查看: 1646|回复: 5
LIS总是看不懂,哪位高人指点一下?
发表于 2012-8-8 19:44:40 | 显示全部楼层 |阅读模式
You lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following
/ E" A% X) H- ~1 H* Kmessage summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where- w: W) e& s& k1 F/ r. s- u
the "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card! O; i3 i9 t% Z7 m$ `2 b
is generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been
( e! I1 p/ O% U" Pdisplayed, so a copy follows:! R" ~% M2 I4 u, R" p. y0 V
"  X0005AX0005A                                        MEASURING                1"0 r$ V3 c3 W- @. T$ A
              KILL code number                Overlay number               Nearby statement number
+ W. a; V: O/ F# o                        224                          4                               82124 k0 ?5 Y" r; C: C! X0 _
KILL = 224.   The last-read data card is for a switch that has both terminals connected to the same node  BUS1 = X0005A.   This is0 u% @/ _: [9 `' }4 h- w. z: D- O
objectionably stupid.4 j, F( B% w% a6 G; T% g
哪位高人能说一下,上面是什么意思啊?自己总是琢磨不透,谢谢了~
发表于 2012-8-8 21:01:01 | 显示全部楼层
他是说你的一个开关的两端连在同一个节点X0005A上面。。。。。。$ R; t& a. K& b1 u$ a8 i2 I
“The last-read data card is for a switch that has both terminals connected to the same node  BUS1 = X0005A.   This is objectionably stupid.”
 楼主| 发表于 2012-8-8 21:24:43 | 显示全部楼层
[img]file:///C:/Documents%20and%20Settings/Administrator/Application%20Data/Tencent/Users/569290572/QQ/WinTemp/RichOle/$M7C37SG1[}N82_`K{8HKZQ.jpg[/img] 5 u1 F% K2 U  P% C2 {/ j
图如上该怎么改呢?我实在不明白。
 楼主| 发表于 2012-8-8 21:26:02 | 显示全部楼层
未命名.jpg 不好意思,不太会弄,这是图
    2018-8-13 08:52
  • 签到天数: 10 天
    累计签到:10 天
    发表于 2012-8-10 10:59:13 | 显示全部楼层
    回复 4# jymildred + q% Q+ ?, i5 a% Y( e' E
    4 c; g7 |' Q6 Q
    / t3 }( {0 F# x: k3 m$ K
       你吧那个支路电流元件两端的连线拆了  然后一端连线路  一端连开关 试试  最好不要直接把电流测量元件直接放支路上
    发表于 2012-8-16 22:44:03 | 显示全部楼层
    回复 4# jymildred 把电流互感器两端的名称改一下试试吧?名字不应该是一样的啊……
    GMT+8, 2026-11-20 10:57
