K* O5 p! o! u4 M0 t
    ) b! P# c) k% I% s' ?% s7 b4 jThe next program is matrix multiplication.
      W# G" E# O( R. h3 m, i  m& H; i/ G4 A5 `5 R( I+ R
    $ Y! y6 Z) X% S$ P( ~) L% hfunction c=mult(a,b)
    : Q8 |7 N8 B2 F6 C
    + ^. p, m9 I& Q# K% c=mult(a,b). This is the matrix product of ' O3 I  v9 D9 Y
    % |* P1 X2 u0 i/ F2 F) P4 U. U8 n% function c=a*b.% \: y7 J: R. T' D: g- Q
    , x5 a% g! ]2 N( D  p2 \  m[m,n]=size(a);7 u  }8 x  c6 \- g6 L
    [k,l]=size(b);
    8 ?4 R8 g+ B$ q8 \" ]( M& iif n~=k,
    / ^& l! Z$ X) N7 l   c='ERROR using mult: matrices are not compatible " j' M' r3 p$ t. ^2 i5 N5 r
          for multiplication',6 j# D3 n0 v% E9 w' }
       return,
    ' z+ U4 ^3 P  j# Qend,+ K+ `: H" B3 P5 r
    c=zeros(m,l);( D0 v- ]4 U3 a# t
    for i=1:m,
    : z+ W) |6 j. D, V( [& W) [6 {5 ~% E   for j=1:l,
    # ~: ?6 j" c9 o( K9 X; K      for p=1:n,. s4 ]( j- V: `( `" \* t$ b1 F
             c(i,j)=c(i,j)+a(i,p)*b(p,j);) o/ }/ Q3 @' o- F1 Q+ s+ M, z
          end
    ' E2 ^* Y9 t( p, L* L1 x8 A5 O, @   end
      k! v5 L' L+ O" l7 y" r$ eend  l! Q! ?/ J9 ]8 }* b) {
    6 }9 A* b$ Z- c9 _9 P! @; v
    For both of these programs you should notice the branch construction which follows the size statements. This is included as an error message. In the case of add, an error is made if we attempt to add matrices of different sizes, and in the case of mult it is an error to multiply if the matrix on the left does not have the same number of columns as the number of rows of the the matrix on the right. Had these messages not been included and the error was made, MATLAB would have delivered another error message saying that the index exceeds the matrix dimensions. You will notice in the error message the use of single quotes. The words surrounded by the quotes will be treated as text and sent to the screen as the value of the variable c. Following the message is the command return, which is the directive to send the control back to the function which called add or return to the prompt. I usually only recommend using the return command in the context of an error message. Most MATLAB implementations have an error message function, either errmsg or error, which you might prefer to use.
    1 C( L9 k, t1 E% s' D+ ?. _+ P# F1 |: |- t9 `- X) x
    In the construction 1 e" z* d. C+ M( F
    ; y9 K8 Y+ s; r$ k- ^for i=1:n, <program>, end
    0 g( b' ^3 l$ p7 M& C
    # E; q& x8 z$ s; c# ithe index i may (in fact usually does) occur in some essential way inside the program. MATLAB will allow you to put any vector in place of the vector 1:n in this construction. ) d6 _7 c; n- K, X9 U2 |% b6 C1 a
    Thus the construction " ]  }0 ^9 K/ E* A6 [
    ' {# V: W$ W) l+ o' V! Afor i=[2,4,5,6,10], <program>, end
    $ J+ E2 E7 y  {* f9 K0 B- P( R  @, f2 n
    is perfectly legitimate. In this case program will execute 5 times and the values for the variable i during execution are successively, 2,4,5,6,10. The MATLAB developers went one step further. If you can put a vector in, why not put a matrix in? So, for example, 4 _5 O+ M+ G) H' T4 w5 l
    for i=magic(7), <program>, end
    6 l2 i! T$ B* a* V' c' C8 \7 a' d1 b3 j- i: x/ ?
    is also legal. Now the program will execute 7 (=number of columns) times, and the values of i used in program will be successively the columns of magic(7).
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:57:15 | 显示全部楼层
    A while loop is a construction of the form . ~4 O0 R/ r) m3 t
    - t4 p; s8 u' W7 r' M" t% u, Y
    while <condition>, <program>, end
    9 l$ E+ N4 f+ T: p* A7 e1 H: b& y5 _9 Z1 `0 m
    where condition is a MATLAB function, as with the branching construction. The program program will execute successively as long as the value of condition is not 0. While loops carry an implicit danger in that there is no guarantee in general that you will exit a while loop. Here is a sample program using a while loop. ; d6 p8 ?" U" w8 p, V- L' T
    7 m; v8 H& t. W( {+ z8 i7 f
    function l=twolog(n)
    8 A5 t& S; e# [
    . G5 q# Y3 V" D, J$ B+ s% l=twolog(n). l is the floor of the base 2
    ) W. f" {( d# b" K( \0 [% logarithm of n.! M+ f" V. {4 B& ?3 n
    1 a) a$ g+ F( s, C1 ^% \
    l=0;8 F9 i9 \' u) }0 i6 O2 [+ J: {' A
    m=2;
      _9 L% Y- L6 f  E; ~7 mwhile m<=n
    " M! x; _: J+ A" [   l=l+1;" C& q" \! \/ J' f& ~# m
       m=2*m;
    , K8 ^, S( a. r* J, W/ N% ^/ uend
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:57:35 | 显示全部楼层
    Recursion* b+ _$ k! ?- ~' o* v5 P, ?2 L, y5 Z
    Recursion is a devious construction which allows a function to call itself. Here is a simple example of recursion
    9 B0 b+ ~3 e' h7 K/ i5 \+ ~6 e. D& s- G) W
    . V/ V: N  q4 ?+ c
    function y=twoexp(n)( d7 y% u3 j; G7 J/ K
    6 W! @$ r+ T+ I& ]1 u* z' \3 n% y=twoexp(n). This is a recursive program for computing! x7 f: g9 h7 h7 y( N+ o
    % y=2^n. The program halts only if n is a nonnegative integer.. {2 T; ^% Z2 ?; y0 A
    9 T! ^) c2 R2 X  Fif n==0, y=1;! p4 Y' r6 J2 ~/ G8 _6 x0 e- t
       else y=2*twoexp(n-1);
    3 X9 Y8 T  F# R7 L2 U2 |  v- Iend  D9 X( c& O8 c( s% ?; r
    " m; x: n$ e# q7 t
    The program has a branching construction built in. Many recursive programs do. The condition n==0 is the base of the recursion. This is the only way to get the program to stop calling itself. The "else" part is the recursion. Notice how the twoexp(n-1) occurs right there in the program which is defining twoexp(n)! The secret is that it is calling a lower value, n-1, and it will continue to do so until it gets down to n=0. A successful recursion is calling a lower value. / N4 @: k; `1 {+ I1 p- ~
    + P8 Z* _6 r& N# NThere are several dangers using recursion. The first is that, like while loops, it is possible for the function to call itself forever and never return an answer. The second is that recursion can lead to redundant calculations which, though they may terminate, can be time consuming. The third danger is that while a recursive program is running it needs extra space to accomodate the overhead of the recursion. In numerical calculations on very large systems of equations memory space is frequently at a premium, and it should not be wasted on program overhead. With all of these bad possibilities why use recursion? It is not always bad; only in the hands of an inexperienced user. Recursive programs can be easier to write and read than nonrecursive programs. Some of the future projects illustrate good and poor uses of recursion.
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:58:01 | 显示全部楼层
    Miscellaneous Programming Items5 \' }9 ?7 Q. F+ u( d: T& i: u3 ]7 W
    It is possible to place a matrix valued function as the condition of a branching construction or a while loop. Thus the condition might be a matrix like ones(2),zeros(2), or eye(2). How would a construction like . a+ g. c4 y3 H& ^2 w4 P+ Q1 I
    * f% t3 B/ s3 o( Q' D- ^
    if <condition>, < program1>, 1 a8 J$ t- _( m! J7 K) e  h& O
    else <program2>, end4 w2 a6 i2 O2 ^
    / j/ T/ _. ]8 q4 I* e6 f
    behave if condition=eye(2)? The program1 will execute if all of the entries of condition are not 0. Thus if condition=magic(2), program1 will execute while if condition=eye(2) control will pass to the "else" part and program2 will execute. # p& z! t  O; s, O* s
    A problematic construction occurs when you have
    9 _3 @3 C7 n6 \& b3 n
    - m7 F5 U! G) u% ?if A ~= B, <program>, end.
    * }7 |3 s2 q+ s( j, a% v! k3 ]2 c$ R3 S3 T/ s" ^
    You would like program to execute if the matrices A and B differ on some entry. Under the convention, program will only execute when they differ on all entries. There are various ways around this. One is the construction 7 D( S6 S# J" X! d) m- v1 x8 w
    if A ==B  else <program>, end) M& j* U: Q/ N+ l
    0 ?8 l+ I& V; ^6 L) @
    which will pass control to the "else" part if A and B differ on at least one entry. Another is to convert A==B into a binary valued function by using all(all(A==B)). The inside all creates a binary vector whose i--th entry is 1 only if the i--th column of A is the same as the i--th column of B. The outside all produces a 1 if all the entries of the vector are 1. Thus if A and B differ on at least one entry, then all(all(A==B))=0. The construction - q+ e# o( O: s6 s
    if ~ all(all(A==B)), <program>, end
    & e: n+ V! r1 s8 W/ n  E  s3 R6 Y4 b# M! N4 g- N/ Z
    then behaves in the desired way. " F6 t  i2 ?8 g3 D% R
    Essentially, the same convention holds for the while construction. 6 |/ K, ?6 g- b* ^+ l5 O3 n
    * S" o( m! a6 ?while <condition>, <program>, end.. A* G/ E' p1 N8 G- U
    - _+ v1 B: S0 W1 k% eThe program program will execute successively as long as every entry in condition is not 0, and the control passes out of the loop when at least one entry of condition is 0. ' h/ u2 U( N- S
    Another problem occurs when you have a conjunction of conditions, as in
    4 ]/ B) J+ }( b  {) j1 T9 t! ]6 ^5 F) i0 ^. x6 F
    if  <condition1> & < condition2>,
    $ ?! m1 l! K5 P+ f/ a5 n<program>,  end8 M5 M' c2 e" m( q, x5 |
    5 T/ X! x+ _* }- \! c$ _" _
    Of course, program will execute if both condition1 and condition2 are nonzero. Suppose that condition1=0 and condition2 causes an error message. This might happen for
    5 y, V2 L% @- p2 }i<=m &  A(i,j)==0 5 ~- Q: V3 U  C4 X
    . ?3 k& h  S. r% g8 x2 m; ~, p0 w3 `
    where m is the number of columns of A. If i>m, then you would like to pass the control, but since A(i,j) makes no sense if i>m an error message will be dished up. Here you can nest the conditions. " Z: C7 p$ D1 B  a; F
    * f4 `- P: r+ r3 pif i<=m,7 O) _. A* G" j% c; {, S
       if A(i,j)==0,' K6 U7 `9 Q9 u( ?
          <program>
    " g$ y. l$ b& q% U; L& Y( v4 H6 `   end& |! {: U& J* D4 a; x5 W. u% t
    end
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:58:21 | 显示全部楼层
    Scripts) N7 l, Z" O) T+ a7 I' S  ]
    A script is an m-file without the function declaration at the top. A script behaves differently. When you type who you are given a list of the variables which are in force during the current session. Suppose that x is one of those variables. When you write a program using a function file and you use the variable x inside the program, the program will not use the value of x from your session (unless x was one of the input values in the function), rather x will have the value appropriate to the program. Furthermore, unless you declare a new value for x, the program will not change the value of x from the session. This is very convenient since it means that you do not have to worry too much about the session variables while your program is running. All this has happened because of the function declaration. If you do not make that function declaration, then the variables in your session can be altered. Sometimes this is quite useful, but I usually recommend that you use function files.
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:58:47 | 显示全部楼层
    Suggestions
    4 K* L( b% C* k- F6 Y+ j8 GThese are a few pointers about programming and programming in MATLAB in particular.
    $ S  K9 `7 m( n/ w
    8 e' H! c7 J3 S1) I urge you to use the indented style that you have seen in the above programs. It makes the programs easier to read, the program syntax is easier to check, and it forces you to think in terms of building your programs in blocks. : ^5 ^0 x. g: @$ K
    ) }6 \/ L8 z. ?# @& Z% O
    2) Put lots of comments in your program to tell the reader in plain English what is going on. Some day that reader will be you, and you will wonder what you did.
    % p( a( L" A7 d1 d1 l1 O* ^
    8 a- Z( U+ H- X' D! E& t7 N3) Put error messages in your programs like the ones above. As you go through this manual, your programs will build on each other. Error messages will help you debug future programs.   g/ o7 @2 Q, b1 r
    ! y( C. x7 F  U% c' s4 i
    4) Always structure your output as if it will be the input of another function. For example, if your program has "yes-no" type output, do not have it return the words "yes" and "no," rather return 1 or 0, so that it can be used as a condition for a branch or while loop construction in the future. 7 a+ X. S6 k* G
    $ l7 U2 c7 o3 C* G! W/ z; i# N
    5) In MATLAB, try to avoid loops in your programs. MATLAB is optimized to run the built-in functions. For a comparison, see how much faster A*B is over mult(A,B). You will be amazed at how much economy can be achieved with MATLAB functions. * Y" Y, n8 P" ]( [3 a& j
    $ y& y- v$ R: L# x' b+ \6) If you are having trouble writing a program, get a small part of it running and try to build on that. With reference to 5), write the program first with loops, if necessary, then go back and improve it.
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:59:02 | 显示全部楼层
    MATLAB demonstrations1 A- X% y. a5 w
    Matlab is shipped with a number of demonstration programs. Use help demos to find out more about these (the number of demos will depend upon the version of Matlab you have).
    ! X6 z( ~9 Z7 C/ Q0 \  `. P& ]
    - D& d5 d' P3 _  S+ Y6 K* ESome of the standard demos may be especially useful to users who are beginners in linear algebra:
    ) Q; D5 Z9 A( ^
    . P- B8 F( |5 [( ^5 ]demo - Demonstrate some of MATLAB's capabilities.
      Q) V( \5 k5 T* z0 Q* L7 w$ n# Q' p  J5 G5 Y( v' {: I
    matdemo - Introduction to matrix computation in MATLAB.
    . X) Z# n, G- l. p  S5 f/ p
    & v2 v% m9 `4 h' r+ ]rrefmovie - Computation of Reduced Row Echelon Form
    2017-7-12 08:29
  • 签到天数: 7 天
    累计签到:7 天
     楼主| 发表于 2010-1-21 09:59:19 | 显示全部楼层
    Some MATLAB built-in functions; Z; U9 q: |$ {
    This is a list of functions available in Matlab as of 1984, which should be taken as a quick reminder of the most basic tools available. See the Matlab help screens and excerpts from those screens reprinted in section Some MATLAB function descriptions. In any case, your version of Matlab may vary slightly. - i" c8 T7 }4 N$ r  O
      q' A1 y* j+ E2 O
    intro    <        chol     end      function lu       quit     sprintf
    % X; j. U" u- R- G$ G: ]4 zhelp     >        clc      eps      global   macro    qz       sqrt
    : T0 E" i) \" ^, ydemo     =        clear    error    grid     magic    rand     startup  . S3 L5 s( w7 W) M3 [
    [        &        clg      eval     hess     max      rcond    string
    - {( t" i/ d: G# P, {]        |        clock    exist    hold     memory   real     subplot  3 j0 O! [% ]$ j0 L# ~/ C
    (        ~        conj     exit     home     mesh     relop    sum      2 b- R& b9 E3 x' o2 \9 H
    )        abs      contour  exp      ident    meta     rem      svd
    ' ^  p$ [" x0 M3 z9 ?$ L- i- k& s.        all      cos      expm     if       min      return   tan      2 P' x2 S! p3 ]8 U6 S  v+ ?' t  F5 \
    ,        ans      cumprod  eye      imag     nan      round    text
    6 {- |* a8 ?; R& C% i7 h) B# Y;        any      cumsum   feval    inf      nargin   save     title    9 {& J0 M7 ]( w! @  b/ P
    %        acos     delete   fft      input    norm     schur    type
    " S5 ^4 o8 x8 _!        asin     det      filter   inv      ones     script   what     9 \+ t" A( p4 W+ _% q+ S; k- N' t# w
    :        atan     diag     find     isnan    pack     semilogx while
    + c& ]9 l* J- O'        atan2    diary    finite   keyboard pause    semilogy who
    - t4 r, O1 D0 }0 G9 X. T  W+        axis     dir      fix      load     pi       setstr   xlabel   " I. l( _$ l6 u4 m3 Q+ H$ `
    -        balance  disp     floor    log      plot     shg      ylabel   4 A9 `+ L# v+ f0 b! d
    *        break    echo     flops    loglog   polar    sign     zeros
    5 T( C2 H/ W9 g9 u) z\        casesen  eig      for      logop    prod     sin
    ! O! W, i- D' S8 O4 G- x/        ceil     else     format   ltifr    prtsc    size     / T2 l6 O; X6 \6 t' u+ A5 ~
    ^        chdir    elseif   fprintf  ltitr    qr       sort
    2 C9 D/ o: `4 ?( ]
    6 Q  y1 W( L0 D1 b- T$ W) u& J6 C9 P) e) h' O# Q& n) d4 p8 F( e8 {3 [2 y
    acosh        demo         hankel       membrane     print        table1 ( B& [- i; y. q8 U! Q
    angle        demolist     hds          menu         quad         table2   W  U6 O$ c! x8 T* }# {4 {; ?
    asinh        dft          hilb         meshdemo     quaddemo     tanh
    $ @& |- F* K; p8 n) C, r1 E) P6 Satanh        diff         hist         meshdom      quadstep     tek     7 t7 t6 N0 \7 s4 K
    bar          eigmovie     histogram    mkpp         rank         tek4100
    ) ]  g* M9 S* _7 [7 M* `2 ]bench        ergo         hp2647       movies       rat          terminal
    * H" G  I. o, _/ {+ Bbessel       etime        humps        nademo       ratmovie     toeplitz
    / I/ h' f2 @  D7 f1 f& Tbessela      expm1        idft         nelder       readme       trace     L& m) F  c' N- S; v
    besselh      expm2        ieee         neldstep     residue      translate
    - n' I( E2 _! a% {! {besseln      expm3        ifft         nnls         retro        tril
    # e4 C) v* o5 h8 gblanks       feval        ifft2        null         roots        triu
    3 a4 r9 j$ }. n3 c) hcdf2rdf      fft2         info         num2str      rot90        unmkpp . ?, K, Z! F' P  k  ~
    census       fftshift     inquire      ode23        rratref      vdpol  * a; n  Q" M( a" Z0 s& ~# y1 A
    citoh        fitdemo      int2str      ode45        rratrefmovie versa  & q! O' B0 L: l6 i  u' Z8 r
    cla          fitfun       invhilb      odedemo      rref         vt100  % A3 H- X' a9 V1 P, w; U% ~
    compan       flipx        isempty      orth         rsf2csf      vt240  * F" H0 C' y/ l" b" X; ?
    computer     flipy        kron         pinv         sc2dc        why
    : m* ^. D5 ]$ Z' _- a2 n, ^cond         funm         length       plotdemo     sg100        wow   . b: R0 J- O& U  @
    conv         gallery      log10        poly         sg200        xterm
    + ~- ~) t. h! y5 Nconv2        gamma        logm         polyfit      sinh         zerodemo& W6 U9 D2 s* p% D) D2 n1 o
    corr         getenv       logspace     polyline     spline       zeroin
    ; I' \- D  ~9 V: d7 }8 _  O; lcosh         ginput       matdemo      polymark     sqrtm
    # H! _9 c- \3 Uctheorem     gpp          matlab       polyval      square
    " R; O: }6 O- m" w% N6 Z/ @4 Idc2sc        graphon      mean         polyvalm     std          8 E7 Y, a' P( _0 b  R) D6 s0 ]
    deconv       hadamard     median       ppval        sun
    * q) q$ u+ ?6 ]6 B7 j% F9 {6 C5 E5 ^3 o: c1 Q+ u9 [2 H! S
    9 l. C* G8 G( R( b
    addtwopi buttap   cov      fftdemo  freqz    kaiser   specplot ' [+ [5 q2 ~! X: K7 i
    bartlett butter   decimate filtdemo fstab    numf     spectrum 1 z' w1 D4 o1 s8 ]. `! X
    bilinear chebap   denf     fir1     hamming  readme2  triang   ! B: V. \) E' g3 m
    blackman chebwin  detrend  fir2     hanning  remez    xcorr    0 ]9 \, E: |% m# I+ ]
    boxcar   cheby    eqnerr2  freqs    interp   remezdd  xcorr2
    1 O: \$ q/ g/ e3 b) o8 W- J                                                      yulewalk
    GMT+8, 2026-11-14 05:40
