仿真可以正常运行,但只要加入谐波分析模块就显示如下错误。已经用ATP-Launcher修改了存储数组大小,但是不知道修改哪一个 # S. u1 A/ Z/ K" ^/ | y求大佬指点!!!4 ]0 z4 t$ g8 ]
% v2 v4 D5 s: _# n- b8 o
Execution of the program is interrupted in the MODELS section of the data case.5 X/ ]/ i5 O R3 @8 t
The model in use is identified by the following use pathname:: w* M+ v {/ g6 Q6 f
MODELS.HARMONICS ( B a4 ~' l' x " Q0 T* K1 o8 _: T
------------------------------------------------------------------------------------------------------------------------------------ L7 m2 r o/ S( q% K L. H
ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ 4 p' N* t) |$ w8 {3 K& C. I7 wERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/ERROR/9 m. j9 O a( M
------------------------------------------------------------------------------------------------------------------------------------/ `/ o% L! j- Z6 b x
You lose, fella. The EMTP logic has detected an error condition, and is now going to terminate program execution. The following8 E, A1 v0 h, i
message summarizes the circumstances leading to this situation. Where an otherwise-unidentified data card is referred to, or where / a$ D5 @2 a3 H: E0 qthe "last" card is mentioned, it is the most recently read card of the input data that is meant. The 80-column image of this card # K- K6 f; G( ^! W& y2 h! uis generally the last one printed out prior to this termination message. But possibly this last-read card has not yet been * v7 h' p8 a8 A+ G& q" ydisplayed, so a copy follows:& M9 u) F2 n/ }! h% X- {2 D. h
" " 4 `1 Y" S( A8 w9 w4 u( T KILL code number Overlay number Nearby statement number , ^7 |8 T. q! H$ K8 P 644 13 99994 X3 x4 w* r. C* R
KILL = 644. The real storage area is overflowing into the real stack. Increase the storage allocation for MODELS. ' N% t$ F% v1 Z& @4 Q2 U# n X8 i number of used real storage cells as this point = 557818 g0 n. c6 ]# e$ f2 G) p
number of used real stack cells at this point = -349458- i/ j3 A f. |: o5 [0 B3 j$ _
