查看: 911|回复: 1
Matlab
发表于 2012-12-3 20:36:58 | 显示全部楼层 |阅读模式
请各位大神指教,我在做MATLAB电力系统三项故障仿真时,测量A相正序分量总出现仿真无法完成,显示如下:Warning: Output port 2 of block 'cir6/Demux' is not connected.Warning: Output port 3 of block 'cir6/Demux' is not connected.
0 M5 N6 U& e, y; @Warning: Next step size (2.190737403247518e-016) is smaller than minimum step size (2e-016) at time 0.06166377595582589 because distance between zero crossings is smaller than the minimum step size.% A! f8 w" H/ J& t8 t5 S, }, B
Warning: Next step size (2.190737403247583e-016) is smaller than minimum step size (2e-016) at time 0.06166377595582764 because distance between zero crossings is smaller than the minimum step size.
+ }% a; ^4 `$ f  r' Q8 X) \9 v$ MWarning: Next step size (2.190737403247591e-016) is smaller than minimum step size (2e-016) at time 0.06166377595582787 because distance between zero crossings is smaller than the minimum step size.6 i& K0 q; G6 S
Warning: Next step size (2.190737403247599e-016) is smaller than minimum step size (2e-016) at time 0.06166377595582809 because distance between zero crossings is smaller than the minimum step size.6 g' R6 M3 S1 O9 w+ }
Warning: Next step size (2.19073740324763e-016) is smaller than minimum step size (2e-016) at time 0.06166377595582898 because distance between zero crossings is smaller than the minimum step size.
+ l3 \: M# x+ d- p& LWarning: Next step size (2.190737403247638e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558292 because distance between zero crossings is smaller than the minimum step size.
; R* C, \: P& ~# p# `% v+ e/ tWarning: Next step size (2.190737403247717e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583142 because distance between zero crossings is smaller than the minimum step size.
& D$ G+ E# B# g% ]) g6 _# G$ YWarning: Next step size (2.190737403247725e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583164 because distance between zero crossings is smaller than the minimum step size.
' v6 U, ?  g4 F4 OWarning: Next step size (2.190737403247757e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583253 because distance between zero crossings is smaller than the minimum step size.
2 ~3 R% }, ?( X1 v1 A. qWarning: Next step size (2.190737403247765e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583275 because distance between zero crossings is smaller than the minimum step size.
3 N. i3 b  N! k6 v" gWarning: Next step size (2.190737403247772e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583297 because distance between zero crossings is smaller than the minimum step size.1 k3 y0 k' w7 f% e
Warning: Next step size (2.19073740324778e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583319 because distance between zero crossings is smaller than the minimum step size.
7 d# Y/ ]  W9 t' J9 D3 e$ E  ~7 LWarning: Next step size (2.190737403247804e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583386 because distance between zero crossings is smaller than the minimum step size.7 j% Z% }+ g! p
Warning: Next step size (2.190737403247812e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583408 because distance between zero crossings is smaller than the minimum step size.
: Q' ?3 Q* Q2 e  o- W4 D' bWarning: Next step size (2.190737403247843e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583497 because distance between zero crossings is smaller than the minimum step size.# w- h" ~5 m4 L6 V; [
Warning: Next step size (2.190737403247851e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583519 because distance between zero crossings is smaller than the minimum step size.; @; X4 j! {& f9 D! Q% V6 ~
Warning: Next step size (2.190737403247859e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583542 because distance between zero crossings is smaller than the minimum step size.9 g: e6 l  n# j0 B" l: y/ _
Warning: Next step size (2.190737403247867e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583564 because distance between zero crossings is smaller than the minimum step size.
: u' D* q9 K" v2 l& ^$ z: KWarning: Next step size (2.190737403247891e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558363 because distance between zero crossings is smaller than the minimum step size.$ l& Z- K8 P( k8 ~
Warning: Next step size (2.190737403247907e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583675 because distance between zero crossings is smaller than the minimum step size.! G+ \$ a, `& x7 w5 G0 v7 x
Warning: Next step size (2.19073740324793e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583741 because distance between zero crossings is smaller than the minimum step size.7 z, |% N+ t4 _8 a
Warning: Next step size (2.190737403247938e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583764 because distance between zero crossings is smaller than the minimum step size.
: S; K6 w8 B  G0 z0 l. W, TWarning: Next step size (2.190737403247946e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583786 because distance between zero crossings is smaller than the minimum step size.5 k/ |% s! M" R' k4 u
Warning: Next step size (2.190737403247962e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558383 because distance between zero crossings is smaller than the minimum step size.
# o* t( x" }5 Y5 m$ OWarning: Next step size (2.190737403247985e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583897 because distance between zero crossings is smaller than the minimum step size.
5 U7 ]1 u4 _6 M* x6 z0 L  B0 y" NWarning: Next step size (2.190737403247993e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583919 because distance between zero crossings is smaller than the minimum step size.( y7 {* j* S* l4 z8 E3 ^
Warning: Next step size (2.190737403248009e-016) is smaller than minimum step size (2e-016) at time 0.06166377595583963 because distance between zero crossings is smaller than the minimum step size.- F6 ~* Z0 ^  E9 {0 W# v* l% W  c) l# p
Warning: Next step size (2.190737403248025e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584008 because distance between zero crossings is smaller than the minimum step size.# i" m5 [5 g! a1 ]' q
Warning: Next step size (2.190737403248072e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584141 because distance between zero crossings is smaller than the minimum step size.
6 N4 B* y- ~9 O& E! I9 p2 gWarning: Next step size (2.19073740324808e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584163 because distance between zero crossings is smaller than the minimum step size.
3 A% E0 r# n" T: F, KWarning: Next step size (2.190737403248112e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584252 because distance between zero crossings is smaller than the minimum step size.
: C3 l6 Y. U' E" H& I+ D: sWarning: Next step size (2.190737403248119e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584274 because distance between zero crossings is smaller than the minimum step size.
" P8 l0 y4 X) ?/ ]: w3 U5 v9 y1 v* ^Warning: Next step size (2.190737403248159e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584385 because distance between zero crossings is smaller than the minimum step size.
1 Q8 a% u1 j1 EWarning: Next step size (2.190737403248167e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584408 because distance between zero crossings is smaller than the minimum step size.- `; U4 x8 d" j
Warning: Next step size (2.190737403248198e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584496 because distance between zero crossings is smaller than the minimum step size.
+ t( e" O+ e6 x- H: i- K% CWarning: Next step size (2.190737403248206e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584519 because distance between zero crossings is smaller than the minimum step size.
6 K& I0 @! i2 Y( s- B# qWarning: Next step size (2.190737403248214e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584541 because distance between zero crossings is smaller than the minimum step size.
3 |% Z# g. K0 Z# t5 l. T2 t+ k. d  bWarning: Next step size (2.190737403248222e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584563 because distance between zero crossings is smaller than the minimum step size.! `. j9 d  F) n7 {: c
Warning: Next step size (2.190737403248246e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558463 because distance between zero crossings is smaller than the minimum step size.
( j) I8 o/ E8 ?' ~7 aWarning: Next step size (2.190737403248261e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584674 because distance between zero crossings is smaller than the minimum step size.. j8 D' g- q& U+ d- D' K2 V
Warning: Next step size (2.190737403248285e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584741 because distance between zero crossings is smaller than the minimum step size.
5 f% Y" F& e5 b* h, o. XWarning: Next step size (2.190737403248293e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584763 because distance between zero crossings is smaller than the minimum step size.
& J4 W, `1 f; a9 P  B. qWarning: Next step size (2.190737403248301e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584785 because distance between zero crossings is smaller than the minimum step size.
  a: W: _3 y8 Q  BWarning: Next step size (2.190737403248309e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584807 because distance between zero crossings is smaller than the minimum step size.
/ l+ k9 F$ O) k) l7 @7 eWarning: Next step size (2.19073740324834e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584896 because distance between zero crossings is smaller than the minimum step size.
( G* x5 s3 H4 g/ \! eWarning: Next step size (2.190737403248348e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584918 because distance between zero crossings is smaller than the minimum step size.8 B' h3 ^- C( v1 s
Warning: Next step size (2.190737403248372e-016) is smaller than minimum step size (2e-016) at time 0.06166377595584985 because distance between zero crossings is smaller than the minimum step size.+ a+ E- }  O" g. g/ G7 j
Warning: Next step size (2.19073740324838e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585007 because distance between zero crossings is smaller than the minimum step size.
& y; ]2 z3 T+ i  t/ JWarning: Next step size (2.190737403248388e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585029 because distance between zero crossings is smaller than the minimum step size.% e) }9 I" d/ a
Warning: Next step size (2.190737403248403e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585074 because distance between zero crossings is smaller than the minimum step size.
" c6 d: q+ a* M1 W: pWarning: Next step size (2.190737403248427e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558514 because distance between zero crossings is smaller than the minimum step size.
' G% O7 R& z& R8 UWarning: Next step size (2.190737403248435e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585162 because distance between zero crossings is smaller than the minimum step size.8 l6 Z2 n! v) e% f# A& K, Q1 `/ \
Warning: Next step size (2.190737403248459e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585229 because distance between zero crossings is smaller than the minimum step size.
0 U  \, a' a% Y  }- F- C7 p. sWarning: Next step size (2.190737403248474e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585273 because distance between zero crossings is smaller than the minimum step size.
# ?3 m6 m, v& V3 {" gWarning: Next step size (2.190737403248514e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585385 because distance between zero crossings is smaller than the minimum step size.
' @5 @% c; M: ~Warning: Next step size (2.190737403248522e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585407 because distance between zero crossings is smaller than the minimum step size.
7 q: j+ ~/ U9 Q) P1 ], S; mWarning: Next step size (2.190737403248553e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585496 because distance between zero crossings is smaller than the minimum step size.& J' M, T+ G2 J" n, g5 B
Warning: Next step size (2.190737403248561e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585518 because distance between zero crossings is smaller than the minimum step size.
  f5 W* u: J! L. e% nWarning: Next step size (2.190737403248601e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585629 because distance between zero crossings is smaller than the minimum step size.
" J  o2 L2 M  g& oWarning: Next step size (2.190737403248616e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585673 because distance between zero crossings is smaller than the minimum step size.
9 h/ J9 F* j1 P. sWarning: Next step size (2.19073740324864e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558574 because distance between zero crossings is smaller than the minimum step size.
7 f3 V1 I% Z+ s1 z9 tWarning: Next step size (2.190737403248648e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585762 because distance between zero crossings is smaller than the minimum step size.1 J& F1 v$ T0 w+ D6 X
Warning: Next step size (2.190737403248695e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585895 because distance between zero crossings is smaller than the minimum step size.' g  ]6 J2 d' g" j
Warning: Next step size (2.190737403248703e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585917 because distance between zero crossings is smaller than the minimum step size.. A7 C& n6 E! ]
Warning: Next step size (2.190737403248727e-016) is smaller than minimum step size (2e-016) at time 0.06166377595585984 because distance between zero crossings is smaller than the minimum step size.
8 j- l$ c  s/ s/ C. H/ e; vWarning: Next step size (2.190737403248735e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586006 because distance between zero crossings is smaller than the minimum step size.9 u. m8 ?' [2 ]) y
Warning: Next step size (2.190737403248743e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586028 because distance between zero crossings is smaller than the minimum step size.0 ]1 Z; H. j$ p' H& O
Warning: Next step size (2.190737403248751e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586051 because distance between zero crossings is smaller than the minimum step size.+ F' Z4 S: `2 E: N- V
Warning: Next step size (2.190737403248766e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586095 because distance between zero crossings is smaller than the minimum step size.
1 i' }& `+ h2 K( [$ ~Warning: Next step size (2.190737403248774e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586117 because distance between zero crossings is smaller than the minimum step size./ I  v, _4 q2 i
Warning: Next step size (2.190737403248782e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586139 because distance between zero crossings is smaller than the minimum step size.5 L1 _! H" }  Z& P& X9 X' D2 q
Warning: Next step size (2.19073740324879e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586162 because distance between zero crossings is smaller than the minimum step size.
+ ?3 r+ G' v9 XWarning: Next step size (2.190737403248814e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586228 because distance between zero crossings is smaller than the minimum step size." R4 X8 o2 R  `5 L* I6 i
Warning: Next step size (2.190737403248822e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558625 because distance between zero crossings is smaller than the minimum step size.' G9 l. A" h% J! t
Warning: Next step size (2.190737403248869e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586384 because distance between zero crossings is smaller than the minimum step size.
+ T0 {+ @, V! L% B# f! zWarning: Next step size (2.190737403248877e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586406 because distance between zero crossings is smaller than the minimum step size.
( w7 Y5 y3 {% v1 D8 TWarning: Next step size (2.190737403248893e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558645 because distance between zero crossings is smaller than the minimum step size.
# N: P6 q/ }  K8 NWarning: Next step size (2.190737403248916e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586517 because distance between zero crossings is smaller than the minimum step size.
/ f5 A& N0 b. L3 l8 m, oWarning: Next step size (2.190737403248956e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586628 because distance between zero crossings is smaller than the minimum step size.
1 e5 `1 \  N* \6 m7 rWarning: Next step size (2.190737403248971e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586672 because distance between zero crossings is smaller than the minimum step size.
" M* I; W- N' G! e% ]4 W" W1 ~Warning: Next step size (2.190737403248995e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586739 because distance between zero crossings is smaller than the minimum step size./ C7 W/ Y7 P  R" b, ^( W. H
Warning: Next step size (2.190737403249003e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586761 because distance between zero crossings is smaller than the minimum step size.$ S4 P4 d" Q- a" p. J* W. d6 @
Warning: Next step size (2.19073740324905e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586894 because distance between zero crossings is smaller than the minimum step size.
) c  @; `9 ~9 _" Y7 m7 d6 BWarning: Next step size (2.190737403249066e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586939 because distance between zero crossings is smaller than the minimum step size.' ?$ A2 L" Y" f# X9 l, I8 _
Warning: Next step size (2.190737403249082e-016) is smaller than minimum step size (2e-016) at time 0.06166377595586983 because distance between zero crossings is smaller than the minimum step size.
2 r" f  R: W, O9 dWarning: Next step size (2.19073740324909e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587005 because distance between zero crossings is smaller than the minimum step size.7 a0 G) O. e( O- b- T1 X3 m
Warning: Next step size (2.190737403249121e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587094 because distance between zero crossings is smaller than the minimum step size.
1 t# I/ k# g3 }# F  T" OWarning: Next step size (2.190737403249129e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587116 because distance between zero crossings is smaller than the minimum step size.
7 a' J4 Z: \6 c5 L* DWarning: Next step size (2.190737403249137e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587139 because distance between zero crossings is smaller than the minimum step size." m& D: p" o, [1 q3 U, f/ O# C
Warning: Next step size (2.190737403249145e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587161 because distance between zero crossings is smaller than the minimum step size.
  L7 K/ k8 f; y& NWarning: Next step size (2.190737403249169e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587227 because distance between zero crossings is smaller than the minimum step size.$ e6 A6 d) ~8 z. Q0 h
Warning: Next step size (2.190737403249177e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558725 because distance between zero crossings is smaller than the minimum step size.
, D# D& c  r/ I1 ?  ^. l6 z1 YWarning: Next step size (2.190737403249208e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587338 because distance between zero crossings is smaller than the minimum step size.
) ~7 v/ x5 J" f( L9 eWarning: Next step size (2.190737403249216e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587361 because distance between zero crossings is smaller than the minimum step size.
, X/ V2 ~8 f# w" w6 f6 sWarning: Next step size (2.190737403249224e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587383 because distance between zero crossings is smaller than the minimum step size.
% g2 c  b$ ]4 H. hWarning: Next step size (2.190737403249232e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587405 because distance between zero crossings is smaller than the minimum step size.; a6 t7 O; G- b, \- L8 L+ a
Warning: Next step size (2.190737403249255e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587472 because distance between zero crossings is smaller than the minimum step size.
0 M/ ~0 \* U1 J- B# MWarning: Next step size (2.190737403249271e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587516 because distance between zero crossings is smaller than the minimum step size.2 ]- x4 j9 B: n
Warning: Next step size (2.190737403249311e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587627 because distance between zero crossings is smaller than the minimum step size.- {, R+ B# ?9 C. }
Warning: Next step size (2.190737403249319e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587649 because distance between zero crossings is smaller than the minimum step size.
. X( o8 ?: b7 t6 ?Warning: Next step size (2.19073740324935e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587738 because distance between zero crossings is smaller than the minimum step size.
$ Z) ~3 A4 o& wWarning: Next step size (2.190737403249358e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558776 because distance between zero crossings is smaller than the minimum step size.2 Q6 P, k& y( B
Warning: Next step size (2.190737403249397e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587871 because distance between zero crossings is smaller than the minimum step size.
7 E1 d8 E. y% E' a4 j# c9 ]Warning: Next step size (2.190737403249413e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587916 because distance between zero crossings is smaller than the minimum step size.
- o% R6 h" ?9 f* M$ k3 Y! p7 b  gWarning: Next step size (2.190737403249437e-016) is smaller than minimum step size (2e-016) at time 0.06166377595587982 because distance between zero crossings is smaller than the minimum step size.
4 P7 C. j" k6 ^! V; u. {2 @9 Q" yWarning: Next step size (2.190737403249445e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588005 because distance between zero crossings is smaller than the minimum step size.
: b! |5 e8 t2 NWarning: Next step size (2.190737403249476e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588093 because distance between zero crossings is smaller than the minimum step size.3 J# ]( H! v) Z# x+ T5 l
Warning: Next step size (2.190737403249484e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588116 because distance between zero crossings is smaller than the minimum step size.
, w* a$ U0 O. M) m+ X$ O: G0 XWarning: Next step size (2.190737403249492e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588138 because distance between zero crossings is smaller than the minimum step size.
+ X, I: b  @! PWarning: Next step size (2.190737403249508e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588182 because distance between zero crossings is smaller than the minimum step size.
# |- \. X- M+ H1 NWarning: Next step size (2.190737403249524e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588227 because distance between zero crossings is smaller than the minimum step size.! c6 K- F& p8 W7 ]
Warning: Next step size (2.190737403249532e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588249 because distance between zero crossings is smaller than the minimum step size.. i( a6 O) q/ @3 }/ Y
Warning: Next step size (2.190737403249563e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588338 because distance between zero crossings is smaller than the minimum step size." J/ q4 F: }2 A* B  w/ p
Warning: Next step size (2.190737403249571e-016) is smaller than minimum step size (2e-016) at time 0.0616637759558836 because distance between zero crossings is smaller than the minimum step size.
5 g. @2 a% |& n  UWarning: Next step size (2.190737403249579e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588382 because distance between zero crossings is smaller than the minimum step size.$ _( T6 \# a" h
Warning: Next step size (2.190737403249587e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588404 because distance between zero crossings is smaller than the minimum step size.
3 N0 H" N- }# @Warning: Next step size (2.19073740324961e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588471 because distance between zero crossings is smaller than the minimum step size.
2 D; G4 _6 ^9 J% V) }- LWarning: Next step size (2.190737403249626e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588515 because distance between zero crossings is smaller than the minimum step size.
) U1 M3 L" U4 f+ Y' G; j+ g1 P8 SWarning: Next step size (2.19073740324965e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588582 because distance between zero crossings is smaller than the minimum step size.
, `1 s" |, z4 O- G6 B! oWarning: Next step size (2.190737403249658e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588604 because distance between zero crossings is smaller than the minimum step size.
& [; _" `# D2 W' Z6 t, M7 T  |Warning: Next step size (2.190737403249666e-016) is smaller than minimum step size (2e-016) at time 0.06166377595588626 because distance between zero crossings is smaller than the minimum step size.
 楼主| 发表于 2012-12-5 20:18:35 | 显示全部楼层
解决啦,加个selector就行啦
GMT+8, 2026-11-20 11:05
