查看: 2153|回复: 5
英文科技论文中的语言技巧
发表于 2009-8-8 22:53:58 | 显示全部楼层 |阅读模式
a)如何指出当前研究的不足以及有目的地引导出自己的研究的重要性
4 \* z; B  A) r+ b通常在叙述了前人成果之后,用However来引导不足,比如8 P1 g8 T* O' Y" O
However, little information..' t2 p! @! s+ A# Z% @
      little attention...9 C$ b9 E2 j- @% W
      little work..." D. {2 H( I5 {+ K! O
      little data  r) w% L: R8 m& P& ?7 D6 @
      little research* L! h0 ?8 I, n, b
or     few studies
  p. S- Q* P; o$ O- n      few investigations...
0 r3 c$ U% N% O9 ]) g! ]      few researchers...
+ f0 t8 j$ Q+ R( D, [- C1 f+ z      few attempts...
& o1 m, l3 k' j8 w6 M, ~1 l4 for     no: z, p% r9 S% T6 @5 i5 A& v( W  k2 r, H
      none of these studies
- s' W( m2 b* o8 M3 Chas (have) been less
) S1 y9 |( u5 r  m        done on ...6 s  F8 J% V4 J/ n! Y' y
        focused on
/ N; P6 ^8 s6 w, L; H3 B2 {        attempted to
' T& P- d# K1 z        conducted
1 M$ w* H' z1 v; h+ U        investigated
0 G" ^7 M) E* ^9 _9 Z        studied3 |" W+ [% V7 x& I$ Q0 _* X8 r  f
  (with respect to)
0 g" q4 _0 n' g  W$ HPrevious research (studies, records) has (have)2 K$ G3 t1 E. H- R% D* K' O
    failed to consider% \6 i, a0 |8 J* D
    ignored
/ l+ n, B+ }' E3 j5 D4 Z    misinterpreted; s) @4 D8 H: g2 D
    neglected to
( k. J1 k2 }8 {" @- u    overestimated, underestimated
$ e% z+ T4 D% U" a0 b% E% A+ x    misleaded- P  Q1 [6 e+ d* L
thus, these previus results are
! x" N* u. b! Z5 q; I4 q' l5 }0 z7 T  inconclisive, misleading, unsatisfactory, questionable, controversial..
1 X$ s& J1 [& m& x; xUncertainties (discrepancies) still exist ...: Z  y8 h& R+ j- J* C/ g
这种引导一般提出一种新方法,或者一种新方向。如果研究的方法
" |2 `  [% L9 i' X8 ~! b! n以及方向和前人一样,可以通过下面的方式强调自己工作的作用:" B2 h* K" X7 p4 \7 Q
However, data is still scarce6 Q$ W& D' {& E$ n# J/ X4 k
              rare
0 C* c. E6 T  n6 @/ N6 F. \8 K) M              less accurate
" G: n* o3 t! f9 x8 c      there is still dearth of
6 T9 x& N- k1 a0 LWe need to
  J0 D# s' J" O5 V1 y  aim to
: f2 \& x8 x1 u3 g  have to) C5 Q) H8 {: A5 d' P4 a
      provide more documents
& Y7 c. s2 u' _# p. p  V              data
# `* P5 [1 l  Q1 _1 J              records
: |- J: U) `. [6 d' w: Z              studies
' w4 t3 {4 K1 s* G' k      increase the dataset
' X( r  V5 v/ j8 @; Z4 vFurther studies are still necessary...# y, M. r4 W( c( c! C; H; u
            essential...
; h9 E9 Q' D* [$ T为了强调自己研究的重要性,一般还要在However之前介绍自己研究& [" P( y8 e. ?2 x3 m7 `
问题的反方面,另一方面等等
0 N) x7 c5 k* X! R" e比如:, ?( L! b6 N" E0 K4 S' }! p
1)时间问题
# F. O3 W1 X$ }& u4 q7 J如果你研究的问题时间上比较新,你就可以大量提及对时间较老的问题
5 O2 p2 C# f" G! j% e* n4 N的研究及重要性,然后说(However),对时间尺度比较新的问题研究不足
: }$ _/ E* x# G/ w2)物性及研究手段问题
6 q  x. D  u5 j) B) W, |' x如果你要应用一种新手段或者研究方向,你可以提出当前比较流行的方法+ |. F$ }! V0 s+ O0 t; |) K
以及物质性质,然后说对你所研究的方向和方法,研究甚少。
/ j# t$ W, y) j  W$ n& B2 @3)研究区域问题% ?$ T; Z. D$ |
首先总结相邻区域或者其它区域的研究,然后强调这一区域研究不足
0 I. i2 D: [8 l* ?4)不确定性/ X) l. S; Z# i. B9 H7 R: W
虽然前人对这一问题研究很多,但是目前有两种或者更多种的观点,
/ O5 I8 z3 M6 D5 b- \! c1 o" d这种uncertanties, ambiguities,值得进一步澄清5 I3 j0 ~, d4 e9 b! k% g5 J  ^2 I
5)提出自己的假设来验证  h0 |- ^& T, C% ^  v
如果自己的研究完全是新的,没有前人的工作进行对比,在这种情况下,9 b, R+ d" [6 _, M- D
你可以自信地说,根据提出的过程,存在这种可能的结果,本文就是要! a! X2 U: T5 U7 q
证实这种结果。0 L# ?3 i, X9 j6 j
We aim to test the feasibility (reliability) of the .../ y1 ^9 Q; |4 m/ w
It is hoped that the qutestion will be resolved (fall away) with our proposed) t4 u+ X! z- ?) F4 s
method (approach).
# w6 C" @# w, gb) 提出自己的观点
. ?0 a, l" I/ x/ z# ~8 ?We aim to
2 G2 n1 m4 D, N* c+ c$ T$ mThis paper reports on2 [3 d2 f/ S" G% D* O+ I
      provides results) u' v& a/ A+ A% b2 _( W
      extends the method.." l4 F* o$ P+ p4 Y) i; z
      focus on! m6 U8 q$ ~5 \' e) I
The purpose of this paper is to
4 H$ e" O+ o. a9 @1 iFurthermore, Moreover, In addition,, we will also discuss...
3 D! c! p* b. A% k+ x& H5 {c) 圈定自己的研究范围
' G- w4 K0 p, N. H$ ^' M3 W前言的另外一个作用就是告诉读者包括(reviewer)你的文章主要研究
) @1 }2 _3 i; Q7 z内容。如果处理不好,reviewer会提出严厉的建议,比如你没有考虑
: A* c7 ]7 y7 l4 T( U某种可能性,某种研究手段等等。: f4 h( O! t6 M1 ]
为了减少这种争论,在前言的结尾你就要明确提出本文研究的范围:! U6 f* i! R/ q2 }2 g# H
1)时间尺度问题& p; S2 `8 e. s  z( t3 u- H- ~; d% B
如果你的问题涉及比较长的时序,你可以明确地提出本文只关心这- {! l' |" D' L5 D! a
一时间范围的问题。
3 w& O7 s) @+ j% L$ XWe preliminarily focus on the older (younger)...3 F8 G  A0 J' m9 H  T$ u3 [0 t$ a
或者有两种时间尺度的问题 (long-term and short term),你可以说
. p% l- i7 P9 p1 k# t两者都重要,但是本文只涉及其中一种
7 w  P' C6 d) N: U) d' ?; v2) 研究区域的问题
% b8 Q+ |5 R6 B+ y0 w, O8 ^7 F和时间问题一样,明确提出你只关心这一地区* r. l/ {+ H4 A! v+ h
d) 最后的原场6 Z6 d/ C' T( j4 }
在前言的最后,还可以总结性地提出,这一研究对其它研究的帮助。8 ]% [- t" l4 M# z( u0 W
或者说,further studies on ... will be summarized in our next2 ?/ e" J6 p' T' R
study (or elsewhere)
2 S% g' |6 j! C7 K0 a) Z# s总之,其目的就是让读者把思路集中到你要讨论的问题上来。减少" K4 X) U- q$ |. P/ ~: C
争论(arguments).
$ Y( |1 E5 V+ W' w8 P1 m关于词汇以及常用结构,要经常总结,多读多模仿才能融会贯通。0 P- q. p0 \- |4 }% ]9 O  _
-------------------------------------------------------------/ M3 T1 h0 T+ \6 `2 F
怎样提出观点6 I  j0 o- |0 M! c3 }: R0 `
在提出自己的观点时,采取什么样的策略很重要。$ o: I- M" S, n
不合适的句子通常会遭到reviewer的置疑。
+ ?$ z* H) w# v7 s1)如果观点不是这篇文章最新提出的,通常要用! w- I# Q7 z( M% _  D: z. e
We confirm that...
. d* e8 A) r$ f% K1 m* J+ h2)对于自己很自信的观点,可用
2 b9 ~# x; f, g% y& R' kWe believe that...
2 J  R' c6 R$ ?# u. `& C! _* u: V3)在更通常的情况下,由数据推断出一定的结论,
, z/ z1 e5 U/ A& {9 ~" f& p用, Results indicate, infer, suggest, imply that...
$ m% f' s, Q6 o. {4) 在及其特别的情况才可以用We put forward3 X; M6 o1 _. o
(discover, observe..) .. "for the first time".+ W" X+ m& T3 R' h
来强调自己的创新。
9 X3 A( O/ p7 d- F5) 如果自己对所提出的观点不完全肯定,可用8 p* p% Z0 d# q- X: {* I  `6 b
We tentatively put forward (interrprete this to..)+ ?" ^2 l" e2 ~
Or The results may be due to (caused by) attributed to
/ q5 k6 h# W" P) D- Nrsulted from..
  r+ s+ b2 k: h, wOr This is probably a consequence of
- D# M3 S, n3 \It seems that .. can account for (interpret) this..4 d5 ~1 v, @2 [* A# K2 \. I
Or It is pisible that it stem from...# g( q/ B# X0 E0 V8 C
( k8 G+ F! f, `+ F; _连接词与逻辑
. Z9 N8 K$ x" A0 r; _: P写英文论文最常见的一个毛病就是文章的逻辑不清楚。解决
% `4 I1 `5 K" u1 K+ P的方法有:
5 l6 ?9 \, W7 J3 W4 K5 }1)句子上下要有连贯,不能让句子之间独立5 J: d6 ]' y- x" p
常见的连接词语有, However, also, in addition,
/ f$ k4 y- x9 dconsequently, afterwards, moreover, Furthermore,
* _% ]; @* }/ O' m, ^( rfurther, although, unlike, in contrast, Similarly,
7 Z+ M# y1 ^5 S$ T( nUnfortunately, alternatively, parallel results,
6 r! c4 v( I5 n; C& VIn order to, despite, For example, Compared with6 a' t' `( X0 B* ]$ l; \
other results, thus, therefore.../ M! ^6 Q3 P: @1 [; f! w8 k
用好这些连接词,能够使观点表达得有层次,更加明确。
: q& X. U) s# z: y& o: |比如,如果叙述有时间顺序的事件或者文献,& r2 |$ ^* H( f" A; M
最早的文献可用AA advocated it for the first time.- o: `# m3 U/ g) _8 ?# P8 C6 \9 F
接下来,可用Then BB further demonstrated that..
* v% q% Z+ z5 g+ M, ^; x再接下来,可用Afterwards, CC..
2 `& k* @7 M) g如果还有,可用More recent studies by DD..
& s) p) g+ T/ T. E0 Q7 f) J) h如果叙述两种观点,要把它们截然分开
% P8 B4 e; [& @3 \- v6 lAA pput forward that...
0 n' E0 p. \. a& m/ d/ FIn contrast, BB believe
% [9 Y  K8 f2 Hor Unlike AA, BB suggest
+ f" C5 w4 {6 For On the contrary (表明前面的观点错误,如果只是表明
3 X. r9 f7 P5 y7 h( P两种对立的观点,用in contrast), BB..
/ {  w( P4 c* {, F$ @如果两种观点相近,可用
* P8 F0 v& z) _2 u( n  a; nAA suggest
3 X5 n. U2 w% ~; g9 eSimilarily, alternatively, BB..
1 A' \$ A  G0 _# O& S* _0 T& OOr Also, BB1 x7 s$ g, c) O6 f4 V6 V8 Z% `% m. ~
or BB allso does ..
$ f! I% l2 M5 ^3 h1 I# |* y表示因果或者前后关系,可用9 d3 V% R& C9 D! r( C! K- \: P
Consequently, therefore, as a result," J. E$ p1 @; L: _: [, U6 p% {
表明递进关系,可用furthermore, further, moreover, in addition,; A( F: ], k4 F
当写完一段英文,最好首先检查一下是否较好地应用
3 l% F, p$ _  M! N了这些连接词。
( J# j) G; R+ @; K0 o# y2) 段落的整体逻辑! W& ~1 U6 E5 F$ Y8 Y$ V' \: a* {$ w) ?8 H
经常我们要叙述一个问题的几个方面。这种情况下,一定要注意7 ~6 w# x+ R5 u# E2 J
逻辑结构。
3 R* X" g$ g/ R% |. V首先第一段要明确告诉读者你要讨论几个部份! ~0 u5 j; O6 M( `# E- M, [+ J, f8 H
...Therefore, there are three aspects of this problen have to
1 z( t! ^' f/ P1 o; C9 Q* Gbe addressed.% q& K' R* r0 m7 h
The first questuon involves...' b- ~  M$ T" N! x% r, m
The second problem relates to! Z0 G2 B$ h: _  ]
The thrid aspect deals with...
, z- n+ X( e: W/ |/ t# `; z! j上面的例子可以清晰地把观点逐层叙述。$ T' t& H6 V% M, q+ T, R! ?$ Q
Or, 可以直接用First, Second, Third...Finally,..* Y( p! \- k) E3 F
当然,Furthermore, in addition等可以用来补充说明。% V8 L: V' P6 {& ~  V
3) 讨论部份的整体结构9 @5 Q# k1 I) \/ p0 I0 M- N1 f
小标题是比较好的方法把要讨论的问题分为几个片段。/ W/ R+ B& A- ^. ~/ U) t& ^3 `
一般第一个片段指出文章最为重要的数据与结论。补充说明
- p3 N6 i' N4 F的部份可以放在最后一个片段。
2 [5 _7 e$ G: N0 W7 c, C4 H一定要明白文章的读者会分为多个档次。文章除了本专业5 C5 B/ }; f7 @, b& Y8 i' ?
的专业人士读懂以外,一定要想办法能让更多的外专业人读懂。
0 v5 q" i4 d1 C# i2 v所以可以把讨论部份分为两部份,一部份提出观点,另一部份
( T: o3 U/ [, d1 v  G详细介绍过程以及论述的依据。这样专业外的人士可以了解' U% z( l; v; i. U$ b
文章的主要观点,比较专业的讨论他可以把它当成黑箱子,而这一( S# [+ w* Q& _! H$ z
部份本专业人士可以进一步研究。
' q7 z2 M8 Q. W; G( |" |为了使文章清楚,第一次提出概念时,最好加以个括弧,给出
" U+ |1 s; F, n) Y+ c) t* a; D较为详细的解释。2 G9 w' j- [: k. a; j
如果文章用了很多的Abbreviation, 两种方法加以解决- \! k2 [" z. I; q- t& l4 X" V4 I" Z
1) 在文章最好加上个Appendix,把所有Abreviation列表" Q3 ]4 k4 O0 ^
2) 在不同的页面上,不时地给出Abbreciation的含义,用来
: p7 a- l: z, B/ O提醒读者。$ ]7 D" F# S6 N/ Y8 v1 l9 c* @
总之,写文章的目的是要让读者读懂,读得清晰,并且采取各种
& q% y& |! U5 m措施方便于读者。* X0 ?; T& c  j: C
- K1 J. s5 [5 S8 x* B" C! X1 G- w一定要注意绝对不能全面否定前人的成果,即使在你看来$ W( I# n% h0 r) K5 f
前人的结论完全不对。这是前人工作最起码的尊重,英文
, r" o. ]: S5 r' ^) ^* f叫做给别人的工作credits.
1 Z2 W" j2 K, X% R+ M所以文章不要出现非常negative的评价,比如Their results( M2 P5 I/ O; h$ g$ S! Q
are wrong, very questionable, have no commensence, etc.) a$ s1 Z' t& U/ ]  U! [/ j
遇到这类情况,可以婉转地提出:
+ J" i# U* q; s% lTheir studies may be more reasonable if they had8 j$ w5 ~$ L: a: o' X  P
considered this situation.
7 X3 p/ U6 z4 ETheir results could be better convinced if they ...- c8 B8 K4 t* q
Or Their conclusion may remain some uncertanties.' v+ h) D' M' |8 a
讨论部份还包括什么内容?
1 M9 V; |; @/ U3 S. ~; \1. 主要数据特征的总结
& {6 e# d1 P1 N2. 主要结论以及与前人观点的对比
  O$ p9 e5 d. n3. 本文的不足+ j5 D/ Z4 i* a
第三点,在一般作者看来不可取。事实上给出文章的不足恰恰7 y* H% u) m5 H7 D3 K) T; t/ m
是保护自己文章的重要手段。如果刻意隐藏文章的漏洞,觉得( L* T8 ^3 l' D# K1 e
别人看不出来,是非常不明智的。  K# l. Y! y3 J5 s
所谓不足,包括以下内容:. x! b$ ]; Z9 W
1. 研究的问题有点片面
% @/ H! E# B- G" \  讨论时一定要说,
+ e0 m( n' p# O) t! O' n0 k+ v  It should be noted that this study has examined only..# ?: i9 Q" ]3 ~
  We concentrate (focus) on only...- [! g2 l5 @1 s0 n7 r" ~
  We have to point out that we do not..
( O; i/ }! A' _  Some limitations of this study are...
- |5 r  A2 p, Z6 @: T- L2 {6 _/ t3 R  H2. 结论有些不足
1 r. [) \9 |$ f* X: L, K1 NThe results do not imply,
  n) Y& W2 f# p/ ?9 @The results can not be used to determine$ r% e8 d2 p, S3 m8 s
              be taken as evidence of2 w8 \+ B- U' N, N) H% {
Unfortunately, we can not determien this from this data4 K( ^# t9 y3 A( p3 t
Our results are lack of ...  E# F+ i" P2 Z  K$ k( n
但是,在指出这些不足之后,随后一定要再一次加强本文的重要性
* s* S/ I) l3 `# _以及可能采取的手段来解决这些不足,为别人或者自己的下一步. s$ @1 X# f6 K9 l5 ~" u
研究打下浮笔。( h# e( L9 U* {& W$ h9 `# ^0 E, F# {7 L3 ~
Notwithstading its limitation, this tudy does suggest..
+ t* ~0 D) z  G) X' a% zHowever, these problems culd be solved if we consdier' y/ ]5 G) c3 z* A
Despite its preliminary character, this study can clearly indicate..4 {- g, X! N! |2 Z* B
用中文来说,这一部份是左右逢源。把审稿人想到的问题提前
# h$ ^+ }& ~6 j4 }6 d( Y  M给一个交代,同时表明你已经在思考这些问题,但是由于文章+ X* I# _1 X% S& }
长度,试验进度或者试验手段的制约,暂时不能回答这些问题。
. W1 R8 a8 j% _9 e4 o但是,这些通过你的一些建议,这些问题在将来的研究中游可能
; Y: E! C6 q6 E2 e8 k实现。
英文科技论文中的语言技巧.rar
7.86 KB, 下载次数: 3, 下载积分: 威望 -2 点, 学分 -5 点
发表于 2009-8-9 07:34:37 | 显示全部楼层
很有帮助。谢谢。
发表于 2009-8-9 09:03:18 | 显示全部楼层
比较复杂,学习了
发表于 2009-8-9 09:17:25 | 显示全部楼层
英语不怎么样,下下来学习学习
    2020-4-27 20:29
  • 签到天数: 84 天
    累计签到:84 天
    发表于 2009-8-9 11:57:03 | 显示全部楼层
    感谢分享
    2018-10-15 22:30
  • 签到天数: 8 天
    累计签到:8 天
    发表于 2009-8-9 13:19:01 | 显示全部楼层
    好东西,收藏了。没写过英文论文,但这对摘要很有帮助的。
    GMT+8, 2026-11-20 08:56
