楼主 |
发表于 2012-9-14 20:40:37
这个是不加电动机动态数据时动态仿真初始化是的发电机输出,跟潮流计算时结果一致 ' k& y7 t- K7 z c7 m
BUS# X-- NAME --X BASKV ID ETERM EFD POWER VARS P.F. ANGLE ID IQ
6 N0 H6 S( L# d# V e9 v7 B 10 BUS1G 13.800 1 1.0000 1.0090 4000.27-1093.27 0.9646 22.44-0.2029 0.8042
; _5 `( E; j& t1 y 11 BUS2G 13.800 1 0.9999 0.9795 478.78 -423.69 0.7489 14.46-0.5060 0.6186% u& S/ u6 o4 O1 `, [. M' o
12 BUS5G 13.800 1 1.0000 0.9923 2111.22 -423.93 0.9804 11.35-0.0405 0.7166
( U% N! @4 c: k: c- t/ \ 13 BUS7G 13.800 1 0.9998 1.0394 2420.75 1699.04 0.8185 1.73 0.5897 0.7903
1 V- x6 t; g& t% u9 ? 14 BUS9G 13.800 1 0.9999 1.0430 2276.93 1606.56 0.8171 1.87 0.6721 0.8894# r7 b1 P& g* e1 J O2 u
下面是加了电动机动态数据后,动态仿真初始化时的发电机数据,差别太大了: S; ?! Z" c" r( H3 x9 ~
/ C& k/ @1 I8 p6 V, h 10 BUS1G 13.800 1 1.0000 1.0089 3973.13-1109.69 0.9631 22.43-0.2064 0.7988
: g) w; {! I6 _0 b 11 BUS2G 13.800 1 1.0025 0.9683 142.82 -594.74 0.2335 13.19-0.7395 0.1867" R! _+ w" |/ c1 h0 G
12 BUS5G 13.800 1 1.0000 0.9923 2111.22 -423.93 0.9804 11.35-0.0405 0.7166* I. i! j1 B. b$ @; @" z
13 BUS7G 13.800 1 1.0052 1.0296 -838.19 476.87-0.8692 0.31 0.1609-0.2763
3 y* n& v0 G- Y: s 14 BUS9G 13.800 1 1.0028 1.0378 1143.75 1080.04 0.7271 1.28 0.4383 0.4491 |
