发表于 2015-4-8 15:01:36
你好,我现在运行报错。You lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following6 S0 F* G: t- L# Y% w
message summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where" u2 {% @1 |/ c6 Z2 L9 X: Y' o
the "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card" \! P% K3 h& b6 G) ~+ J4 m1 G% O: b2 |, O
is generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been
# O& f1 X. |# ]* d2 S/ C4 Xdisplayed, so a copy follows:8 h) m4 D" U- l9 h3 x; m4 k4 H
" "2 Q$ f" t9 L% D! n) @
KILL code number Overlay number Nearby statement number
( Q( e/ F3 [! Q8 z 143 2 2114
- r& g. O0 S! g' R( q; j* FKILL = 143. TACS name "XX0039" is associated with a supplemental variable or device for which the input "X0002C" is undefined.
) t; r) A" m( |( p* ^The purported input name is neither the output of a TACS function block, nor is it the name of a TACS source. The name does not. O; j& y& f7 d/ @1 ~. O5 L
identify any other supplemental variable or device, either, at least not any that has been defined prior to the one now being6 Y$ a4 Y3 h) X
considered (as would be required by TACS ordering rules).
* {" `% V9 Z: M4 O) R/ I. n
' [ [6 l R) B) }求解释,谢谢 |
