查看: 8008|回复: 7
Electronics - Switchmode Power Supply Handbook 1st Ed
发表于 2007-8-11 14:29:32 | 显示全部楼层 |阅读模式
Electronics - Switchmode Power Supply Handbook 1st Ed-%-53595-%--%-53597-%-
Electronics - Switchmode Power Supply Handbook 1st Ed.part1.rar
9.54 MB, 下载次数: 137, 下载积分: 威望 -2 点, 学分 -5 点
    2019-1-25 10:10
  • 签到天数: 3 天
    累计签到:3 天
    发表于 2007-8-11 14:34:41 | 显示全部楼层
    不看也要顶!!!!!
     楼主| 发表于 2007-8-11 14:50:36 | 显示全部楼层
    Electronics - Switchmode Power Supply Handbook 1st Ed.part2.rar
    9.54 MB, 下载次数: 10, 下载积分: 威望 -2 点, 学分 -5 点
     楼主| 发表于 2007-8-11 15:23:43 | 显示全部楼层
    Electronics - Switchmode Power Supply Handbook 1st Ed.part3.rar
    9.03 MB, 下载次数: 10, 下载积分: 威望 -2 点, 学分 -5 点
    发表于 2008-3-3 20:46:26 | 显示全部楼层
    回复 4楼 的帖子
    非常经典的好书
    发表于 2008-3-3 20:49:05 | 显示全部楼层
    该书的目录
    Common Requirements: An Overview( P# U" @' F% w" m/ ]& d
    Ac Powerline Surge Protection
    7 e) Z0 L; F  i8 ]9 e) C! G Electromagnetic Interference (emi) In Switchmode Power Supplies$ K& d$ Y: T* ]5 f5 D: y
    Faraday Screens2 _: P+ T* \# F+ |) f& G; |
    Fuse Selection
    + n$ [/ o2 T! K- m/ V* m% f Line Rectification And Capacitor Input Filters For “direct-off-line” Switchmode Power Supplies7 \+ L9 d  s( ^0 P$ v7 n
    Inrush Control
    8 P; Z+ H  g* V( \* F! z Start-up Methods
    ; u3 p7 N! W6 w% [3 v/ p0 b Soft Start And Low-voltage Inhibit. w( R& R  F' m) o1 M- j0 T4 p0 |
    Turn-on Voltage Overshoot Prevention: f* |  ?" G* T; c3 @9 A' z8 |
    Overvoltage Protection
    ) ?' z& k% [1 b Undervoltage Protection
    5 X/ Z  ~  u) l. m& U; b- k- w Overload Protection* U- D; S0 T& F) _* u, L
    Foldback (reentrant) Output Current Limiting8 H# g3 q( C  `3 j2 v
    Base Drive Requirements For High-voltage Bipolar Transistors( }1 d; a% `& i  q! ^, |) X
    Proportional Drive Circuits For Bipolar Transistors) V9 C) ]- a4 [5 v' m6 _" \% A
    Antisaturation Techniques For High-voltage Transistors$ R$ p2 n) t0 D1 E
    Snubber Networks1 e0 j! E* m  ^% I+ `3 a% G
    Cross Conduction2 u* |1 u8 y2 S" n' @, ^
    Output Filters- y! K3 i, a# W
    Power Failure Warning Circuits
      {5 ?6 ]/ R7 J1 W5 s1 l) v) N Centering (adjustment To Center) Of Auxiliary Output Voltages On Multiple-output Converters
      y4 W$ n  k7 i- z* | Auxiliary Supply Systems
    " T+ \4 w3 S( M2 | Parallel Operation Of Voltage-stabilized Power Supplies
    # s! d! a6 l0 x: ]( t: s Multiple-output Flyback Switchmode Power Supplies
    ! E4 B! V  c* ?; R Flyback Transformer Design
    - x$ y7 n. T" c0 J8 n, P! ?  j: c+ U$ v Reducing Transistor Switching Stress
    $ W3 E$ \: U+ l- O, w* ? Selecting Power Components For Flyback Converters
    6 A& ~6 {  L3 I& O1 w, O$ W& I' A The Diagonal Half-bridge Flyback Converter
    9 H: h4 g" t3 T5 n( B Self-oscillating Direct-off-line Flyback Converters
    1 U  ]5 Q+ y; z# f+ x Applying Current-mode Control To Flyback Converters
    1 F5 R: y6 Y9 D: M Direct-off-line Single-ended Forward Converters
    * p& |* X# w1 {! c, ~5 M* T Transformer Design For Forward Converters) o  o2 A* y7 v0 E9 a
    Diagonal Half-bridge Forward Converters
    : s5 ^6 Z& g# F Transformer Design For Diagonal Half-bridge Forward Converters
    ( h0 t; D* i$ D$ e: r, O Half-bridge Push-pull Duty-ratio-controlled Converters
    ' |" Q8 |6 r+ B* s6 f+ Y Bridge Converters* t6 P4 t8 P, j4 a5 x9 I+ U
    Low-power Self-oscillating Auxiliary Converters. O6 |' ]# S; m5 o. {
    Single-transformer Two-transistor Self-oscillating Converters
    & m+ a$ G4 m- V* d, O# e0 }& f: o Two-transformer Self-oscillating Converters
    " m3 ]5 k# \  d$ P, m+ y The Dc-to-dc Transformer Concept
    & i. Q: S5 y" s8 s# V- f Multiple-output Compound Regulating Systems" [/ P  b' _% |+ h: S+ o6 X% T4 A% X! v
    Duty-ratio-controlled Push-pull Converters8 h: l! N6 z2 o  Z, S' [& @0 ~
    Dc-to-dc Switching Regulators
    - P: }$ ^1 _+ ?& R5 I1 t8 d High-frequency Saturable Reactor Power Regulator (magnetic Duty Ratio Control)' U  r, t% z4 Z" `
    Constant-current Power Supplies
      h$ m/ H, ]( ?, k( J" d9 K: J3 } Variable Linear Power Supplies
    & c2 L0 F" X; X7 o8 f8 N4 } Switchmode Variable Power Supplies
    " |0 s/ X+ p: c( I" I  E& A Switchmode Variable Power Supply Transformer Design
    ; G, }2 L! @% O6 s: a3 k Inductors And Chokes In Switchmode Supplies; X3 t: H8 _" N- f8 t7 g/ ~5 _
    High-current Chokes Using Iron Powder Cores
    " d! V; ^) n- t! a1 w Choke Design Using Iron Powder Toroidal Cores
    ) b) v1 `& y+ G  u" O Switchmode Transformer Design (general Principles) 4 l6 U5 o& L6 X$ i7 x
    Optimum 150-w Transformer Design Example Using Nomograms 6 c% Z& @& @! p& t
    Transformer Staircase Saturation
    2 X8 ?% _7 B- U. W- S Flux Doubling ! I- K6 T- r3 X9 }- F
    Stability And Control-loop Compensation In Smps
    % a8 \0 C. R- l, T9 y The Right-half-plane Zero
    / a: Z% |$ F9 k! V Current-mode Control
    6 \4 Z9 U2 j. ^8 u0 H& e Optocouplers
    ) Q0 a1 y+ p- o Ripple Current Ratings For Electrolytic Capacitors In Switchmode Power Supplies % ?. x- d( F" d/ i
    Noninductive Current Shunts
    0 v+ h1 r: ]# V8 o9 [ Current Transformers % S+ r: r, {0 j3 H& R8 v. m" O
    Current Probes For Measurement Purposes 6 W# A* o9 u6 T  }
    Thermal Management In Switchmode Power Supplies; ?: b% W" ?- K* D/ d1 Q6 T
    Active Power Factor Correction
    2019-11-15 20:29
  • 签到天数: 11 天
    连续签到: 3 天
    累计签到:11 天
    连续签到:3 天
    发表于 2008-3-31 21:32:27 | 显示全部楼层
    想下* e( c- z# n& t& I8 N$ F
    可是没点了4 O+ o' j+ ?/ V3 R5 q, U: P
    明天攒起来再说
    发表于 2008-9-26 11:42:04 | 显示全部楼层
    $ [' s' z' x' I楼主 这本书 很不错 呵呵
    4 y. ~/ L! ?, P; J8 K2 Z喜欢
    GMT+8, 2026-11-20 09:44
