查看: 3241|回复: 10
plotxy图形不出结果,显示plot必须超过一个节点
 荐 [复制链接]
发表于 2014-1-5 19:38:31 | 显示全部楼层 |阅读模式
3 k! P0 O+ X2 L$ t仿真出现错误提示为:
  \2 H1 M7 c2 N3 N. zYou lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following
; ~  P1 |* H7 i# n8 w  J% G/ f" {message summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where
4 ], E/ n7 r0 Y" n+ n4 qthe "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card
3 P5 q. i6 V$ G& I3 fis generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been% i9 k! e, |, _/ @. c  {
displayed, so a copy follows:
/ n1 p( {4 X6 Q1 S  C6 q$ L "        "
, W! _2 ^, b5 C              KILL code number                Overlay number               Nearby statement number3 {- c  h2 n# `
                        212                         18                               3522
" `) a, s9 P* }/ IKILL = 212.   A Newton solution for  3   coupled nonlinear elements has failed to converge within the iteration limit  MAXZNO = 50.
9 f7 a& h( F- Y* L( I. n4 L+ B9 iThe current residual is  5.15845719E+01,  which exceeds the sloppy convergence tolerance  EPSTOP = 1.00000000E-01.   The first of
2 i, t  q. M1 bthe coupled, true, nonlinear elements (in order of data input) is located in row  1   of the nonlinear element table, and it$ y" @+ Q4 O5 d) i7 I! H: T
connects node  "XX0026"  with node  "VTB   ".   The final coupled element is in row  3,   and the matrix rank is  3.   Finally, the% o" f" Y9 `2 k# T6 C
simulation time is  T = 2.70500000E-06.   Possible corrective actions include a decrease in the time-step size  DELTAT,  an increase. q; ]0 I) R( z
in the iteration limit  MAXZNO,  an increase in the divergence tolerance  EPSTOP,  and artificial splitting of the subnetwork  in7 H: W* }' f: `- p$ C& _! d# Q
question by distributed-parameter lines (to reduce the number of coupled elements).   In addition, it is possible for the user to
" A- v6 m) I+ S  Jmake a solution impossible by unrealistically limiting the Newton corrections.  The user should remember that there can be no
+ K2 Q6 e# u, S) k: I& G2 W; Ssolution if his bound on arrester voltage is less than the true solution voltage.  The bound has a default value of 1.5 per unit,- g; W2 D/ `. x) Z! C
although it can be changed by a"ZINC OXIDE"  special request (columns 57-64, variable  ZLIN(2)).8 V5 @7 L& k# L+ z% |/ d
------------------------------------------------------------------------------------------------------------------------------------+ t0 {/ _1 q' n1 @! ~5 w7 x' K
ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/
' \' ~! `, e/ b8 C6 _8 g( tERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/, F6 S3 ?3 E0 @. B
------------------------------------------------------------------------------------------------------------------------------------: {: E: R5 z; Y0 u
9 b) x$ V. a& h: X
Actual List Sizes for the preceding solution follow.       05-Jan-14  19:31:31/ U6 a& h5 n, D
   Size  1-10:    37    46    25     1   156     9    30 16298     3    18
# Q& N9 V) P: c* O/ J0 B) J, |, ^   Size 11-20:     0    12 -9999 -9999  3511     0     0     0    23     0* g% E9 j+ t" V2 `& N; H& B) ]4 e
   Size 21-30:    55     0    30     3 -9999     9 -9999  1976 -9999     0
% y* g2 C0 l1 B$ s& @) h) lSeconds for overlays  1-5  :     0.039     0.000     0.039  -- (CP: Wait; Real)
+ E3 U$ I5 g$ d/ c- R! ESeconds for overlays  6-11 :     0.039     0.000     0.0393 \# p  I- r6 q$ e5 p* m
Seconds for overlays 12-15 :     0.000     0.000     0.000, P% V7 o$ C2 V3 b5 |
Seconds for time-step loop :     0.000     0.000     0.000# B* G1 Q. d+ T; i  B$ \; P; W1 l
Seconds after DELTAT-loop  :     0.000     0.000     0.000
% {: P- V5 I  m$ n' v4 e. s                               ---------------------------' l" [, M2 }' d
                   Totals  :     0.078     0.000     0.078
2 F8 w: d8 r3 s. q" s0 e/ c
) H, a6 O4 B4 o2 _) x仿真为雷击线路:2 i/ v9 N7 F" q: Z3 I9 T
! b; |1 f, \3 u% V/ `  a8 C4 S% x9 j$ a4 ~+ i; Q, {& M/ j3 `
仿真设置为: k0 Y. n7 E6 E' n/ z8 t  Z; n# X, a
5 I* t' f4 h- a4 n* A6 m5 |  `8 l; |/ p8 F7 y. E8 m
求高人解答
    2021-6-12 00:00
  • 签到天数: 1657 天
    连续签到: 28 天
    [LV.Master]伴坛终老
    累计签到:3190 天
    发表于 2014-1-5 21:12:09 | 显示全部楼层
    顶楼主一下
    2021-6-12 00:00
  • 签到天数: 1657 天
    连续签到: 28 天
    [LV.Master]伴坛终老
    累计签到:3190 天
    发表于 2014-1-5 21:21:14 | 显示全部楼层
    如果是Matlab 的话,plotxy要求有两组对应的数组才可以画
    2019-7-17 16:19
  • 签到天数: 11 天
    累计签到:16 天
    发表于 2014-1-6 08:51:58 | 显示全部楼层
    顶一下  没用过这个
     楼主| 发表于 2014-1-6 21:36:32 | 显示全部楼层
    改了一些参数,仿真出来了,但还不明白怎么回事
    2019-7-17 16:19
  • 签到天数: 11 天
    累计签到:16 天
    发表于 2014-1-7 08:58:25 | 显示全部楼层
    再帮顶
    2020-4-27 10:35
  • 签到天数: 14 天
    累计签到:15 天
    发表于 2014-1-7 18:51:32 | 显示全部楼层
    这个问题我也遇到过,情况和你不一样。我是在运行中点绘图,出现了上述警告,运行到后期(未运行完),依然可以绘图。觉得和ATP的计算速度有关
    2020-5-19 19:34
  • 签到天数: 235 天
    [LV.7]常住居民III
    累计签到:237 天
    发表于 2014-1-9 08:07:08 | 显示全部楼层
    6 V: T% I  G4 @' x- G) o: A1 NThe current residual is  5.15845719E+01,  which exceeds the sloppy convergence tolerance  EPSTOP = 1.00000000E-01. , u* `, M2 {* S% \6 ^% S
    说的是避雷器的问题,伏安特性曲线的问题,采用指数进行拟合,有时候会不收敛,一般修改伏安特性曲线参数,或者减小仿真步长,也可以降低收敛的最小值
    2017-3-7 10:41
    发表于 2014-1-10 09:48:10 | 显示全部楼层
    继续顶
    2019-5-27 11:31
  • 签到天数: 106 天
    累计签到:106 天
    发表于 2014-1-16 10:43:16 | 显示全部楼层
    好,继续努力。
    GMT+8, 2026-11-20 10:07
