楼主: maxhu559988
ATP-EMTP武大培训各种算例
 荐  火... [复制链接]
发表于 2012-3-19 14:06:50 | 显示全部楼层
呵呵,好东西
发表于 2012-3-25 15:39:57 | 显示全部楼层
很实用 多谢
发表于 2012-4-1 10:12:45 | 显示全部楼层
感谢楼主分享
    2016-4-12 09:14
    发表于 2012-4-9 14:09:19 | 显示全部楼层
    学习啦
    发表于 2012-4-12 20:38:42 | 显示全部楼层
    积分为负数。。好悲催啊。。
    发表于 2012-4-13 11:26:51 | 显示全部楼层
    版主你好!关于您发的算例中雷电过电压计算中的atp模型运行不了,总是出现错误提示。请楼主帮忙看看,到底是为什么。错误提示如下:ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/$ a- ]3 z0 B7 i4 |2 d
    ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/+ E4 c$ \( z& ^$ |
    , [& a$ \% t$ K6 T5 Y2 @/ }1 WYou lose, fella.   The EMTP logic has detected an error condition, and is now going to terminate program execution.  The following
    & `8 z1 [  \1 |, t, `' Zmessage summarizes the circumstances leading to this situation.  Where an otherwise-unidentified data card is referred to, or where
    , {) q. Y1 H- mthe "last" card is mentioned, it is the most recently read card of the input data that is meant.  The 80-column image of this card
    6 j7 X+ E) A% ?is generally the last one printed out prior to this termination message.  But possibly this last-read card has not yet been3 [" N( l7 `/ R6 A3 K$ b+ w
    displayed, so a copy follows:& T( d, B1 Y+ S( m+ E( x. P
    . Q4 c" U; f) S" E& @2 J* ?              KILL code number                Overlay number               Nearby statement number
    + T9 T/ K% i9 D                          1                         13                               8109
    2 |7 ^- I" U" @2 V& R5 ~7 H. KKILL = 1.   Storage exceeded for EMTP List Number 8.   See the dimensioned limit in the case-summary statistics below.  The problem
    " ?. j$ x/ C# y7 B8 X" N# }. Zis simply too big for the program as currently dimensioned.  Yet, do not forget dynamic dimensioning as described in the Oct., 1993,6 C- B3 [, e3 u5 }
    newsletter.   In this case,  edit  LISTSIZE.DAT to increase table sizes,  and then try again.   Of course, such dynamic expansion is/ z% ^% r; \1 M. x
    possible only within limits fixed by  LISTSIZE.BPA  (used by variable-dimensioning program  "VARDIM"  as ATP is to be linked).
    : U8 B4 v4 I) Y/ b; x& \1 ~! M: xSometimes the reason for EMTP table overflow is unclear, and Program Maintenance might wish to inspect the contents of the error
    ) [$ G: }+ v/ h  u& q9 F# jinterface vectors  LSTAT  and  FLSTAT.    These now follow.   First comes  LSTAT,  using (12I10) encoding; then comes  FLSTAT,% Z+ [7 [' g8 K6 l+ a, G
    using (8E15.6) encoding:7 t6 f# d7 R8 `5 F3 y) A
    LSTAT =     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999     -9999        10        80/ Q- u' w; C. v
    LSTAT =       323         0     -9999         8       324         0      8109     -9999       116       155       323         7
    " L; T4 T3 d* K/ j) TFLSTAT =   6.250000E-02   6.250000E-02   9.375000E-02   9.375000E-02   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00
    ! d" X. n4 U7 _7 ^' }FLSTAT =   0.000000E+00   0.000000E+00   0.000000E+00   5.000000E+01   6.000000E+01   0.000000E+00   0.000000E+00   0.000000E+00
    4 J: L7 L" p( J7 f- ~* R! ~, T  wFLSTAT =   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00   0.000000E+00
    7 ^- O. u( x& f+ L4 y! fYet maybe the user would like some suggestions as to why the table in question  (List Number 8 )  has overflowed.   If such further
    3 y) x! c6 e/ a8 q, e/ vinformation is available,  it will now follow immediately ....! R4 L0 V, m0 H! q9 h, k: K
    List 8 stores past history points for distributed-parameter transmission circuits (lines or cables) in modal form.   Each5 ^0 g, H9 m0 ]# H6 C; B. _
    propagation mode requires storage, and there are as many modes as there are coupled conductors or phases (e.g., a double-circuit
    # u$ f% [% D" C/ H2 y* uline will normally have 6 modes).  Each mode requires TAU / DELTAT  entries,  where TAU is the modal travel time of the line,
    + J$ q% y/ ^% V5 `+ ]DELTAT is the time-step size,  and the division involves integer truncation followed by the addition of unity.
    ! a8 `& [# W8 k! y/ P4 LIn order to effectively trade memory space among the different EMTP tables (EMTP List Sizes), the user must know how many arrays
    0 N# i6 u6 q2 w/ I+ P5 H  {! M  _(columns) there are in each table.  The following tabulation shows the effective multiplicities that are associated with each
    ) P' B1 [, U* P. Q4 y; ~- q" pindependent EMTP List Size (those lists whose lengths are under user control by means of the EMTP variable-dimensioning program+ {# C' R* a3 B& u' i
    "VARDIM").6 F% X" x6 h5 R# O
    -------------1------------------------------------------------------------------------------------------------------------
    ) u2 O' J* J; n9 n! ? 7 O. v- M3 S' W( `/ T9 `
    List Number  1   1   2   3   4   5   6   7   8   9  10  11  12  13  14  15  16  17  18  19  20  21  22  23  24  25  26  275 }1 a3 _$ N3 T, p
    & q2 {( i$ o4 |+ c  I-------------1------------------------------------------------------------------------------------------------------------2 i; A2 k7 E9 u( b
    9 K; V" t' m. I  w2 v4 A% b, Q
    Floating Pt. 1   6   5   3   6   1  12   2   2   8   3   1   4   8   1   2   2   0   6   1   1  24   2   1   #   *   1
    / |+ B. ?3 f2 U0 b0 a  j) uInteger      1   4   7   0   2   1  10   0   0  11   0   3   0   4   0   0   2   1  10   2   0   0   0   0   0   0   0
    8 C. g5 E" l- y. G' vTotal        1  10  12   3   8   2  22   2   2  19   3   4   4  12   1   2   1  16   3   1  24   2   1   #   *   1
    . A9 t. N8 y9 K$ s+ I3 L! k: j
    9 T: d' }* ?' i( X8 J-------------1------------------------------------------------------------------------------------------------------------. e) Q7 Q0 @- `+ ?* j
    " I8 J( x) M- _! E/ p# --- Used only for virtual computers (Burroughs, PRIME, VAX, Apollo, etc.).    Others can ignore this List.
    $ H; v$ A# ^# o: b/ b8 N+ N" g* --- Rather than count List 24 itself,  add the value to the floating-point  and total counts for Lists 1 and 6.
    : F/ ^, n1 P: ~; S6 W------------------------------------------------------------------------------------------------------------------------------------
    " @/ |" T6 v, s) F+ `0 }ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/
    - O2 x) r& T' V4 cERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/
    2 l0 m7 m0 m+ B  I------------------------------------------------------------------------------------------------------------------------------------
    发表于 2012-4-21 00:48:55 | 显示全部楼层
    谢谢楼主
    发表于 2012-4-23 15:02:45 | 显示全部楼层
    请问和上次上传内容一样吧
    发表于 2012-4-24 22:14:51 | 显示全部楼层
    好东西啊,可惜流量不够 楼主能否给发一份呢,在此谢谢啊,
    : y( o# e. D% flkai121@163.com
    发表于 2012-5-7 08:54:15 | 显示全部楼层
    版主谢谢诶
    GMT+8, 2026-11-4 19:30
