警告: A propagation speed of 483775 km/s has been found for mode 2; Propagation speeds must be < 300000 km/s! [75 similar] 7 A; N$ o; ^" P5 w- y4 k0 ~- ]$ E + _! n$ e- o7 B( j7 z+ ]! aMatching "From" for "Goto" 'IEEE30/B1-2/Iabc' not found [211 similar]8 F. |' o q6 Y* M: ^
Component:Simulink | Category:Blockwarning ! V6 ~- n O- b" B( eOutput port 5 of 'IEEE30/Power Plant #4/Turbine & Regulators M2/Bus Selector' is not connected. [3 similar]) Z, ~" |, M7 \" `
Component:Simulink | Category:Blockwarning4 d6 t2 l' _3 x' D
The block diagram 'IEEE30' uses bus signals or has signals/parameters that are associated with bus objects. However, the 'Mux blocks used to create bus signals' diagnostic is not configured to 'error'.8 f7 }' [, q: u) R- k
Suggested Actions4 o" e3 a0 d0 B: C8 K
Run the 'Check Bus Usage' check in Upgrade Advisor and follow the recommendations) _; x% T! s: v* ?% i
0 z' O5 E6 |5 k# ]0 U3 |) V
