发表于 2011-1-12 10:36:41
没太明白你说的,配网和大网的结构,r、x比值不一样,算法上用大网的有时不收敛啊
2 [# d2 F" O- X0 v2 kshirleyy 发表于 2011-1-12 10:03
s6 M& A! H6 U1 n: z
* J$ o4 N+ m o- _8 N" ?4 TX/R ratio is already considered in the model. What do you mean by "不收敛"???8 h- g: C/ y- G/ ?9 {
7 R- \' _% J7 {2 l
As far as I know, the distribution utility here in Australia uses PSSE for their network.
$ @3 v8 ~2 ?3 H$ l! W2 c
9 m2 ^4 s1 o1 D9 D8 xSome example of the bus data cut from the .raw file:
$ [) |! s9 O1 n7 T o& R# O. |' @ U- J# s
" 9168,'pd1 ', 0.4150,2, 38, 838, 823,1.01300, 0.0000
( z! U1 b1 [0 X" K0 ? 9300,'zsa', 11.0000,1, 47, 820, 847,1.01300, 0.0000
0 c0 F" U3 k0 S6 k( A6 L......7 K8 J. ~ J5 Y. j
9352,'ZoneSub1' , 11.0000,1, 35, 808, 835,1.01300, 0.0000
0 T8 M* [( C: {0 o 9360,'ZoneSub2', 11.0000,1, 24, 821, 824,1.01300, 0.0000
9 y, k0 R$ ~ l) D4 k 9809,'ZoneSub3', 33.0000,1, 9, 809, 809,1.01300, 0.0000
! U8 v5 z: i; \/ z2 o% o4 P 63300,'TS1 ', 132.0000,1, 23, 828, 823,1.06365, 0.0000
7 s% t+ f2 I7 N 64568,'ZoneSub4', 33.0000,1, 26, 158, 823,1.04370, 0.0000
3 K. N4 l, d3 T4 z" Z; f 65270,'ZoneSub5', 11.0000,1, 24, 1, 824,0.99458, 0.0000: o% | v" |- Z8 s6 i8 }
65272,ZoneSub6', 11.0000,1, 24, 1, 824,0.99458, 0.0000"* r5 d+ X9 R/ ]& \" ]0 y
# M, Z1 C6 x3 Z* i
Highlight in red is the voltage level in KV. |
