论文文献
| 标题: |
WIND TURBINE APPLICATIONS TECHNICAL PAPER |
| 作者: |
| 所属专业方向: |
风电 |
| 摘要: |
| 关键字: |
| 来源: |
Wind_turbine_PSCADV42.rar
(1.17 MB, 下载次数: 100)
! w1 M! E& w& S/ v- t; ^( |6 }* [PART A: INTRODUCTION 1 6 t/ C. w4 [/ \6 r
1. Introduction..................................................................................................................3
( L6 i) u# I# I/ q' V: \0 J2. pscad components....................................................................................................5 3 a; {( i' ?6 X, v9 u% k8 D
3. Modelled structure .......................................................................................................7 - w; _! _1 f) @/ y3 o" U7 U
4. Simulations performed.................................................................................................9 . K# e* O/ W: I: c/ w* |
PART B: BUILD THE MODEL 11 7 H" ~1 J; \4 p* l0 n$ Q9 S/ w0 {
5. From the wind to the Synchronous Generator ...........................................................13 ! C8 n. @' h8 Q/ ^5 K6 X: n' h
5.1 The Wind Source.........................................................................................................14 7 f; A8 } Q% u# j7 A; \- \
5.2 The wind turbine component .......................................................................................15
' h2 e; ?. {! }& _5.2.1 Theoretical study ...................................................................................................15 9 V" F2 e8 ^2 c
5.2.2 Cp curve with PSCAD standard model .................................................................16 ( d' n3 Q1 E K
5.2.3 Computation of parameters...................................................................................17 8 [) v# `+ C8 f1 ^5 c: f! S. R- F
5.2.4 Define the Wind turbine parameters .....................................................................18
$ Z8 |7 Y3 L/ J; x" `7 W$ `9 P5.3 Wind turbine governor component ..............................................................................19 4 R& l! T8 F; A0 k' O9 d* H) }
5.3.1 Theoretical study ...................................................................................................19
; ~; ]+ |% A+ @; Q( M) l% K5.3.2 Define the Wind governor parameters ..................................................................20
) d2 a# f! |: }$ K- y9 x5.4 The synchronous generator.........................................................................................21
$ d: `. _/ P& ]2 l7 ]5.5 Turbine generator connection: Simulation at rated load..............................................24 4 d# G% u6 F# Z
Simulation parameters & analysis : ......................................................................................24 : f! y1 O8 |6 l
6. AC/DC/AC : Power and Frequency conversion .........................................................27
9 ~6 o5 i/ J' p6.1 Diode Rectifier .............................................................................................................28
4 J, @7 S$ M! q3 b8 I$ M8 Z5 H! b6.2 Overvoltage protection ................................................................................................30
+ C" ]; u0 D, ?2 ?% s# T6.3 DC bus.........................................................................................................................31 7 c7 y' J: p" j7 \
6.3.1 Build the DC bus....................................................................................................31 3 C/ U0 L; d$ c2 W% N
6.3.2 Model validation.....................................................................................................32
. r! n$ o# f0 e1 J6.4 6-Pulse Thyristor inverter ............................................................................................34 + p* B7 r; h4 n* U
6.4.1 Presentation.......................................................................................................... 34
, W, [$ L2 U% q0 [) y, u6.4.2 Voltage collapse limitation .................................................................................... 36
( _/ U. W( ^! w v- ~6.4.3 Voltage regulation................................................................................................. 37
C% @8 k% s1 F# V( G6 J. }: f3 {6.5 Connection to the network ..........................................................................................40 # s! b. e: N% S0 ?" H
7. The distribution grid ...................................................................................................43 9 W, q! E4 g4 | Q% p% H; ~9 i. Z
7.1.1 Definition of the grid.............................................................................................. 43 ) g: T1 @! _0 z# c$ f
7.1.2 Load Flow Simulation ........................................................................................... 47
6 s7 C( r, f1 K2 o1 HPART C: SIMULATE 49 ( U4 R& ?9 g8 \4 a$ m
8. Constant Wind Study .................................................................................................51 8 R h! K' t& |, j" N: y6 e4 O2 H
8.1 Structure the complete model .....................................................................................51 , ?9 l4 r; k$ f6 J
8.2 Constant wind study....................................................................................................53
5 Q b/ j) s$ k% `9. Fault Analysis.............................................................................................................55 1 d; t1 T( } ^& r6 _% p/ Z. D2 _5 U
9.1 Default at Node 3 ........................................................................................................56 ( K3 |2 d; |, K0 c
9.1.1 Without DG........................................................................................................... 56
3 L' r7 D' W% h. z: X8 Z9.1.2 With DG connected at node 1 .............................................................................. 57
8 z D; F$ v9 u6 G& N9.2 Default at Node 2 ........................................................................................................59
, a) |+ B( O8 D+ W$ {/ j, x* {6 m! U9.2.1 Without DG........................................................................................................... 59
7 ~+ ]/ J+ b. A# O) @9.2.2 With DG connected at node 3 .............................................................................. 59
0 I2 ?, n9 Z) f5 M5 j6 \; d9.3 Conclusion ..................................................................................................................61
: l7 p( S* D! e; U( D10. Variable wind study....................................................................................................63 ) C' b/ ]) C: Y1 P5 o5 O
10.1 Dynamic pitch control ..................................................................................................63
: U7 ?* r" C2 r/ K7 m* O10.2 Passive pitch control simulation ..................................................................................67
4 F; @! R6 Q& o7 b3 A10.3 Comparison of passive and dynamic pitch control ......................................................69
8 a* U+ A. \2 Q- `+ ~3 w11. Wind farm...................................................................................................................71
F5 V8 T7 }- y8 w5 d* B11.1 From a single wind turbine to a wind farm ..................................................................72
5 l+ U6 m) m* W# ^4 x f11.1.1 Change the structure of the model ....................................................................... 72
0 R% ?+ ?. U, o& c11.1.2 Modifications in the synchronous generator......................................................... 73
. n7 f; u4 V8 u$ S' ?& H& F11.1.3 Modifications in the transformer ........................................................................... 74 " h$ Z* i9 U- r6 T# |5 F
11.1.4 Modifications in the grid........................................................................................ 74 * Q& `7 z2 f k
11.2 PWM Regulation drives...............................................................................................75 R4 ]4 r/ j0 w
11.2.1 Principles .............................................................................................................. 75 % ~! K6 o$ E5 l. b9 K8 F
11.2.2 Generation of the triangular waveform................................................................. 75
9 C' G8 N4 S. T( v11.2.3 Generation of the reference.................................................................................. 79 4 B$ w2 s7 }3 x9 U2 `
11.2.4 Generation of the firing pulses for the GTO inverter ............................................ 83 $ A+ D) R8 |( p1 c6 y2 h
11.3 Simulation 85
- o* [: ^3 V8 N7 b( bPART D: APPENDIX 87 ( |& Q9 J1 e% S+ z* k' S6 _
12. References.................................................................................................................89 |
