本帖最后由 Tms320 于 2009-12-27 17:46 编辑 & k! G4 u2 r: \' I
$ }6 i% u+ `: f: Dpowerttech 的DSA是用于系统稳定性分析的强大工具,SSAT是其中用于系统小干扰建模的模块。! O8 o4 x% N9 v3 m; O
Main Features 2 C& f. u; b+ b8 X$ \8 H( b. }: DModeling3 Q4 ]$ H$ n( z I- k7 q( Q
SSAT accepts powerflow data in the native formats of DSAToolsTM (PSF and PFB), as well as other 1 `2 X L9 G$ f" F" M* W. Bcommonly used format such as PTI PSS/E format, GE PSLF format, and BPA format.; p+ A& \' B4 F3 \- ]5 Z G! d
Dynamic models of devices commonly represented for stability studies are available in SSAT. Data of+ ~. k2 \* W: H* F
models can be in DSAToolsTM, PTI PSS/E, GE PSLF, BPA format. ' l" i6 F' o6 P& iThe actual dynamic models used in an SSAT analysis can be customized from the data set provided in all: I7 j* p% D/ v$ x M
data files, by using the dynamic representation specifications. 3 G3 T3 c# R8 R9 B+ Y
. G2 w- ^5 V. h) J( z3 h# z
Computation options . Z' A5 `2 Q4 cThere are 11 computation options available in SSAT. These include:* Y1 h3 y" O1 D& K& O1 d6 b
(1) Complete eigenvalue analysis2 O) ^9 N O( |, W8 t
(2) Single-Machine-Infinite-Bus (SMIB) analysis. h7 f4 O5 `5 H( c# d
(3) Single-Machine-Infinite-Bus (SMIB) scan for the entire system # `: z6 n/ ?: n0 H(4) Eigenvalue analysis within specified frequency and damping ranges 7 {3 [: S" S) m( \- f! m(5) Computation of modes closest to a specified frequency and damping 7 r- N3 K, L: ~) D: M(6) Computation of modes related to a generator6 z2 c" p8 q2 t) g/ Q
(7) Small-signal stability index for contingency ranking 7 r/ Z3 {3 Y. M6 `(8) Time and frequency response calculations* s' ]) G B) S4 y. F! ^
(9) Sensitivity analysis 6 m' d' J& x% S7 [6 e8 X- f(10) Small-signal stability limit search ) h: G$ m q3 k" n1 u! |# @1 t0 f(11) Mode trace
