发表于 2013-8-14 22:15:32
You lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following
1 N: e7 W3 H X6 gmessage summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where: ?1 d. Y4 o0 T# f
the "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card
! S0 e6 m" ^( ^& W: {is generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been j+ W: n' ~" p6 r
displayed, so a copy follows:
- z+ b7 \2 A5 Y/ K! \ " "
N8 G7 F4 y! q9 \ KILL code number Overlay number Nearby statement number, n6 e8 [1 S( R+ p' Y
212 18 3522
- C; X5 D8 a3 {% h% |3 h5 qKILL = 212. A Newton solution for 1 coupled nonlinear elements has failed to converge within the iteration limit MAXZNO = 50.
0 p, a# @; t; S9 n# sThe current residual is 1.99878365E+05, which exceeds the sloppy convergence tolerance EPSTOP = 1.00000000E-01. The first of9 u' C) _1 z1 M& s8 K3 m6 A
the coupled, true, nonlinear elements (in order of data input) is located in row 1 of the nonlinear element table, and it3 c2 X0 d, k; P2 [) f6 y. p8 x$ f
connects node "XX0110" with node "X0005B". The final coupled element is in row 1, and the matrix rank is 1. Finally, the
: } o3 `- c( Bsimulation time is T = 1.00000000E-06. Possible corrective actions include a decrease in the time-step size DELTAT, an increase
^, X X8 q; M% Din the iteration limit MAXZNO, an increase in the divergence tolerance EPSTOP, and artificial splitting of the subnetwork in
# [0 d, W* U% P# iquestion by distributed-parameter lines (to reduce the number of coupled elements). In addition, it is possible for the user to& k% b, n/ l6 @7 n
make a solution impossible by unrealistically limiting the Newton corrections. The user should remember that there can be no) h b% a- w% i' a, _2 L
solution if his bound on arrester voltage is less than the true solution voltage. The bound has a default value of 1.5 per unit,4 {+ J( d' l' H( S' R0 T
although it can be changed by a"ZINC OXIDE" special request (columns 57-64, variable ZLIN(2)).这是我编译避雷器模型时候错误的信息 求好心人帮忙 看下 到底哪里出错了 很急 谢谢了 |
