1. Disable connection to internet 請先將網路斷開.不要上網
) o9 N* m: W% k+ {5 g+ H2. Disable antivirus software on your computer 關閉所有防毒軟體
9 ^2 J% C9 I- O! i3. Run etap-7 installation from DVD/Harddisk. 開始安裝
! p! x1 y0 m+ b: |3 M: P: c4. select install + license manager, just follow the instruction.
8 f* e/ a/ W" C1 K# q# T請選擇install + license manager安裝) m) g. ~. s" F1 n( l9 C, A# P
5. When finish installation, dont run the software.安裝完後不要執行程式 S; `( x, z5 a7 n, Z" ]
6. copy all files in the LMSETUPSYSTEM32DRIVERS ----- to ------ C:WindowsSystem32Drivers' B% y9 ~6 a1 X3 Q! f
打開程式光碟到Z:\ETAPSETUP\LM32SETUP\LMSETUP\SYSTEM32\DRIVERS內的所有程式 , m9 o6 `' E0 ?4 |6 J# k @$ O
複製到C:\Windows\System32\Drivers目錄下
$ Z2 }1 q; R6 v4 x7. Extract 123.rar (石皮解, downloaded above) and place the exttracted files(etap6.exe) to ETAP 700 Folder., e2 v6 s4 V" T8 i( e6 d9 `: y, g6 b" _
將123目錄下的Parche.zip壓縮檔解壓縮到c:\ETAP 7001 a4 e7 b& \+ l
8. Goto c:\Program Files\Operation Inc. Technology ETAP Licence Manager and open the file ETAPKEY.exe. A window will keep running. Let it be running.2 Q! E( ^, d; L* O0 L
到C:\Program Files\Operation Technology Inc\ETAP License Manager 700點擊ETAPKEY.exe1 K8 O: }6 y# z# ^2 a
程式不要關閉2 a" z1 B1 Q8 `* `; O
9. Now Go to ETAP 700/Parche/ETAP6.exe" and run etap6.exe. This is the software to bypass license.
2 E* V/ L. e- l5 U$ n# G- Mthis file is under DOS file, so you will see DOS application run. win7用?在此步?需要“以管理?身份?行此程式”,不然石皮解?失?。( y& N# S$ P. F7 T- [
執行c:\ETAP 700/Parche/ETAP6.exe如果你是win7的話,必須要用管理員身份執行
# v; X, I6 X' x; M W10. After finish installing ETAP6.exe, then Reboot your computer/laptop.
: N& U# a4 `$ E) e( P8 C0 K完成完裝重新開機!
S6 y# W) E3 q9 Z* j11. Enable again your antivirus, Y6 o& a* ^7 x1 b. @/ Y
12. Run ETAp 7 application.- l5 b- W* E8 `1 p
13. Will show up window for license , click OK, then software will ask for activation serial
( O0 `. b I& i5 ?Enter Activation serial : 9dp8kD6Ncc#Y8r5FBL+QEn3DHqDBKR<7Nc4/
- \6 c1 l, i$ ]3 D; m7 I, i執行程式,它會讓你輸入註冊碼serial : 9dp8kD6Ncc#Y8r5FBL+QEn3DHqDBKR<7Nc4/4 D, U& a9 M% [8 c- ?. o! B& Z
1 M; j6 l4 a' \
