查看: 1394|回复: 3
digsilent中模型开环测试设置完成后,如何运行?
发表于 2012-6-27 09:56:08 | 显示全部楼层 |阅读模式
在一份资料中看到model搭建完成后可以不连接其他设备,进行开环测试,操作如下:0 o0 V2 I7 v7 ^7 g" m
" {! j( U8 X' M. ?- L5 b         Verify the behaviour of the model by an open-loop test, i.e. the controller is not connected to any
8 \' q$ L1 S5 b4 G" S% q1 Wother element (synchronous generator) in the grid:
  u1 d, @% @$ c+ T
2 ?6 ^1 B3 ^* V# w4 F. hOpen-Loop Response:5 W2 t, D2 j! e! Q( \2 _( S
 1    Test the model with a step response to the reference voltage “usetp” (open-loop-test) [17].8 E* P$ g1 s( ~1 @
 2    Define a variable set to monitor for the VCO element and visualize the results of the simulated step response
0 y8 q' F) J# T; o
0 N6 Y: ^6 S- r1 }4 U: y; j/ D上面第一步的具体操作过程:9 n* S0 m1 J" q2 F+ H
#17: Open-Loop Test, ~, Z( b$ \$ _7 b( P9 v, w. g( W" R
  h: m9 t" Y, X/ D  U7 p. w: l
 1     Open the event list ( ) and use the “New Object” button to insert a “Set Parameter(EvtPara)” event
4 S. a5 b# t/ c# [$ Z( `! m 2     Select the AVR controller for the element.4 V( K3 B4 ?& ^
 3     Insert the name of the variable ‘usetp’ and the new value for this variable (=0.9).. f, x5 }* ~. L
6 H! i. C( U( V0 ~ 我想问的是,这些设置都做完后,接下来如何操作呢?
 楼主| 发表于 2012-6-27 09:58:39 | 显示全部楼层
补充:2    Define a variable set to monitor for the VCO element and visualize the results of the simulated step response; ]: S; O7 A7 l% E
* l7 s) y# P  @) O  @0 W' m
这一步也完成了,问:接下来怎么做?是执行计算初始条件然后开始仿真吗?
    2021-6-1 11:31
  • 签到天数: 215 天
    [LV.7]常住居民III
    累计签到:223 天
    发表于 2012-6-27 15:15:00 | 显示全部楼层
    接下来就是定义一些你要观察的变量的值,然后做仿真,显示结果。
    2017-9-26 15:28
  • 签到天数: 21 天
    累计签到:21 天
    发表于 2012-6-27 16:11:49 | 显示全部楼层
    学习一下
    GMT+8, 2026-11-20 09:20
