楼主: rosickywang
用PSCAD仿真双馈风力发电大半年了都没有满意结果,实在没办法,现寻有偿指导!
 火.. [复制链接]
发表于 2010-12-20 12:19:51 | 显示全部楼层
我也在搞双馈风机的仿真。可以交流。
发表于 2010-12-21 02:58:35 | 显示全部楼层
回复 1# rosickywang
! H: V' |, h; R5 I9 U
, k6 \! `& F2 \0 a7 v! f
- t/ @3 _( Y, W5 A    The DFIG simulation case is posted on the website of pscad.com. What is your problem on it. That case works pretty good.1 X5 a5 U* s4 v! D8 F0 i$ M0 {
The only thing not perfect is the loss of the bridge, which in most case people don't care that much.
5 S$ o- M8 h; u! N8 a: k
. P+ i" L3 d* Y/ A2 {, I+ K! |The theory of DFIG is also open to public. You can reference the paper of Pena on IEE.
' J: q+ d+ s  p! @* u" Q+ v( x
/ E3 U3 [8 N6 @8 N) }+ \( H& RA difference of the PSCAD sample case and the paper is the CPWM (not PWM) is used on rotor site converter control. This simplified the control, but still works well.0 G" ^) L* ]1 B- w
; U' n+ O9 f- m9 f; Z" ~9 |9 o3 lYou should have a case and read the paper. If you still have trouble, see and your teacher. It is not very good to hang up there for 6 month. " i+ _+ g3 R; S0 E( l$ L' h
8 w5 [. ^3 O- q7 w
Good luck.
 楼主| 发表于 2010-12-21 15:44:14 | 显示全部楼层
回复 12# yizhangsjtu
; L1 U1 r8 G1 w& R3 d6 n7 r$ ^
9 H0 G! O4 |7 M( O$ |  c9 U2 |* k" l6 Y
    $ }9 W4 K5 l7 \7 w3 r1 D) y
你好,谢谢你的帮助。对于你说的几点,我的理解如下:1.The DFIG simulation case is posted on the website of pscad.com. What is your problem on it. That case works pretty good.以前官网中那个模型电机容量是500 [MVA],很多参数都不满足需要,所以我想修改下,然后就涉及到一些参数选择和计算问题。最新的模型,很多波形的效果都不是很好。: K% g% `* Z  `
2.The theory of DFIG is also open to public. You can reference the paper of Pena on IEEE。很多参考文献中,转子侧的控制都是采用的间接电流控制,即通过电压去控制转子电流。而官网中的模型采用的是直接电流控制。所以我一直是在这个模型的基础上,去改转子侧变流器的控制策略,结果不理想。3 B. I8 F+ T1 N: [4 Q' k
我想请问你是如何考虑上面提到的这两点问题的:即参数的修改和控制策略的改变。
发表于 2010-12-22 04:38:21 | 显示全部楼层
回复 13# rosickywang
6 c. y$ e0 n; O) N0 ~  OI can see you are doing real work. The two points you proposed are the core problem for this case.  m, G: I; V! N8 B
4 T" ]- R" Y! K: {  V2 G* g/ v1. Yes, many of the parameters in control are derived from the machine parameters. Those control constants is not arbitrary chosen, but by calculation.
0 K; u" `9 X: K5 P
2 B) V  z) R3 b% H' f2. As I mentioned in the previous message, the CPWM is used in the sample case. This treatment avoided a very hard part of the control-how to decouple the rotor side converter control. Personally I don't like this simplification very much. But it seems work fine.
/ r* k' A8 _+ r- t+ V3 u, v
& B* j5 N0 x) H/ K# L% e( f2 xThose are not simple questions that can be explained here. Please let me know which university you are, let me see if I can find someone to help you locally.
发表于 2010-12-22 10:32:55 | 显示全部楼层
回复 14# yizhangsjtu 3 K* Q" |$ h; [4 {3 ?4 ?8 T
$ w0 s( d/ e# i- O& [* V' _
3 Y; y  m3 j9 m! p7 j) R
   您好,我是华北电力大学的,是否可以也顺便指导我一下,我的方向是功率控制(direct power control)
    2021-6-12 00:00
  • 签到天数: 1657 天
    连续签到: 28 天
    [LV.Master]伴坛终老
    累计签到:3177 天
    发表于 2010-12-22 11:42:55 | 显示全部楼层
    谢谢你的资料
    2016-7-25 06:47
  • 签到天数: 3 天
    累计签到:3 天
    发表于 2011-6-3 17:00:05 | 显示全部楼层
    我也帮你顶一顶!
    2016-11-12 19:15
    发表于 2011-6-27 11:23:04 | 显示全部楼层
    回复 12# yizhangsjtu
    / ^. U- B0 Z  [: P3 n
    4 S" Y4 X, K6 H+ x+ T7 T9 J/ z7 b4 q8 L; [. C1 {& T
        请问一下,为什么论坛中的其他例子我可以下载,DFIG的例子却下载不了呢?这个资源已经不在了?
    发表于 2011-6-27 14:44:54 | 显示全部楼层
    回复 3# norika
      T. |9 [& O: C: q+ x; R) R3 c% W- ~/ U3 V+ e8 {
    % n: n8 [) k2 R  c8 M1 ?
        PI参数调节常用口诀:6 A8 b! ~8 y! i( z8 Z0 I( V
    参数调整找最佳,从小到大顺序查;
    4 L0 J5 ?! [3 v先是比例后积分,最后再把微分加;% J' `6 g% z  e
    曲线振荡很频繁,比例度盘要放大;: l& A& A2 R1 G, v
    曲线漂浮绕大弯,比例度盘往小扳;5 R0 y5 A1 k1 T" G+ s; N
    曲线偏离回复慢,积分时间往下降;3 [9 L+ h3 l2 B$ L" m; N# @
    曲线波动周期长,积分时间再加长;
    4 I! k6 A& E' O. K7 O' V0 f) \# x曲线振荡频率快,先把微分降下来;; x2 I$ j. ~! w' I& I
    动差大来波动慢,微分时间应加长;  _) U4 Q8 B. a; h6 B9 c0 ?
    理想曲线两个波,前高后低4比1。5 S4 ~1 g( c, }* C4 K6 e/ D9 v3 Z4 a
    希望有用!!!!
    2016-11-12 19:15
    发表于 2011-11-2 09:37:53 | 显示全部楼层
    请问,PI调节的时候不是应该先单端调完再调双端吗,那么在双馈电机里,这个该怎么调呢?谢谢。
    GMT+8, 2026-11-5 10:04
