查看: 1656|回复: 4
变压器分接头控制和line drop compensation怎么实现啊
发表于 2012-6-1 23:18:09 | 显示全部楼层 |阅读模式
最近在做变压器控制的relay,怎么样实现延迟60秒再调节呢?或者谁做过这个求分享...多谢~~
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
    发表于 2012-6-2 10:09:14 | 显示全部楼层
    On-Line Tap Changer8 z* \/ C2 ~9 `+ K7 {- o& G' x, d
    All transformer components are equipped with an on-line tap changer.  When the tap changer is enabled, a diagonal line will appear on the component graphic, labelled Tap.
    , _7 J- S! S& x0 u) P! `5 B5 yA change in tap setting is modeled as a change in the turns-ratio of the transformer.  The per-unit leakage reactance and magnetizing currents, specified for 100% tap, are used to calculate admittances for the new voltage rating, corresponding to the tap setting.
    4 q5 c" ?* I! A) X6 y# P! n2 HEXAMPLE:
    ' N3 p* H9 c% m4 W' T+ }- B* ~Let us assume for simplicity, that a transformer is configured as Y-Y, with winding voltages rated at 10 kV primary and 100 kV secondary, and a tap changer is placed on the primary winding.  The turns-ratio for this transformer is of course 1:10.
      o/ a* q: Z& ~, x- j, aAn on-line tap input of 1.0 corresponds to a 100% tap (i.e. no tap adjustment).  If the tap input value is adjusted to say 1.05, then the turns-ratio would become 1.05:10 or 1:9.52381.6 ^& b8 L' l, Q5 k& I- m0 k
    It is possible to have a continuous change of tap, but this would require a re-ordering of the network solution every time step. It is more practical to change tap settings in steps, either through manual adjustment, using a slider or rotary switch, or from a controller with appropriate delays and steps built in.
     楼主| 发表于 2012-6-4 21:13:19 | 显示全部楼层
    RE: 变压器分接头控制和line drop compensation怎么实现啊
    回复 2# mingyu
    . I% q. b# z7 K# ?4 M& p1 t
    : p+ p5 K- s/ w/ z" ZThanks a lot for the reply and explanation...do you have any pscad example about OLTC control?
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
    发表于 2012-6-5 09:56:52 | 显示全部楼层
    没有,找客服要。
    2017-9-26 15:28
  • 签到天数: 21 天
    累计签到:21 天
    发表于 2012-6-5 11:47:46 | 显示全部楼层
    没做过,不太清楚呀
    GMT+8, 2026-11-20 09:09
