查看: 1383|回复: 1
Distribution Optimal Power Flow
发表于 2011-8-2 02:18:58 | 显示全部楼层 |阅读模式
论文文献
标题: Distribution Optimal Power Flow
作者: H. M. Khodr, Member, IEEE, M. A. Matos, Member, IEEE, and J. Pereira
所属专业方向: Optimal Power Flow
摘要: Abstract--This paper presents a new and efficient methodology
for network reconfiguration with optimal power flow based on
Benders Decomposition approach. The objective minimizes the
power losses, balancing load among the feeders and subject to the
constraints: capacity limit of the branches, minimal and maximal
limits of the substation or generator, minimum deviation of the
nodes voltages and radial operation of the networks.
A variant of the generalized Benders decomposition algorithm
is applied for solving the problem, since the formulation can be
embedded under two stages. The first one is the Master problem
and is formulated as Mixed Integer non-Linear Programming.
This stage determines the radial topology of the distribution
network. The second stage is the Slave problem and is formulated
as a non-Linear Programming problem. This stage is used to
determine the feasibility of the Master problem solution by means
of an Optimal Power Flow and provides information to formulate
the linear Benders cuts.
The model is programmed in GAMS mathematical modeling
language. The effectiveness of the proposal is demonstrated
through an example extracted from the specialized literature.
关键字:
来源:
Distribution Optimal Power Flow.rar (230.14 KB, 下载次数: 0)
    2020-12-8 11:59
  • 签到天数: 105 天
    累计签到:223 天
    发表于 2011-8-2 09:07:25 | 显示全部楼层
    配网潮流优化
    GMT+8, 2026-11-20 09:54
