查看: 1405|回复: 5
WIND TURBINE APPLICATIONS
    2020-3-3 14:59
  • 签到天数: 9 天
    累计签到:10 天
    发表于 2013-3-8 18:22:50 | 显示全部楼层 |阅读模式
    PART A: INTRODUCTION 1
    1 G; n( s- Y% S0 [6 J. ]# S- u1. Introduction..................................................................................................................3
    # C4 z! f% u' @- n/ ?" V2. pscad components....................................................................................................5! h  D" z8 p7 l: E
    3. Modelled structure.......................................................................................................7
    0 |/ T* p/ O) T& [( p: ~! Q* G* N4. Simulations performed.................................................................................................9
    $ h0 b5 m3 m; S8 ?$ L, @& ^9 j% bPART B: BUILD THE MODEL 11$ T2 T, L" z' S; ~5 T
    5. From the wind to the Synchronous Generator...........................................................13- ^3 @. X: e+ l. g% i) d
    5.1 The Wind Source.........................................................................................................14
    1 [# c1 j( x3 Q# Y" e; V5.2 The wind turbine component.......................................................................................15* {3 Z$ D6 g1 _/ g- K4 s% O
    5.2.1 Theoretical study...................................................................................................15
    ) I! G  `- Z0 v' {  ~5.2.2 Cp curve with PSCAD standard model.................................................................16  ], Y& o9 _( ?6 g1 e; g) K$ h4 Z. c
    5.2.3 Computation of parameters...................................................................................17# y" A0 l$ F/ g8 z6 J/ Z
    5.2.4 Define the Wind turbine parameters.....................................................................18+ D1 p  A1 J3 h
    5.3 Wind turbine governor component..............................................................................19" z1 E6 o- E7 U3 w4 r) Z7 h
    5.3.1 Theoretical study...................................................................................................19  w4 c7 L# s6 ~. d8 ^, ~& m9 i
    5.3.2 Define the Wind governor parameters..................................................................20) U+ A! ^. R# U/ ]. A! C
    5.4 The synchronous generator.........................................................................................21% {. u+ |& e4 i7 X
    5.5 Turbine generator connection: Simulation at rated load..............................................24
    % ]; ]  q* B3 B+ dSimulation parameters & analysis :......................................................................................24
    . M+ ?# k& j$ J9 G  L9 s6. AC/DC/AC : Power and Frequency conversion.........................................................27
    & D3 C. U& o4 @3 e8 \( P7 ?  f6.1 Diode Rectifier.............................................................................................................28
    $ m: n; f; {$ b2 Y1 H! {7 |  M1 y6.2 Overvoltage protection................................................................................................30
    3 Y* s* M/ u* F4 O. D! ]4 ~6.3 DC bus.........................................................................................................................310 k- R; w& u8 J- c: q. D& V
    6.3.1 Build the DC bus....................................................................................................31
    6 z/ Z4 `/ G) u: |! q: |6.3.2 Model validation.....................................................................................................32
    3 L* r1 s# [# ^) P, Y$ o9 k6.4 6-Pulse Thyristor inverter............................................................................................34 WIND TURBINE APPLICATIONS PAGE A3 y6 O6 ~) C% y! t6 W% M, F+ R9 m* H
    PSCAD®4.02
    & V3 F0 _# m# C. @Introduction7 Y2 A4 W1 c% H, u$ t
    6.4.1 Presentation..........................................................................................................34; V/ Z! n; u7 _4 d. M
    6.4.2 Voltage collapse limitation....................................................................................36
    9 Z( i: j( v/ c% S  Y6.4.3 Voltage regulation.................................................................................................37; W+ [' v3 W1 P6 F1 w% ?
    6.5 Connection to the network..........................................................................................40
    / j) \+ {8 R3 V6 n: v7. The distribution grid...................................................................................................43
    + n( Q" Z1 V! _8 }6 p4 b( B, h' _7.1.1 Definition of the grid..............................................................................................43
    4 s8 ~2 F, D3 F/ a1 [2 E7.1.2 Load Flow Simulation...........................................................................................47! G+ Z0 q- `. e6 m3 |4 S
    PART C: SIMULATE 49- m% ]1 [2 W6 x/ _
    8. Constant Wind Study.................................................................................................51
    + N) V$ a/ v: q1 M( h# |8.1 Structure the complete model.....................................................................................511 K6 \# v. ^* q' ?6 k5 Z
    8.2 Constant wind study....................................................................................................53* ]9 ^3 Q# a; ]1 o
    9. Fault Analysis.............................................................................................................55
    ( V4 s# ~. _8 a; F5 b( Z) a9.1 Default at Node 3........................................................................................................56% k) ^0 Z( E9 C" i: G
    9.1.1 Without DG...........................................................................................................56) P- V" `7 z0 M$ j/ ^+ D& Q
    9.1.2 With DG connected at node 1..............................................................................57$ H+ N: i4 }. k# l/ F7 p
    9.2 Default at Node 2........................................................................................................59* U- {1 _: H# m
    9.2.1 Without DG...........................................................................................................59
    ; E, \6 D: i9 o8 P9.2.2 With DG connected at node 3..............................................................................59
    - W& g; G$ {( D5 h3 ~2 `9.3 Conclusion..................................................................................................................61! y) X: R$ s3 x' r  o# [' }5 G0 v
    10. Variable wind study....................................................................................................63& k+ q- K+ |5 s  q% j3 ]" B* e4 \
    10.1 Dynamic pitch control..................................................................................................63  {1 @0 E/ e4 ?6 z1 Y1 @
    10.2 Passive pitch control simulation..................................................................................67
    8 g6 ^3 W% U9 Z# E2 A( q2 R0 ^10.3 Comparison of passive and dynamic pitch control......................................................69
    % c& R/ }! C+ R/ q: @$ Q' k11. Wind farm...................................................................................................................71
    2 M' O0 j- h% A, G6 L4 t. a7 M11.1 From a single wind turbine to a wind farm..................................................................72
    / Q+ p. y* o9 [) y4 t11.1.1 Change the structure of the model.......................................................................72
    ) B/ F& ^' m2 z2 w9 F* G# {0 s11.1.2 Modifications in the synchronous generator.........................................................73" u1 A7 f9 W2 U
    11.1.3 Modifications in the transformer...........................................................................74
    $ N% r9 X4 }. m11.1.4 Modifications in the grid........................................................................................74
    , f) I, ^( C3 `2 }11.2 PWM Regulation drives...............................................................................................750 y. F- M4 _) |$ O# P
    11.2.1 Principles..............................................................................................................759 ~+ i$ k; z$ U9 Q+ {+ T% W$ W; r
    11.2.2 Generation of the triangular waveform.................................................................75# _0 L/ H3 m5 `: _% G
    11.2.3 Generation of the reference..................................................................................79
    7 n! S5 F9 j4 s5 T; r  D; E11.2.4 Generation of the firing pulses for the GTO inverter............................................836 {# }+ ^2 H, R
    11.3 Simulation 85
      z5 n5 i9 G. N1 @: q. WPART D: APPENDIX 87
    . ~4 F& ~$ {- l9 F+ f' b) O1 O12. References.................................................................................................................89
    WIND TURBINE APPLICATIONS.rar
    1.17 MB, 下载次数: 2, 下载积分: 威望 -2 点, 学分 -5 点
    英文版
    2016-4-4 14:20
    发表于 2013-3-8 19:11:44 | 显示全部楼层
    多谢楼主的分享
    2021-6-12 00:00
  • 签到天数: 1657 天
    连续签到: 28 天
    [LV.Master]伴坛终老
    累计签到:3188 天
    连续签到:8 天
    发表于 2013-3-9 10:43:23 | 显示全部楼层
    感谢楼主的资料
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
    发表于 2013-3-9 10:44:45 | 显示全部楼层
    很好的参考。
    发表于 2013-3-9 16:40:56 | 显示全部楼层
    弥足珍贵,而且还有简单介绍,太感谢楼主了
    2021-6-12 00:00
  • 签到天数: 1657 天
    连续签到: 28 天
    [LV.Master]伴坛终老
    累计签到:3188 天
    连续签到:8 天
    发表于 2013-3-11 11:31:55 | 显示全部楼层
    再次感谢了
    GMT+8, 2026-11-19 07:44
