查看: 3802|回复: 2
DFIG暂态仿真问题
发表于 2012-4-23 21:33:20 | 显示全部楼层 |阅读模式
用DIgsI进行风电场仿真时,把demo中的DFIG复制到Kundur11节点系统中,可以计算潮流,但是无法进行暂态仿真,请教各位是什么问题,报错内容如下:! V: c, M- h3 k0 c/ }* Z; T1 S( ]' y) B: q
% q* E* M# M% T+ E$ d/ b/ O
DIgSI/info - Element 'G3   ' is local reference in separated area of 'BUS3   '. M) e* P, q3 i& G% G) n0 ]
DIgSI/info - Calculating load flow.../ L! z! w1 S8 w# H
DIgSI/info - -------------------------------------------------------------------------------------# N0 ]  @5 ~4 C/ h& W: X+ E$ h
DIgSI/info - Start Newton-Raphson Algorithm...+ I" F4 X2 K, O
DIgSI/info - load flow iteration: 1
) s8 O7 m# H, I( jDIgSI/info - load flow iteration: 22 a& l3 Y, E1 {/ n
DIgSI/info - load flow iteration: 3
$ N" g" O& K' W, j6 G9 a$ vDIgSI/info - load flow iteration: 4% S' c& w: }+ u2 e" _; g$ h: ]
DIgSI/info - load flow iteration: 5$ h& q; B7 E, @  O; e' E' H: Z& O
DIgSI/info - Newton-Raphson converged with 5 iterations.
( u/ M5 {7 h" j8 U  gDIgSI/info - Load flow calculation successful.
& h7 c) m2 z$ |# gDIgSI/info - Element 'G3   ' is local reference in separated area of 'BUS3   '9 z- L* y9 n5 K& H! o5 w' Y
DIgSI/info - Element 'G3   ' is reference in 50.0 Hz-system/ R# _4 I- r9 ~
DIgSI/info (t=-100:000 ms) - Initial conditions calculated.0 G9 u) K5 l, q- D' b
DIgSI/wrng (t=-090:000 ms) - No convergence in simulation!
  v' t: e& r7 L: B" ?  _- B0 iDIgSI/wrng (t=-090:000 ms) - No convergence in simulation!
+ p- @/ q/ T$ k' Q6 i0 IDIgSI/wrng (t=-090:000 ms) - No convergence in simulation!8 [" L" _8 o* e6 W9 w: h
2 Q# U. o* A( f3 s8 _DIgSI/wrng (t=-090:000 ms) - Element 'GW4.ElmAsm': Model equations don't converge: error: 1.970124+ L( `/ A' S8 |+ K; u! @
DIgSI/wrng (t=-090:000 ms) - Element 'GW2.ElmAsm': Model equations don't converge: error: 2.206480
9 ?9 u  ?# g  s  t( y1 sDIgSI/err  (t=-090:000 ms) - 'GW1   ':
0 o* Z) V& E5 b2 f6 K# S3 CDIgSI/err  (t=-090:000 ms) - System-Matrix Inversion failed !  g) a* o& I. l7 v* |
发表于 2012-4-24 10:22:54 | 显示全部楼层
暂停仿真时的算法选择有问题,应选local reference system,各控制模块应选stable-integration 算法
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
    发表于 2012-4-24 20:05:20 | 显示全部楼层
    这个算法的选择会影响收敛吗?
    GMT+8, 2026-11-20 11:33
