查看: 2521|回复: 1
PSCAD在amd64位处理器中出错
发表于 2007-9-28 17:35:26 | 显示全部楼层 |阅读模式
pscad4.2版本,模型在别的机子上可以运行,但在AMD64的机子上不能运行,编译器是Compaq Visual Fortran Professional Edition 6.5,请大侠指点是什么原因。
    2019-6-2 21:23
  • 签到天数: 30 天
    累计签到:31 天
    发表于 2007-10-23 15:51:34 | 显示全部楼层
    上www.pscad.com下载4.2.1.3的update,试试,网站原文如下# e9 n/ F2 m5 C2 Z
    ( S1 x$ ?; c& [) gUpgrading PSCAD 4.2.1 (2006) to PSCAD 4.2.1 (2007)7 ]- U/ n- a$ N% v- r
    7 b& ?% F% f- NImportant: If you have PSCAD 4.2.1 (2006) or a previous version installed, and you want to install, PSCAD 4.2.1 (2007), you need to first remove (uninstall) your older V4.2.x release before installing the 2007 release, otherwise the upgrade may not work. 4 e* J0 E# R& N7 \/ O$ N0 o
    - c+ S! ]* I% d% ~0 v% S4 C! nIf you are running Windows 2000 or XP, then the 2007 build is not needed, just replace the masterlibary as described below. This 2007 update is primarly for users wanting to install PSCAD on Vista, XP64, or Vista 64.
    GMT+8, 2026-11-4 21:19
