8-Bit, Microprocessor-Compatible, A/D Converters5 E8 |4 i) u7 H8 w# p' I
The ADC0802 family are CMOS 8-Bit, successive-approximation - v) O( x8 B: Z) ]7 ]A/D converters which use a modified potentiometric " N: D& R# \- V! [+ D# tladder and are designed to operate with the 8080A control 5 ?+ U! D/ ^( l, I7 ] x" lbus via three-state outputs. These converters appear to the / E; h' j2 @- Y4 s- ^processor as memory locations or I/O ports, and hence no 1 W( E1 c6 w2 H6 m9 pinterfacing logic is required.$ _) S6 U8 `) V# I I8 C9 p$ w
The differential analog voltage input has good commonmode- 1 S$ u# _2 x0 ]; I crejection and permits offsetting the analog zero-inputvoltage+ x: G& [" o: _" |1 {
value. In addition, the voltage reference input can be ( f( s3 V" X9 Q' Z# Ladjusted to allow encoding any smaller analog voltage span 9 J6 P2 v. f* C( ?# v6 Hto the full 8 bits of resolution.1 o1 N4 E; {1 a$ m; b
