楼主 |
发表于 2012-12-21 23:04:54
这个应该是rule book中文版的一部分,我没有看过全版的rule book,这是部分目录
/ P0 {; _( d* E7 a( h8 ?2 J1 G引言···········4····································4··································,······························......1
9 {0 }% K/ T5 c$ ?3 d& {工.1模型语言·················4···························································4·····················……19 |, m! |6 H. G: t' t0 Y2 I
1. 2主要特性·4······························································································……1
) h. L7 C1 n" \8 m% S |2.模型描述····················4···························································4·····················……2
) V% H. {, M, ~* o; ~0 X( K" U z.工系统描述................................................................................................. . . 2
% l4 E# W$ ^, \) K3 c4 d Z6 d2 i 2. 2模型表述·································································,···4······················4··……3; a- a1 i9 M& s# H% b
2. 2. 1模型构成·........................................................................................ . , 3
; i1 M6 n% K2 S 2. 2. 2模型定义························································,····························……4 L( J% }' i0 H
2. 2. 3外来模型·································,··················································……‘51 X% M9 a7 F' r& }( \
2. 2. 4外部模型·····················4··································,···························……,fi/ Y: k. o$ r; D5 `7 D; k- K0 j' M
z. 3命令····································································································……了; V/ D3 O. }$ L' i
z. 3. 1分配语句·····················4·······························································……7- _( S" t2 J. c7 b% {+ e
2.3.1.1分配值....................................……‘.................................········……7
0 b4 m+ B- [8 ~$ I4 z/ X0 P6 O0 u' e4 h 2.3.1.2微分方程...........................................................................·········…...7
/ ?' ]4 G# s* s0 j4 ^* }! Q- x 2.3.1.3拉普拉斯转换方程........................……“‘二‘.................................... . . ....9$ s* N" `7 k* m3 h6 `) z
2.3.1.3变换方程....................……J.……“二,.‘.‘............................................1C?/ w9 A& s' c6 x' a' M
2. 3. 2算法控制语句·············································································……11
. b; J" A( W7 z7 ~1 ]. F 2.3.2.1 IF................................……J........……“.‘.............................……11, S# {7 a( \2 P; `' C7 J
2.3.22WHILE..........................……‘..............................................……““‘12+ |0 P$ T& i6 d& n8 z) ^/ q
2.3.2.3 FAR......……“…‘...................................................……,‘...........……12/ |$ t1 E. m7 K1 A# @
2.3.2.4 DO.....................……,..……‘.…‘二“...........................................……13; F. i. T' x7 ` N4 T, V
2.3.2.5 REI30.........……‘…,.…‘..............................................……‘.......……]3( i4 P3 ?- }2 q/ v
2.3.2.b CaMBINE.“.““...........................................……“二‘.“..............……144 c+ O3 N+ r2 Q+ y
2.3.2.7 SEQUENCE......................................……‘.‘二‘..........................··……15+ s _6 _ G2 m4 v/ G( d# E
2.3.2.8 IJSE...................................……,..…,.,......……“,.......................……15+ `% M X! v# z; e) V- e
2, 3, 3仿真命令························································,····························……lfi
- V7 ]! v; Y+ W 2.3.3.1 WRITE.......……‘二“二‘.............................................……“.‘二“...……162 Z' x0 y2 l6 d0 S; k# c" \
2.3.3.2 ERROR.......……“...........................................……““‘...............……17
8 _) _ s. g5 \) k/ P$ V8 k 2.3.3.3 DEP05IT...................……““‘..................................................……‘17
! j5 C1 U O0 R8 r7 v& n+ A5 E1 t 2. 4不变值儿素·························································································4·……17' |& u, H9 t6 T" a
2. 4. 1数组···························4·······························································……1}0 M: z, e' Y0 i6 K: N
2.4.2常数二‘.…,..…‘.,,.,.....……‘.,.,…‘…,..…‘.‘.…‘.18
& D) I7 K7 Z/ P o, ^3 T: e3 n 2.4.3常常量.…‘…‘..……‘..…‘...……‘.……‘..…‘.‘..…18
7 F- s) n) r3 k( H; a7 o5 k6 B( H 2.4.4数据.‘…‘.‘..…‘二“.‘..……‘…‘.‘.‘.‘..……‘…‘.。.‘.19
! I1 B4 A5 b, ` 2.4.5变量……,二‘……“,‘…‘.‘.……‘...........……‘.…2s
6 m: @+ X% O) w' Q. K2 d) W) ^ 2. 4. s长变量二,.,.…‘....... ........................……,..……26: _& X- U. F/ T# A: y
2. 5模型界而.‘.“.;‘。二;‘.““‘.;‘二;“‘;“‘& s- k9 [) q1 q6 h* P9 p# c+ ?- a
2. 5. 1输入.。。,。。。,。。.。.。.。。。,。。。。。。。5 K5 [- c# S- h% w: B; a/ r- @
2. 5. 2输出.…,.,.…‘............……
: ]- A, M, L! d2.fi函数.…‘....……‘..…‘..…‘……& ~! a2 R, W# @
2. fi. 1在一个模型中的函数.…,…,..…, G) e, B2 [( C$ `3 x
2. fi. 2语句函数。.。。。。.。…。.。。。。。。。.。8 a3 C$ O: z p8 P
2 6.3点单函数.,.............. ..…… |
