基本专业词汇(仅供参考) y0 F& B7 @% ~9 A% n
专业常用英语 ) J: A9 U- V( L0 W8 e: h
电力系统 power system 发电机 generator 励磁 excitation
3 P- Y8 j7 R, V0 s J- I7 O I& Z" S" }- A励磁器 excitor 电压 voltage 电流 current 5 ^/ q; y, E2 E7 U
升压变压器 step-up transformer 母线 bus 变压器 transformer / e1 q: c, P. e9 v9 C8 R0 J$ y$ V
空载损耗:no-load loss 铁损:iron loss 铜损:copper loss
( u8 d' I! G! S2 E. M3 g, j空载电流:no-load current 有功损耗:reactive loss 无功损耗:active loss * [3 }# J) U: W. k
输电系统 power transmission system
4 ~, |( M+ `& q$ ~% T Q8 |! }" ?高压侧 high side 输电线 transmission line
- ~. R) z6 g% x$ x$ F# R高压: high voltage 低压:low voltage 中压:middle voltage ( o2 ~+ D0 `# {' @4 U. ?8 s
功角稳定 angle stability 稳定 stability 电压稳定 voltage stability & R' b9 t% B/ O# }9 G: Z! S! q* ]
暂态稳定 transient stability 电厂 power plant 能量输送 power transfer
8 R& Z7 B( A n- }# j# n. w交流 AC 直流 DC 电网 power system
4 Q: }3 O# d1 A/ Y6 @- p落点 drop point 开关站 switch station 调节 regulation
9 s& d" y- z% T4 v. T高抗 high voltage shunt reactor 并列的:apposable 裕度 margin + V$ p- L) z! H
故障 fault 三相故障 three phase fault 分接头:tap
8 B: m2 S# M \7 o$ x' ~ V切机 generator triping 高顶值 high limited value 静态 static (state)
4 D/ Y1 d( r/ a* R* S. P+ ] C动态 dynamic (state) 机端电压控制 AVR 电抗 reactance
$ c \. Z% y, j/ S5 X8 A# Q电阻 resistance 功角 power angle 有功(功率) active power
& q. F$ N- _% A. [$ O% G电容器:Capacitor 电抗器:Reactor 断路器:Breaker % ], a% R1 F; j
电动机:motor 功率因数:power-factor 定子:stator s2 c% ~3 O; }9 |" S% m! w* ^
阻抗电压: 阻抗:impedance 功角:power-angle 电压等级:voltage grade " A9 ], ~5 g, K, `1 s( f8 `
有功负载: active load PLoad 无功负载:reactive load 档位:tap position 6 J/ x5 O4 K3 }! t
电阻:resistor 电抗:reactance 电导:conductance , h2 I" Q4 K( V4 a$ c- l$ Q
电纳:susceptance 上限:upper limit 下限:lower limit 4 [' t6 P1 z; |2 c
正序阻抗:positive sequence impedance 负序阻抗:negative sequence impedance 零序阻抗:zero sequence impedance 0 U6 w0 b2 T; |+ V* P0 Q1 O: R- |
无功(功率) reactive power 功率因数 power factor 无功电流 reactive current
2 l6 Y7 e) I6 R8 `1 @! i斜率 slope 额定 rating 变比 ratio 9 ~7 ~% g# L. t) h1 f/ T! e' W
参考值 reference value 电压互感器 PT 分接头 tap 7 V+ Y# ^& N8 ^' l& ]
仿真分析 simulation analysis 下降率 droop rate 传递函数 transfer function
" Q( w# |, S: y+ P8 X框图 block diagram 受端 receive-side 同步 synchronization , {% t3 D w2 y- F
保护断路器 circuit breaker 摇摆 swing 阻尼 damping
2 R; g+ f% M6 z& o无刷直流电机:Brusless DC motor 刀闸(隔离开关):Isolator 机端 generator terminal
. m& i8 @; L0 R4 V" E
: H3 Q5 o6 P4 j; h4 J变电站 transformer substation $ y2 Y/ ?! _ r5 c8 B& u
永磁同步电机:Permanent-magnet Synchronism Motor
: J! M) `8 V0 p4 A! X' f3 @5 @; K2 D异步电机:Asynchronous Motor
, ~. y9 ~% Z# T7 u4 S3 }三绕组变压器:three-column transformer ThrClnTrans
. u# a' r& F+ W- a7 N' B% v双绕组变压器:double-column transformer DblClmnTrans 4 H6 [- N1 _2 ~
固定串联电容补偿fixed series capacitor compensation 0 F: n9 @) q% W) P
双回同杆并架 double-circuit lines on the same tower
1 U; v8 [1 z/ [5 P% X单机无穷大系统 one machine - infinity bus system
, q u, ]5 R: g) b. F, V8 B, |1 g
0 Y3 z' l2 |7 h' I# \; b! r+ R励磁电流:magnetizing current 补偿度 degree of compensation & [* Z x- w7 d" d; E: E- s) M9 k" n
Electromagnetic fields 电磁场 失去同步 loss of synchronization ( ^# N4 @0 x d3 S" _- Q/ A3 l! f
装机容量 installed capacity 无功补偿 reactive power compensation
6 L3 _9 p! C5 s- \! M故障切除时间 fault clearing time 极限切除时间 critical clearing time
* @9 O7 y7 g: f% h) H; c" ?( C强行励磁 reinforced excitation 并联电容器:shunt capacitor
% w: |1 Q8 l* B0 J# A< 下降特性 droop characteristics 线路补偿器 LDC(line drop compensation) , A/ W8 [, S$ X4 @8 y8 _" A
3 h3 T9 _- m ~; G/ z: X
电机学 Electrical Machinery 自动控制理论 Automatic Control Theory
9 B- g9 Z7 K; I8 b3 I% q电磁场 Electromagnetic Field
+ ^, o" B1 }& P7 v0 q5 \微机原理 Principle of Microcomputer
0 O* l% F0 q7 X9 _' H电工学 Electrotechnics Principle of circuits 电路原理 & ?( {' i6 g& K7 L! U! c
Electrical Machinery 电机学
0 M8 d$ r4 r/ [" B3 h( f) |; u+ e E: [7 \6 |
电力系统稳态分析 Steady-State Analysis of Power System
9 |* M, q& D# _3 J a/ M: b6 o( X4 E电力系统暂态分析 Transient-State Analysis of Power System 4 l0 M6 ?6 h# C( Z: H% H
电力系统继电保护原理 Principle of Electrical System's Relay Protection 8 ^0 H! z9 d9 e# {1 ~" R& M4 }
电力系统元件保护原理 Protection Principle of Power System 's Element
9 G) }7 i1 @" r# @* j' }* u8 o电力系统内部过电压 Past Voltage within Power system 9 Z% _8 ?0 e% T
模拟电子技术基础 Basis of Analogue Electronic Technique % |, r1 b8 D2 G5 A% Y3 K
数字电子技术 Digital Electrical Technique * M! z$ `9 Y, n: u
电路原理实验Lab. of principle of circuits . R5 q7 f1 p6 G# t# A/ p
电气工程讲座 Lectures on electrical power production ! S! u8 w- t. p" m
电力电子基础Basic fundamentals of power electronics V N7 }- c5 W. W
高电压工程High voltage engineering
7 B3 y* [4 M" r0 f5 o电子专题实践Topics on experimental project of electronics 3 A$ Q' \ a8 J, {2 S% X9 d
电气工程概论Introduction to electrical engineering
1 n- {0 ]; x6 [( C电子电机集成系统electronic machine system
5 a& X6 K& Z8 D7 R; D电力传动与控制Electrical Drive and Control * U, J7 t- w" x* M
电力系统继电保护 Power System Relaying Protection |
