问题是conec文件编译后不能生成obj文件,请高手帮看看代码 5 N9 v7 u( P: A2 i4 k$ a& H) T7 _" R# G6 l. z2 c3 B' x
; |/ I2 u5 P" R$ s需要自定义一个逆变器模型,数学模型如下:
数学模型
, V" ?/ S; I4 g
: ?' U1 ^. `* w+ }7 _
Pref (pu) 3-phase total real power reference, per- unit value 0 Q7 G/ ^! e0 s) h. ^4 [vPCC (pu) voltage in PCC, per-unit line-line RMS value & C& m. \8 A* q. K8 U1 EIref_p (pu) real power current reference, per-unit phase RMS value5 j# ]% `3 K2 v0 Q% P- Z8 a
Ip (pu) real power current generated by inverter, per-unit phase RMS value4 M7 n% b7 Y* z* P+ @. f% J. P8 S5 y
( [; E( m1 l5 A/ c" W, Y( q0 h7 B* K4 T5 L( c# s
dyr文件内容如下:0 U) S4 @) d1 I; v
11 'USRMDL' 1 'SLX_G1' 101 1 0 2 2 0 0.01 0.004166666666667 / 9 g0 [. |+ u H: I. o6 b Z" o1 \/ m" Y* r) i9 r! \. Q
+ A% O5 c8 U- e/ V0 Z' Y3 J
第一个con是指参考功率Pref,第二个con是指Tinv ; d9 d3 w1 ]' a8 P) o, `. D ' E# P3 q2 r# h6 j' Q& s+ p" W2 e+ M5 u4 e
首先在生成CONCE CONET的时候,没有出来call语句,psse33版好像都没有call语句了7 V# S; l% L+ V- }
- r$ e' d. y" `, k
' }# Y: C. p% | V* R2 j% [
然后编辑CONEC 文件如下: 8 `' _0 y4 i/ n8 K' b9 d- ^+ B) P8 T5 U' N$ k5 Y2 `
SUBROUTINE CONEC) K' c% {% }2 V. ~7 [9 K
C ! n3 A$ C7 h" }# o' M INCLUDE 'COMON4.INS'3 v [1 E Z& i# x
C+ V4 ]/ n8 {# c+ L
C / z b# u: D' F) t RETURN 8 |# M" E+ G& ^" |. v, \' ~ END# f% i9 Q6 U& ^
# u, W. \" J, f" [9 @SUBROUTINE SLX_G1(MC,ISLOT), U2 b; i$ v5 K9 q
' Q' C8 C7 ~* z6 W9 M5 R( bINTEGER MC,ISLOT* R2 P' Y/ r% v6 d6 @$ D( L
C4 D) _2 F& r5 s7 R$ X
C MC =MACHINE ARRAY INDEX% x% k' F' r% Z% n
C ISLOT=ARRAY ALLOCATION TQABLE INDEX% H2 v: [- c/ f# N2 T3 [" u
C J =STRTIN(2,ISLOT) [USES CON(J) THROUGH CON(J+1) ]5 }1 p v+ i$ u7 M4 X- ?2 i
C K =STRTIN(1,ISLOT) [USES STATE(K) THROUGH STATE(K+1)]. Q! Z4 U( A/ R \0 S+ `: _
C 9 H/ k6 {9 C" {' I , A6 R; U+ G1 Q: ~8 W5 c. ~& N; _$INSERT COMON4 " G' n+ M9 L2 J7 z" uC3 M# D' }2 Z; m4 F$ ^1 X. d
: w: A" R& k/ A; O+ _$ _5 ~6 zINTRINSIC MAX 3 p1 ^3 t: f! R) {& x+ [2 B: v9 Z# x 8 Z5 D- R. U- M6 dEXTERNAL BADMID; j$ c+ Y- L- n! i* [8 ^0 N; e% P
C + o' l, i8 a) i0 x3 V1 [# w" O
INTEGER IB, J, K$ U1 I" g5 _6 I! H
8 K) o1 F. [7 X4 fREAL IP . e# I6 d! S8 c: C0 x/ {* G7 YC $ j# l; o. O: F- I0 L1 P; C7 g$ xC DO NOTHING IN ACTIVITIES ‘DOCU’ AND ‘DYDA’ FOR NOW & U; P9 C _ P4 P1 @% p+ ~( t/ x1 {C & o, k* Y: ^) S9 k# \0 M* L & g X; @1 j: K4 PIF(MODE.EQ.8) % {6 y% {) l ]5 k6 ]# O' H: ]" D: F) i, I. a! S% u
CON_DSCRPT(1)='Pref' # t5 e* x1 T" n, h% i7 H* h) b, M" ~3 R . x8 u# t7 L3 Q* z1 O/ uCON_DSCRPT(2)='Tinv' ) e# I" |% e: @7 H6 M2 O/ {; \5 c
RETURN5 [: M, S2 n% j
N1 |" P7 V$ f1 \ C V+ jIF (MODE.GT.4) RETURN % ~% m s: X3 M" B; c1 sC( W# o ^6 }4 s( g
C BUS SEQUENCS NUMBER NEGATIVE IF MACHINE0 P% Z# r: r7 a* F' S) t" T
C IS OFF LINE,SVS OR INDUCTION MACHINE ' c9 ~ t/ L8 qC 5 {7 S7 L% Q- q( Y : P) M; `( X3 F# L: w9 aIB=NUMTRM(MC) 4 `3 z3 {1 G1 d! f5 ]. Y $ ^. i3 w$ ~( G4 t) H6 f& j7 O, |IF (IB.LE.0) RETURN . u1 |, M+ ?+ p. l# sC- P6 t$ D; L2 {/ o1 a* V4 G) a
, e; ~' |/ j, w5 L$ D0 D
IF (MIDTRM) GO TO 900 ! |# }/ H2 r# J( i& SC - o0 G) q9 |* N* U8 s- \* ]0 TC GET STARTING ‘CON’ AND ‘STATE’ INDICES % R. m! r0 v' Z9 ^' J- wC , Z2 z- J3 T- r8 y Z1 n' Z 9 L, _9 O& _! o! N" {! l* c! B) k0 dJ=STRTIN(1,ISLOT)4 X9 k4 Y9 v% O$ ~
- k8 @6 ^) P. u3 dK=STRTIN(2,ISLOT)% J: I- e8 U+ H6 b
C 2 U6 r3 @ N* T3 U1 x* P1 D& |$ |4 o, a7 C3 q: t5 P& M4 r; h. e
GO TO (100,200,300,400),MODE! o/ n [$ Z7 |8 p( G$ u; @2 ?2 D
C " a$ |+ V; E# Q! N2 SC MODE = 1 – INITIALIZE 0 Y/ n4 e5 j& b1 E! f# q8 `* s' NC+ W) Q- @6 X1 [
3 Y' l% {" {( R/ ]7 A9 K; E9 p: v2 ^! b
100 STATE(K)=PELEC(MC)/ETERM(MC) 0 @: g1 O4 }7 [$ q" O. h% a# s6 l/ Z) l- H+ R8 Y
STATE(K+1)=PELEC(MC)/ETERM(MC) t- H# J& b: k# V0 a
% f3 C: u- r2 M- |4 Y
RETURN# e) J, S: K/ ]
C 1 B; |$ I0 }- F8 U: O3 vC MODE = 2 – CALCULATE DERIVATIVES& i. U2 k4 E, i! g
C 7 _% Y& {& J; q" T9 ?1 V7 U: z- k 6 g& j ]5 k& C7 @1 T/ X9 A, D9 G200 DSTATE(K)=CON(J)/ETERM(MC)6 {3 x$ t( A, n- E# \2 @3 X
b( `1 \- ~# o3 h0 i
DSTATE(K+1)=(DSTATE(K)-STATE(K+1))/CON(J+1) 9 S! x+ q% W L4 R+ z q! v* P; J$ j* m$ X3 ^RETURN" M+ Y: Q& i: X
C + }9 x# M( u0 X( {0 m( t" N8 UC MODE = 3 – SET IP + W: J3 V7 j0 v. a `" x" N$ F) }C 3 P1 R2 ]% D5 E7 i' u4 s p : j+ ^1 u1 R' @/ n( d! N& L300 IP=STATE(K+1) 5 y, h# o4 |. K; P " x+ m3 |, r0 iRETURN( @0 T' U2 R' w. X. G
C " B t% U A X( K# b0 HC MODE = 4 – SET NINTEG " [% Y6 W* y7 b# E& r0 b+ R5 QC. |4 @# J8 r& L/ p# M8 H
0 ]* l2 u e: b
400 NINTEG=MAX(NINTEG,K+1)7 ~( {7 d7 M' R D
$ O3 L4 m1 R2 f; BRETURN " N" L, t: C. Z* fC8 r- C! V4 }% F' ?% ]: x! l
C MODEL NOT IMPLEMENTED FOR MSTR/MRUN 5 e6 N) M1 t* C- l" x9 [C$ v5 R" O+ S0 Q5 C/ u
, x) q+ d/ T5 k307 FORMAT(‘SLX_G1 AT BUS’,16, ‘MACHINE’,A,& n _* L5 A, i s
; B7 S; [9 T3 D
* , ‘INITIALIZED OUT OF LIMITS’)3 A% I" m8 _; }; T
. L* M3 {7 D: p2 p3 a' i/ r2 |( n1 }
END' @- g% {: o: \6 O
+ L1 v. j( M* `4 \8 U! d5 z+ w0 u( Z7 U
( A0 s) h4 x! u# F( W
还有一个问题想请教最后Ip这个参量在PSSE里好像没有内部变量,因为这个是输出变量,现在Ip表示的好像不对,又不知道该怎么解决
