Per IEEE Standard 485, if the operating temperature of a battery (Lead Acid) is different from - n! }7 b6 ^1 Tthat of the library curves used, the temperature correction factor should be applied in calculation5 h4 Y5 J! I5 ~- ]9 l$ C& M
of battery capacity. Table 1 of the IEEE Standard 485 gives a list of correction factors for5 C+ y! a! K# s& I+ X& d$ s3 Z
different operating temperature values, between –3.9 °C and 51.7 °C, assuming that the battery 9 w: S, _" ^2 k3 c% a: Xcharacteristic curves are given at 25 °C.+ Z Z0 x- o* R5 z+ S etap Battery Sizing program determines the temperature correction factor according to this ^& @, f3 j4 U/ ?- Ltable. % K) Y5 R$ W" @/ C2 ?9 Q/ S$ @1. If the battery characteristic curves used in the calculation are for 25 °C and the battery9 n, N4 ^ ]+ F: U
operating temperature is between –3.9 °C and 51.7 °C, the correction factor is determined $ ^ G, w! v6 ~) a0 @by the interpolation method based on the values given in table. " d. r( K" P a' k& M) `0 g2. If the battery characteristic curves used in the calculation are for 25 °C, but the battery * s7 p% X0 U0 E: j0 `8 Uoperating temperature is outside the range from –3.9 °C and 51.7 °C, the correction factor y! v- G. u( K- Q3 J( X# Cis determined by the following equation,: }1 o& T* C- {6 k
y = -2.8117*x^3 + 4.1916*x^2 – 2.4941*x + 1.405 * ]5 q! j0 z% R3. If the battery characteristic curves used in the calculation are not for 25 °C, the correction 5 d+ W( a9 ~3 j% }# J) Wfactor given in Table 1 are shifted and then used as described in the above. For example, if" E+ [ ~/ O) |' G+ Q; S1 N7 t: @0 L
the battery characteristic curves are for 35 °C, the temperature values in Table 1 are! z1 K* p2 @* Z8 Z* M
modified by adding 10 °C. Therefore, the correction factor at 35 °C is equal to 1 and the$ ~# R& N( g R/ [% j% p. s6 D! U
operating temperature range becomes 6.19 °C and 61.7 °C.
